2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums USA - California ✪ Alekshop | Bay Area Wheels Mounting and RoadForce Balancing Service
      12-26-2011, 12:28 AM   #1
Alekshop
Alekshop's Avatar
Drives: M3LR l 1M l X5 l GT-R
Send a message via Skype™ to Alekshop
Hey Guys,
Now we are offering tire Mounting and Road Force Balancing service in house!
To ensure that every customer leaves our shop with perfectly mounted and Road Force balanced wheels, we decided to perform this service in house on our new Hunter Road Force GSP9700 Balancer and Tire Changer. Now we can guaranty your wheels will be mounted & balanced the right way and you don't have to worry about your new and expensive wheels being scratched or damaged!
When it comes to mounting & balancing wheels, most people don’t know the difference between regular balancing and Road Force balancing.
Hunters’ Road Force GSP9700 balancer goes far beyond the traditional functions of a wheel balancer and performs a computer simulated “road test”. It measures radial and lateral tire forces by applying the roller directly to the tire providing instructions for solving ride and handling problems such as tire pull and wheel vibration that regular balancers cannot detect.
Road Force balancing vs Traditional balancing:
Road Force measurement system applies up to 1,400 pounds (635 kg) against the tire. The loaded roller detects non-balance, radial-force-related vibrations caused by eccentricity and constructional variation of the tire and wheel. Unlike non-contact measurement, the roller samples the entire footprint of the tire including the sidewall’s contribution to ride quality.
Non-contact runout measurement systems (traditional balancing) often provides inconsistent results and do not take into consideration the contribution of tire sidewalls to vibration problems.
Now you are going to ask how wheel force variation is corrected?
Once the stiff spot (high point) on a tire and the low spot on the rim are identified, we can match mount wheel to the tire for maximum roundness. This will eliminate or reduce vibration and pull to the minimum.
Next step would be to place wheels on the car. Seems like an easy task, but in order to get that perfect comfort ride, our machine will let us know which wheel has least/most lateral force and where it should be placed on the car. Without having that option, even a perfectly balanced wheels can create vibration and pull.
This is why it’s so important to have the right equipment and know the difference between traditional and Road Force balancing.
Here are some pictures of the wheel that we mounted and balanced for our customers.
Wheel is being ready for mounting the tire.
Using special TPMS torque wrench to make sure TPMS sensors are not over torqued.
Tire is mounted and the Yellow mark on the tire is matched to the location of the TPMS . This is done to reduce wheel force variation.
Tire is mounted on the balancer and ready to be Road Force balanced.
Laser beam indicates the ideal placent for the wheel weight.
If you have any questions or would like to schedule an appointment feel free to contact me.
Aleks
✆ 925.609.4559
info@alekshop.com
@ www.alekshop.com
Like us on Facebook ✆ 925.609.4559 ✉ info@alekshop.com
Alekshop is offline   United_States
      12-26-2011, 09:32 PM   #2
Alekshop
Alekshop's Avatar
Here is another set of HRE Center Lock Porsche wheels that we mounted for guys from Shark Werks.
      12-27-2011, 07:07 PM   #3
Alekshop
Alekshop's Avatar
Here is another set of 19" TE37SL that we mounted and RoadForce balanced for our customer:
      01-01-2012, 11:24 PM   #4
Alekshop
Alekshop's Avatar
Mounting Oranges
      01-01-2012, 11:32 PM   #5
EV0LVE
EV0LVE's Avatar
Drives: F10 535i SG
Wow that blue/orange RS is heaven on wheels. I'll wash that car for free!
EV0LVE is offline   Reply With Quote
      01-04-2012, 12:19 AM   #6
Alekshop
Alekshop's Avatar
Here is another set of TE37SL we mounted/balanced on e90 M3
      06-04-2012, 05:46 PM   #7
Alekshop
Alekshop's Avatar
Here some ADV.1 reverse mounted and RoadForce balance on 2011 997TT
      06-08-2012, 11:19 AM   #8
Alekshop
Alekshop's Avatar
Set of BBS Motorsport Porsche wheels that that we recently mounted and RoadForce balanced
      07-06-2012, 01:13 AM   #9
Alekshop
Alekshop's Avatar
A set of Limited Edition Flack Black TE37SL just was mounted and RoadForce balanced
Reverse Mounting
Hide behind the spokes weights placement so you can't see it
On the car!
Forum Jump
