Bimmerpost for iPhone and Android have just been updated with a host of bug fixes. If you've ever had trouble logging into it in the past, give it a try now!
2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Burger JB3 Kit, DIY step 2. Very important!!!!!!!!
      08-30-2011, 02:31 PM   #1
yxc145
Drives: 2011 535i
Ladies and Gentleman.
I finally got my JB3 kit installed, after 3 tries with the instructions provided by Burger tuning website and thread.
Step #2. Disconnect and connect the MAP sensor under the Airbox.
SERIOUSLY, Don't waste time trying to do that with the airbox in place. It is extremely difficult, nearly impossible, and super ackward. And if you don't do it exactly right, you may risk breaking the sensor connection/clip.
Taking the airbox out is a piece of cake!! Since it is held in by two rubber grommet down the bottom, all you really have to do is loosen the clamp on one hose/pipe end, pull it out, lift up the airbox, then pull out the other side of the hose/pipe.
There is no wiring or anything important connect to the airbox.
Seriously, if you are going to install the JB3 kit. This is the best way. Literally takes total 6 minutes and 30 seconds. 1 min for TMAP, 2 minutes for the airbox, 30 seconds for the MAP, 1 min for MAF sensor, then finally 2 min for the last sensor.
IF you have to take more than 10 minutes to install with my suggestion, I will pay you money to have this installed by a shop!!! Just kidding.
Hope this is helpful for all future installer. Lesson learned after 4 tries, 3 hours, and 2 cut up hands, and 1 good mechanic.
      08-30-2011, 04:44 PM   #2
78mao
78mao's Avatar
Taiwan
65
Drives: F10, F13, current->F80, F15 X5
2015 M3 BMW M3  [0.50]
great tips!!
definately sounds alot easier with ur guidance!!
thanks for the heads up with people thats interested in installing this.
      08-30-2011, 09:27 PM   #3
yxc145
Drives: 2011 535i
Originally Posted by 78mao View Post
great tips!!
You are welcome. I also think I hide the kit pretty well. The module is totally hidden. I don't think I am going to take it off when I go in for service.
Oh, Finally. I did notice the difference. Too bad, I can't drive too fast.
