2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes 2012 550i Xdrive staggered setup
      02-08-2012, 02:46 PM   #1
EBRSKIH
Chef
Drives: F10 550i
Will be hopping into a 2012 550i Xdrive. I have 20 inch wheels and was wondering what tire setup I can run without messing up the xdrive system, I know there is a formula or way of figuring it out but I couldnt find anything thru the search. Front is 245/35/20 and the rear is 285/30/20. Thanks.
Emir
2013 X6 50i Sapphire Black
2012 550x Alpine White
- 12.727@108 - 1.7 60ft lemon'd
2011 550i Sapphire Black
- 12.960@109 - lemon'd
EBRSKIH is offline
      02-08-2012, 03:36 PM   #2
bimmer man
bimmer man's Avatar
Drives: 2012 535d xdrive. 2013 x1 18d
2012 Bmw 116d  [5.00]
2012 535d xdrive  [4.50]
hey. I orded 20" 373M factory wheels for my 535d xdrive and tires dim. are 245/35/20 in front and 275/30/20 rear. And star marked wheels only, for not messing up Xdrive system.
bimmer man is offline   Norway
      02-08-2012, 06:00 PM   #3
Hunter5179
Hunter5179's Avatar
Drives: 2013 M6 Coupe
That's the same sizes I have but what are STAR marked wheels?
2013 M6 Coupe SG, Akropovic Evo Carbon, Vorsteiner Full Aero Kit & VSE-003's 3PC 20's, Gruppe M Intake, Bel Stir Plus with Dual HP Laser Interceptors, JL Custom 2X12W6V2's Subs, 35% tints all around.
Hunter5179 is offline   United_States
      02-08-2012, 08:49 PM   #4
mgcyr
Drives: 2012 550i TiAg & 2012 X5 35d
It was recommended that I go with 285/30/20 in the rear. What would the difference be?
mgcyr is offline   Reply With Quote
      02-09-2012, 12:41 AM   #5
bimmer man
bimmer man's Avatar
hey. 285/30/20 are not rigth dim. rear Wheels going slower than front wheels and you will fuck upp our xdrive sytem
      02-09-2012, 01:26 AM   #6
bimmer man
bimmer man's Avatar
All bmw xdrive have star wheels from factory, star mark are a quality mark for absolutely round tires. best off the best. A STAR ARE MARKED ON TIRE.
      02-09-2012, 01:33 PM   #7
mgcyr
Are you sure about that? The 285's are closer in diameter to the fronts than the 275's.
      02-10-2012, 02:26 AM   #8
bimmer man
bimmer man's Avatar
yes. I talk to BMW Norway and they say. If I have any diffrent tire set upp. I will loose my Worreny on Xdrive system and gearbox.
      02-10-2012, 02:52 AM   #9
Hunter5179
Hunter5179's Avatar
245 front and 285 rear on 20" does have a closer rolling diameter than 275's but either setup is fine.. nothing major.
      02-10-2012, 03:17 AM   #10
Hunter5179
Hunter5179's Avatar
245/35/20 fronts Speedometer Difference: 0.154% too slow with a diameter difference of .15%..............For 275/30/20 rear's Speedometer Difference: 0.834% too fast with a Diameter difference of .83%........For 285/30/20 rears the Speedometer Difference: 0.077% too slow with a Diameter Difference of .08%
The difference in rolling diameter for either of these compared to stock is really negligible and should not affect the x drive at all.. Its when rolling diameters exceed 2.0% and definitely above 5% is not good.
      02-11-2012, 02:31 AM   #11
EBRSKIH
Chef
Drives: F10 550i
So the dealer will agree that there will be no problem? I honestly have no clue how you got these numbers but it seems like you know what youre talking about. The way I thought about it was that the 245/285 setup will work because the X6 runs a 275/315 which is a 40 difference from the front and the rear as is the 245/285. But then again I thought that the profile of the tire would have to be adjusted in order to have a synchronized spin between the front and rear..
EBRSKIH is offline   Reply With Quote
      02-11-2012, 02:55 PM   #12
Hunter5179
Hunter5179's Avatar
I got that info off of a tire calculator. You punch in your stock setup then you punch in the tires you want to put on and it gives you the rolling diameter difference. Tire profiles usually do have to be adhusted fron and rear to achieve the best rolling diameter that's why the profile in front is 35 and the rear 30. I can't say if the dealer will agree but the rolling diameter difference is so small that if they did make a stink its only because they want to be dicks. It really wouldn't cause an issue with that setup either 245/35/20 front with a 275 or 285(slightly better)/30/20 rear.
      02-12-2012, 03:37 AM   #13
EBRSKIH
Chef
Drives: F10 550i
Sweet thanks for the info mind sharing the website for the calculator? I just got the car today just waiting for some warmer weather so I can put on the wheels..not a fan of the 245s at all. You running your stock wheels now?
      02-12-2012, 04:15 AM   #14
bimmer man
bimmer man's Avatar
ok. so in us cars have 245 in front and rear? In Norway are 8"x18" 245/45/18" front, and rear 9"x18" 275/40/18" rear standard. and 8,5"x19" 245/40/19" front, and rear 9"x19" 275/35/19" and 8.5"x20 245/35/20 front 9"x20 275/30/20" as option. I vent for 20" for summer and 18" for Winter, I see, 245 in rear givs not a good look???
      02-13-2012, 04:30 PM   #15
Hunter5179
Hunter5179's Avatar
Here is the link of where I did the calculations. http://www.1010tires.com/TireSizeCal...?action=submit Yes im running stock now just waiting for my Forged 1's to arrive.
      02-13-2012, 05:38 PM   #16
Hunter5179
Hunter5179's Avatar
245's squared is fine but for improved handling wider rear tire is better and looks wise much better. Also can put more power down because of the better grip.
      02-14-2012, 09:32 PM   #17
cdogasman
Drives: 2011 550i xdrive M sport
Do you know if the offset on the staggered version in Norway is different as well? Offset on US version with M pkg is 35mm all around (on 19x8.5) yet 550i non xdrive with M pkg has 44mm offset in rear (on 19x9)
cdogasman is offline   Reply With Quote
      02-15-2012, 01:15 PM   #18
bimmer man
bimmer man's Avatar
Hey cdogasman. On all Xdrive f10 we have 44mm offset in rear on 19" and 20". But f11 has 35 mm offset all around (stationwagon)
      02-15-2012, 02:22 PM   #19
remmib
remmib's Avatar
Drives: 2013 F10 520d M-Sport
The front (and rear on the square setup) is ET33, not ET35 for OEM 19" and 20" F10/11 wheels.
F10 520d M-Sport Alpine White | KW V3 Coilover | 3D Design Front Lip | BMW M Performance Black Grills | BMW M Performance CF Spoiler | BMW M Performance Diffuser|
remmib is offline   Norway
      02-15-2012, 02:54 PM   #20
bimmer man
bimmer man's Avatar
0k. sorry.
      02-27-2012, 09:23 AM   #21
Judah
Drives: Black E46 M3 / SpaceGray 650ix
Here's how you get tire diameters:
245/45/18
245 / 25.4 = 9.6457
9.6457 x 0.45 = 4.340
4.340 x 2 = 8.680
8.680 + 18 = 26.68
26.68 is the overall tire diameter
For MPH tire speed based on RPM:
26.69 / 26.00 = 1.0261
1500rpm / 1.0261 = 1461
1461 / 13.211 = 110mph
These are very basic easy to use laymen "equations". Your actual overall tire diameter will vary based on vehicle weight, tire psi and quite a few other variables. For a more accurate RPM to MPH numbers you will need engine speed, transmission gear ratio and differential gear ratio.
I hope this helps..
Judah is offline   Reply With Quote
      02-29-2012, 03:17 PM   #22
EBRSKIH
Chef
Drives: F10 550i
JUDAH. you is the man. thanks a lot.
Forum Jump
