2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Burger Tuning - N55 Stage 1 Boost Level
      09-27-2011, 12:34 PM   #23
aznevoviii
Bimmer n00b
aznevoviii's Avatar
Drives: none
My dealer is pretty mod frendly, so I won't be worry about it, but that's just me.
      09-27-2011, 03:06 PM   #24
yxc145
Drives: 2011 535i
Originally Posted by Njaza View Post
What are your plans when you take your cars in for oil change or service with the dealer? Will you take harness off to avoid possible warranty voiding?
I was originally gonna leave it in, but now I figure out the best way to install/uninstall this in less than 10 minutes, I will take it out.
Plus, it will help refreshing the feeling of having the mod.
      09-27-2011, 03:34 PM   #25
jaekeem
BMW Noobie
jaekeem's Avatar
Drives: e90 M3 e46 M3 Macan S Model S
I leave mine in since its well hidden from the install.
When I spoke with Terry he told me our JB3 isnt recognized during vehicle scans because the JB3 does not tap into the CANBus system.
So it really shouldnt be an issue, the last time I took it to the dealer I just set the JB3 on the stock OEM setting with it installed.
I'm going to the dealer in a few weeks to get my 15k mile service so I'll let you know what happens.
2011 F10 535i | Build Thread | Power Mods & Dynos
      09-28-2011, 10:39 AM   #26
yxc145
Drives: 2011 535i
Hi Jackeem
When you said OEM setting, do you mean setting the boost level to 0.0?
      09-28-2011, 03:54 PM   #27
jaekeem
BMW Noobie
jaekeem's Avatar
You can select from two maps and not just the boost setting.
I believe stock map is 0 and the stage 1 is map 1. Dont hold me to that as I'm on my mac right now
      10-06-2011, 10:53 AM   #28
yxc145
Drives: 2011 535i
ok, I think I will order my cable today and just do the manual adjustments
      10-07-2011, 11:25 AM   #29
trojanlee
Drives: F15
Jae and Yxc. I been reading your guys post for a while regarding the JB3..
What does the butt dyno tell you. Can you describe it a little more compare to stock.
      10-10-2011, 10:58 AM   #30
yxc145
Drives: 2011 535i
I did not get it dyno tested. But I can definitely tell a difference from the stock performance. I have it set at 4.1 boost level now. I heard from many that has this kit that 4.5 is the best number. I just ordered the cable and will increase it to 4.5. I will let you know how it feels.
this is a good mod for only about $400. Most of the computer tunes out there runs about $900 or more.
      10-13-2011, 04:34 PM   #31
trojanlee
Drives: F15
Are you running on 91 or 93 oct
      10-13-2011, 05:52 PM   #32
yxc145
Drives: 2011 535i
93 Oct
      10-14-2011, 11:54 AM   #33
yxc145
Drives: 2011 535i
Jaekeem
I just got my cable and did "something" to the MAP. I changed the boost to 4.5 on Map 1. Saved it. But when I switched back to MAP 0 and went back to user adjustment, how come the boost still says 4.5? I thought MAP 0 is suppose to be stock OEM level, which should have the boost back to 0.00.
Let me know if I am doing something wrong.
      10-14-2011, 03:59 PM   #34
jaekeem
BMW Noobie
jaekeem's Avatar
If you change to map 0 the boost setting shown is for Map 1. So there is nothing you did wrong on it, thats just the nature of the application Terry put out.
If you change the JB back to Map 1 then the 4.5 boost setting is what it will be running at.
      10-17-2011, 11:23 AM   #35
yxc145
Drives: 2011 535i
Thanks Jaekeem
So when I am ready to take it to the dealer for service. All I have to do is click to MAP 0 and then save, it will be back to stock level? nothing else needs to be changed?
      10-17-2011, 11:47 AM   #36
aznevoviii
Bimmer n00b
aznevoviii's Avatar
Drives: none
is there any easier way to change between maps otherthan hooking upto a laptop?
(like e90/e92 gas pedal method..)
FYI I lowered it down from 5.5 to 4.75, because at 5.5, I felt fuel cut at high gear low rpm range, also constant "traction" light blinking (due to power? or maybe running staggered on xdrive)...
but at 4.75 the fuel cut is definitely gone, traction lights are on still there but not as bad as before. (obviously with sport+ it ran like a BOSS with WOT)..
      10-20-2011, 10:48 AM   #37
yxc145
Drives: 2011 535i
ha ha
Burger tuning site did state CAN Tool will not work for the F10 model
anyway, glad you got the kit. For some reason, when I adjust the boost from 4.1 to 4.5, I did not feel any difference.. actually felt slower..
I hope I am not doing something wrong.
      10-20-2011, 05:21 PM   #38
blackberrycubed
Drives: 535i Xdrive
I had been running at 3 for a few months now and changed it 2 yesterday. After driving it for a day or so I think 2 works much better than 3 as I don't feel any more lag\hesitation before the power kicks in when WOT. On 91, with 3.00, I believe there was retardation going on. Gonna drive with 2 for a while and see how I like it.
      10-20-2011, 06:13 PM   #39
aznevoviii
Bimmer n00b
aznevoviii's Avatar
Drives: none
i love my setting 4.75 with my downpipe + full exhaust!!
      10-22-2011, 01:30 AM   #40
jaekeem
BMW Noobie
jaekeem's Avatar
John
I have the same setting or close to it. I felt the same throttle response with the jb when it was set over 5psi. I'm currently at 4.5 and am happy with it. I will go back to 6 once my new methanol kit comes in.
      10-25-2011, 07:10 AM   #41
Kriston
The Ultimate Driving Machine
Kriston's Avatar
Drives: Like Donkey Kong on Roids
Fellas a quick question,
im pretty new to the boost etc..... I was told i should data log the car before i change the map to 4.0 or 4.3 (where i want to set it at) have any of you done this before?
CHUCK NORRIS ON WHEELS
      10-26-2011, 09:26 AM   #42
yxc145
Drives: 2011 535i
There is another thread/link that you can download the JB software. Then you need to get the JB data cable (NOT the CAN Tool), in order to do this.
whoops, I think I answered the wrong question.
      10-28-2011, 06:42 PM   #43
blackberrycubed
Drives: 535i Xdrive
2.5 seems the best to me at 91 octane.
      11-04-2011, 10:52 AM   #44
Kriston
Kriston's Avatar
I have mine at 4.2 and its nice. But thinking about dropping down to 4.0 to be on the safe side.
