2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Borla Exhaust tips on 550i
      01-23-2012, 02:19 PM   #23
FlobeySolo
Drives: 2012 550i, M-Sport, plus ....
Dumb question, but instead of speculating I'll ask: What's the purpose of the vacuum line?
Your tips look fantastic, BTW. Something I'll definitely entertain when my 550i finally arrives next month.
      01-23-2012, 02:24 PM   #24
FlobeySolo
Nevermind...found it...http://autorepair.about.com/library/faqs/bl104d.htm
      02-13-2012, 08:04 PM   #25
Ellmat
Ellmat's Avatar
Drives: E70 3.0D MSport
Quality improvment...
      04-08-2012, 09:19 PM   #26
alexcyhuang
Drives: 2011
550i trapzoid exhaust tip
Do you think I can take the trapzoid exhaust tip off your hands? I don't want the quad(4)-looking exhaust anymore since I had it on my other cars. Please let me know, greatly appreciated...
alexcyhuang@gmail.com
      08-16-2012, 07:02 PM   #27
HDEddie1
HDEddie1's Avatar
Drives: '12 F10 550i, '08 E60 528i
Exhaust Tips? Still keeping?
I know you mentioned you plan on keeping the exhaust tips....any change of mind? Would be interested in buying. Thanks
      09-25-2012, 12:17 AM   #28
JimmyD
Jimmy D. 2011 F-10 550i Sport, Black Sapphire
JimmyD's Avatar
Drives: 2011 F-10 550i
2011 BMW 550i  [0.00]
What did you plug the hoses with, still after time have you noticed anything unusual?
      09-25-2012, 07:25 PM   #29
tp550i
tp550i's Avatar
Drives: 2011 550i Sport
I plugged the vacuum lines using small plastic screw and wire-tied to keep it tight. It's a vacuum line so plug it securely or plug it at the source - the vacuum activator. 10 months and no problems or codes.
F10 550i Space Gray | Dinan Stage 5 | Eisenmann Race | ACS springs | 20" Ferric Grey 312 - Michelin PSS
      09-25-2012, 10:21 PM   #30
JimmyD
JimmyD's Avatar
Thanks, I ordered the tips, now to see if they fit. I ordered the 2013 M-5 tips, My dealership didnt charge me to order them until they see if they are going to fit, if they dont I will order the Borla like you did.
      09-26-2012, 08:20 AM   #31
tp550i
tp550i's Avatar
The M5 tips were not available earlier in the year - let us know how they fit.
      09-27-2012, 09:12 PM   #32
JimmyD
JimmyD's Avatar
I received my borla tips today, did you weld them on, the pics you posted didnt look welded, also did you have to cut down the 2-1/4 inch side to shorten them a bit, so they didnt stick out so far?
Thanks,
JimmyD
      09-27-2012, 09:15 PM   #33
JimmyD
JimmyD's Avatar
The M-5 tips were just clip on tips, and they arent angled, the borla are much better, and more heavy duty, the 2013 M-5 tips from BMW are really thin and not worth the $77.00 a piece that they charge.
      09-27-2012, 09:19 PM   #34
tp550i
tp550i's Avatar
Thanks,
JimmyD
yes the Borla tips are tack welded on. No cutting to shorten them. I cut the stock tips off about 3/4" away from the muffler using a sawz-all and slid the Borla tips on until the length looked good
      10-07-2012, 09:43 PM   #35
JimmyD
JimmyD's Avatar
Did you disconnect the battery before welding, if you did, what had to be reset? also I noticed the outside exhaust tubes from the muffler cants inward while the other tube is straight, was there any play when you slid the tips on so you could shift both tips to look parallel with each other?
      10-07-2012, 09:53 PM   #36
tp550i
tp550i's Avatar
No we did not disconnect the battery. There is enough inner diameter difference to position these any way you like. I tack welded one side of the tip to the muffler to hold it in place - then using a breaker bar placed into the center of the tip - pried them into position before welding the other side
      10-07-2012, 11:28 PM   #37
EBRSKIH
Chef
Drives: F10 550i
Does your car feel like you lost any back pressure at all?
2013 X6 50i Sapphire Black
2012 550x Alpine White
- 12.727@108 - 1.7 60ft lemon'd
2011 550i Sapphire Black
- 12.960@109 - lemon'd
      10-08-2012, 05:06 PM   #38
JimmyD
JimmyD's Avatar
Thanks for all your advice and help, going to cut them off in the morning I hope and weld new ones on.
      10-08-2012, 05:39 PM   #39
tp550i
tp550i's Avatar
barely noticeable at lower rpms and idle.
remember measure twice and cut once -
its alway easier to cut them shorter than it is to lengthen.
      10-10-2012, 12:47 AM   #40
JimmyD
JimmyD's Avatar
Came out Great
Thanks for your help and your post
      10-10-2012, 07:52 AM   #41
tp550i
tp550i's Avatar
Nice work - they look good in stainless
      10-20-2012, 11:43 PM   #42
Alex@ONEighty
Alex@ONEighty's Avatar
Drives: 2011 E90 M3 CZP 6MT
Exhaust tips look great, but I feel like the quad setup fits the M Sport a lot better. The Square Tips just flow better with the car, much more classy look.
      11-09-2012, 01:31 AM   #43
HDEddie1
HDEddie1's Avatar
+ 1 for the square tips!
Thanks to Jimmy D, I was able pick up his chrome tips to switch out my black tip . I set them about 3/4" from the bumper facia...the contrast with the M Sport diffuser looks good to my eyes. Car is otherwise still a stock and mellow ride.
Just as a back up, I'm sitting on a set of '07 M6 mufflers ready for a quad tip conversion just in case I tire of chrome square tips. If I go that route, I think all will be lost since I'll want to put on an M5 style diffuser, add some 3" mandrel bent pipes all over, drop the car with some coil overs, through in some Dinan 2, etc (Yikes!)
      11-09-2012, 01:36 AM   #44
HDEddie1
HDEddie1's Avatar
Pic of the chrome tip:
Pic of the chrome tip on an M Sport:
