2010 2011 BMW 5 Series Forum F10 Tire pressure for non runflat |
03-28-2012, 10:28 PM | #1 |
Rep 442
Hi everyone
I just installed Michelin Super Sport on my 535i. Want to know if the tire pressure on runflats and normal tires is the same. I aslo have cl 2008 and all four tires have 29 psi. However, on f10 rear is 38 psi and front 35. So, do you know why there is such difference between cl and f10? Also, what tire pressure do you recommend for rear(275/35/19) and front(245/40/19). |
03-30-2012, 10:56 PM | #3 |
Rep 3,834
My understanding is it doesn't matter what brand/size tires you run, you need to follow the suggested pressure on your driver side door panel.
If you over inflate, the center of the tire will wear more (you should physicially see this). If you under inflate, the outers of the tires will wear more. The door panel suggested the perfect pressure for the weight of your vehicle. |
Tags |
tire pressure |
