2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Made a custom exhaust and x-pipe
      12-20-2012, 05:24 PM   #67
topaz330
Drives: 15 X5M
my exhaust shop was looking at doing a similar setup but said that all he needed to do was add side branch resonators to the system to eliminate the drone. has anyone done this? i googled and came up with tons of posts that say this really works.
http://www.6speedonline.com/forums/m...esonators.html
      12-22-2012, 07:22 AM   #68
Edman951
Edman951's Avatar
Drives: 2014 i3, Capparis White
Yes to remove the drone a branch resonator per muffler can help, or eliminate the drone.But it needs to be correctly sized. As the resonance needs the correct volume to disapate its self.
I added some to my setup, but i didnt size it right. So this winter i will redo it.
Current, i3 Capparis White, Lodge interior
Ex- F10 550i Xdrive M sport, white
Ex- trade-in 2008 E90 M3
      12-31-2012, 02:12 PM   #69
topaz330
Drives: 15 X5M
gotcha, so in your opinion, remove the secondary cats or leave it in?
      03-01-2017, 09:48 PM   #70
mpbmw94
mpbmw94's Avatar
23
Drives: 2013 550
Sounds great. what X-Pipe did you get? looking at doing the same on my car. Thx
      03-02-2017, 04:00 PM   #71
STR8-6IX
Drives: RWD 528i N52
Decided to try making my own x-pipe and exhaust.
I wanted a modular system that i could use only the x-pipe with the factory exhaust, and with my exhaust. and be able to put everything back to stock easily.
I used the factory bolted clamps to make it a bolt on and off system.
I couldn't find a x-pipe that was 2-3/4'' OD, so i looked around and found a x-pipe made for a C6 Corvette that was very close to what i needed, but was 2-1/2''OD. So not the best for flow, but figured it would do the job for now.
On thing to note is the car runs 9psi stock., and when i did a test drive using just the x-pipe, i was seeing about 12psi on my gauges, so this car really likes less restriction. and when i drove it with the factory exhaust connected, boost went back to 9psi. I was thinking to redo it with 3'' pipe maybe someday.
Here are a few pics.
I cut the factory exhaust after the secondary cats, and before the muffler cross brace. I can install my x-pipe with the factory mufflers, or with my home made mufflers. so my system is modular by using BMW bolted clamps, and fast to go from one setup to the other, and back to stock.
I used Vibrant stainless steel piping, and two of there resonators as mufflers.
Making it a very cost effective system.
Sure my weld are not sexy, but all in all, i'm happy i did it, was a fun small project, and didn't cost me much.
It's not a high dollars engineered system, but still sound pretty good.
It does have the typical drone as do most exhaust systems.
why didnt you remove the secondaries while you were at it?
