2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions BMS Jack Pad Adapter - Review
      03-23-2012, 10:41 AM   #1
JNoSol
JNoSol's Avatar
Drives: F02 750Li and E70-Sport (N55)
I just received my BMS Jack Pad Adapter. Their website doesn't list the F10 fitment, but the BMS guys said it should fit. The width and length are 1/4" and 1/8" smaller than the F10's jack pad cavity. However, the height is perfect and the circular base doesn't touch the edge of the plastic jack pad (which is good, so you can't tear up the jack pad while jacking the car up). Just wrap the adapter with 1/8" worth of electrical tape if you want a tight fit, otherwise it should work just fine out of the box. BMS says it should be a loose fit anyways.
I used this on my 535i and E70 without any modification (electrical tape mod). It worked perfectly.
This is a made from solid anodized black biillet aluminum and made in the U.S. of A. I highly recommend this product for our F10s, especially with the 3T jack from Harbor Freight tools.
JNoSol is offline   United_States
      03-23-2012, 03:32 PM   #2
gatoman39
gatoman39's Avatar
Drives: 2011 E92 335 M-Sport
How much is this?
gatoman39 is offline   United_States
      03-23-2012, 04:02 PM   #3
KRUZN335
Drives: F10 535
i love this! i picked one of these up after i bought my f10 in 2011...definately something to pick up!
KRUZN335 is offline   Reply With Quote
      03-23-2012, 04:33 PM   #4
JNoSol
JNoSol's Avatar
Originally Posted by gatoman39 View Post
How much is this?
$19 + $7 shipping.
http://burgertuning.com/BMW_jack_pad_adapter.html
      03-23-2012, 04:34 PM   #5
JNoSol
JNoSol's Avatar
BMS says it should be a loose fitment, but did you modified the adapter to make it thicker?
      03-23-2012, 04:41 PM   #6
gatoman39
gatoman39's Avatar
I've just been using this. Seems to work but obviously this is a better fit.
      03-23-2012, 04:47 PM   #7
JNoSol
JNoSol's Avatar
Nice setup. I've seen guys making these with a hockey puck.
With the BMS Jack Pad Adapter, the circular base will not touch the plastic jack pad (about 1/16" gap). This will relieve stress off the edge of the plastic jack pad, which cracked on me w/o this solution.
      03-23-2012, 04:48 PM   #8
gatoman39
gatoman39's Avatar
Originally Posted by JNoSol View Post
Hmm... for a little more money I think I wouldn't mind getting one that fits perfectly and doesn;t need modification....
      03-23-2012, 05:30 PM   #9
JNoSol
JNoSol's Avatar
You don't have to modify it, I just like it snugged. BMS says it's meant to have a little play in fitment. Reverse Logic's seems to be a 2 piece, while BMS is a single block of Billet Aluminum. They both will work just fine.
      03-23-2012, 05:45 PM   #10
gatoman39
gatoman39's Avatar
The color threw me off. I thought the BMS was rubber, didn't realize it was anodized aluminum. Definitely need to get two of these, as I have 2 floor jacks and 2 Bimmers.
      03-23-2012, 07:42 PM   #11
KRUZN335
Drives: F10 535
nope didnt modify it at all...works perfectly for me!
      03-24-2012, 08:02 AM   #12
JNoSol
JNoSol's Avatar
Good to know, I'll try it w/o the electrical tape next time.
      05-06-2012, 09:25 PM   #13
JNoSol
JNoSol's Avatar
By the way, I used this on my 535i and E70 for oil changes without any modification (electrical tape mod, as originally thought). It worked perfectly.
      Yesterday, 11:48 PM   #14
JNoSol
JNoSol's Avatar
This also fits my F02. Great investment.
Tags
adapter, bms, jack pad
Forum Jump
