2010 2011 BMW 5 Series Forum F10 BIMMERPOST Universal Forums General BMW News and Cars Discussion BMW E28 M5 CSL Custom Build
      12-16-2011, 10:31 AM   #1
JimVR4
JimVR4's Avatar
Drives: 09 328i M-Sport 6MT
BIMMERPOST
     Featured on BIMMERPOST.com
Im new to this forum, and thought it would be a good place to publish the car we have been building for some time.
Since the E9 3.0 CSL is possible to buy, we didnt choose that easy path when it was time to build our new race car...
First, we retired the E28 M535i we used to run in the racing series.
And then we bought in a scrappy old 528i to experiment with...
Once it was welded to the wanted shape, we made molds of it, and scrapped it out. Molds and other items seen here.
Then we stripped down the M535i and prepared a S38B38 Evolution engine for the new car...
Said and done, we made some new fenders in the molds, and put them on to the car to see what we had created...
BBS wheels for rain and for dry was invested and stored.
Off to the paint shop, and back it came...
Some assembly time later it looked like this...
And next to a stock M535i it looks like this...
And when all is put together and the colour scheme was completed, it made its first apearence in the race!
The car has been struggeling with some strange problems all season and didnt perform any results to brag about so far. Once all problems seemed sorted out, a new one came, and this time it was a hard one to find... Fuel hoses that wont stand the high octane race fuel and therefore melting slowly inside, rubber parts get stuck in the fuel injectors and the car runs lean and wont rev up as it should.
Jegs has now shipped a better hose and we look forward to the next (final) race that takes place in October 10.
The rear doors are welded in place and wont open unless Hulk Hogan manages to find the handle...
I will try to publish some technical specification if its for anyones interest.
And regarding the photoshoot with a real CSL, it has already been made...
The rear doors are totally cut out and its just a frame holding a fibre glass door sill in place, almost no metal left at all, all windows are of 3mm lexan plastic and all bodypanels are of composite materials, suspension and chassie mainly of aluminum.
There is however at least another 50 kg (150 lbs) more to reduce and it will be made in near future.
The front wings are about 2-3mm thick and very light, and equipped with the M5 E60 vents, in true CSL Batmobile style
Wheels are BBS RS 3-piece 11x16" in front and 12,5x16" in the rear. Light and beautiful.
Ok, i guess its time to write some technical information about the car, if you dont mind.
Some short and basic information:
Body: BMW E28 w/o sunroof, rebuilt to coupé, extended FIA safety rollcage, raceweight aprox ~1100kg with driver. Vented body - 200mm (8") wider in rear, 160mm (6.3") wider in front.
Engine: BMW S38B38 (6-cyl 3.8l-24v 365hk/8000rpm)
Gearbox: Getrag 260, shortshifted 5-speed.
Final drive: BMW M3 Group A limited slip, 4 different gear ratios available.
Front brakes: 6-piston aluminum calipers, 330mm (13") rotors.
Rear brakes: 4-piston aluminum calipers, 303mm (12") rotors.
Wheels front: 10x17” BBS (rain), 10.5x16” BBS (slick).
Wheels rear: 12x17” BBS (rain), 13x16” BBS (slick).
Tires front: 275-17” rain, 11,0-23,5-16” slick.
Tires rear: 335-17” rain, 12,5-25-16” slicks.
Chassie / suspension front: BMW Motorsport/Schnitzer 635CSi Grp.A. Suspension arms extended to allow more aggressive settings, wheelbase extended by 40 mm (1.6"), and track width extended by 80mm (3.1").
Chassie / suspension rear: BMW Motorsport/Schnitzer 635CSi Grp.A, Suspension arms fully adjustable for camber/caster and toe. Reinforced A-arms and all stiff mounted joints, no rubber in attachement points.
A lot of the spec is similar to the E9 3.5 CSL when it comes to tire dimensions and type, spring setting is also similar to the ancient race car, shock settings are similar to the classic E24 635 factory racers and the data has been partly collected from BMW Motorsport, Germany.
The rollcage is a copy of the one used for 1982 ETCC winner BMW 528i E28 once the aluminum cage was cancelled.
There is a lot more to write, but this is what comes to mind at this point. Let me know what you need information about, and I will be hapy to provide you all with it.
Attaching a pic that was taken for a car magazine a few weeks ago.
2009 E90 328i ///M-Sport / Blue Water Metallic / Oyster/Black Dakota / PP / 6MT / 194M / Comfort / iPod+USB w/ProClip charging dash mount / $494 /
1995 3000GT Spyder VR4
JimVR4 is offline   United_States
      12-16-2011, 10:34 AM   #2
AddictedToBavarian
My other ride is a Bianchi Infinito
AddictedToBavarian's Avatar
Drives: E92 328xi
Pretty cool.
AddictedToBavarian is offline   Portugal
      12-16-2011, 11:15 AM   #3
apc3libras
apc3libras's Avatar
Drives: 2010 GMC Sierra
Awesome.
Jeremy
2007 BMW 328I - SOLD
2010 GMC Sierra Crew Cab SLT
apc3libras is offline   United_States
      12-16-2011, 11:20 AM   #4
darebornsolja
Drives: e92
Would not mind cruising in that~
darebornsolja is offline   United_States
      12-16-2011, 11:34 AM   #5
90rr
90rr's Avatar
Drives: 2007 328i
nice!
http://i35.photobucket.com/albums/d159/novak223/jK.jpg
90rr is offline   Reply With Quote
      12-16-2011, 12:11 PM   #6
Clifton
Clifton's Avatar
Drives: Cars with tires
Regards,
Clifton
Clifton is offline   United_States
      12-19-2011, 12:27 PM   #7
VincentMorin
Concept Art - Illustration - Storyboard - Design
VincentMorin's Avatar
Drives: e90
Amazing job!
Vincent Morin | Concept Art - Illustration - Sequential Art - Design - Animation
Website. www.vincentmorin.com
VincentMorin is offline   Canada
      12-19-2011, 12:29 PM   #8
MoeM3Power
Vago Pirata
MoeM3Power's Avatar
Drives: Voluptuous
Lovin that M5 looks!
MoeM3Power is offline   United_States
      12-19-2011, 12:38 PM   #9
Jesal@IND
Jesal@IND's Avatar
Drives: E90 SSII M3
Send a message via AIM to Jesal@IND
Im in love!!
IND DISTRIBUTION | 866.963.4520 | IND STYLE | FACEBOOK
Jesal@IND is offline   United_States
      12-19-2011, 12:39 PM   #10
Adj5633
Adj5633's Avatar
Drives: Screws
I am speechless, great job guys. Very ingenious of you.
Adj5633 is offline   Canada
      12-19-2011, 12:40 PM   #11
eliemman
eliemman's Avatar
Drives: 2007 E92 335i Space Grey
2007 E92 335i  [4.38]
Awesome build! Love it!
eliemman is offline   United_States
      12-19-2011, 12:40 PM   #12
BMWSzabi
BMWSzabi's Avatar
BMWSzabi is offline   Hungary
      12-19-2011, 12:40 PM   #13
Bakeme521
Some say...
Bakeme521's Avatar
Drives: Fresh
2007 BMW 335i  [4.39]
baller status
I have exhaust and an intake...
Bakeme521 is offline   United_States
      12-19-2011, 12:47 PM   #14
ATS
ATS's Avatar
AMAZING job!!!
ATS is offline   No_Country
      12-19-2011, 12:47 PM   #15
mshab356
Go ///M or go home
mshab356's Avatar
Drives: a ///Monster
Wow it looks sick right out of paint/assembly when it's plain white with the gold BBS wheels on it!
2011.5 SG E92 ///M3 6MT | CF kidney grills | IND SG painted side grills w/ tinted lenses | Painted bumper reflectors | TMS 90mm stud kit | Rear fog light mod | Active Autowerke exhaust |
mshab356 is offline   United_States
      12-19-2011, 12:55 PM   #16
Vegas_Sirk
Its All About The Offset
Vegas_Sirk's Avatar
Drives: 2011 E90 M3 ZCP
Location: Where you come to vacation and go home on probation: Vegas
Send a message via AIM to Vegas_Sirk
Such a awesome build!
AKA M3This (changed my user name ) | M3 Build Thread | E61 Build Thread
Vegas_Sirk is offline   United_States
      12-19-2011, 12:58 PM   #17
Dackelone
Dackelone's Avatar
Drives: 135i Silber mit/Rot 6MT N54
I love everything you did! Me wants!!
Dackelone is offline   Germany
      12-19-2011, 01:26 PM   #18
Onurleft
Onurleft's Avatar
Drives: RPM
This is one of those cars that comes up in my dreams
Youtube: 95CSL
Onurleft is online now   Reply With Quote
      12-19-2011, 01:31 PM   #19
Ken@ActiveAutowerke
Drives: various BMWs
wow.. i really really like!
Ken@ActiveAutowerke is offline   United_States
      12-19-2011, 01:32 PM   #20
AvetNY
AvetNY's Avatar
Drives: BMW X6
BMW
http://www.xbimmers.com/forums/image.php?type=sigpic&userid=140209&dateline=13205  48990
AvetNY is offline   United_States
      12-19-2011, 01:37 PM   #21
Just_me
Drives: RWD
Track: Ring Knutstorp
BMW M3 V8 CSL petition. You want BMW to build a M3 CSL?
Then sign your name here:
http://www.petitiononline.com/m3csl/petition.html
Just_me is offline   Reply With Quote
      12-19-2011, 01:47 PM   #22
GOLFFRR
Architect
GOLFFRR's Avatar
Drives: Golf Cart
awesome!
BEFORE YOU BUY YOUR NEXT BMW, PM ME FIRST I CAN HOOK YOU UP!
We are Performance Center|Euro Delivery|BMW Individual Specialist
Need a quote?..Ryan /Checa Email link | T.805.482.8878 ask for Francesca
www.stevethomasbmw.com | OUR PARTS STORE | Facebook-STBMW | Twitter-STBMW
GOLFFRR is online now   Reply With Quote
Forum Jump
