2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums EUROPE - CONTINENTAL A tip for new springs !
      04-06-2012, 03:32 AM   #1
gema
Gerrit
Belgium
Drives: 535i f10 tasman
Hello,
I need some advice to lower my car, witch springs to buy for my new 535i f10 the wheels are 20" v-spaak 356 liquid black..........;
thanks in advance Gerrit
      10-18-2013, 06:41 AM   #2
Fre_535Xd_F11
Drives: Bmw f11 535d X drive
Originally Posted by gema View Post
Hello,
You could buy a H&R set of springs wich lowers the car with approx. 35mm/25mm.
Or you could buy a set of AC schnitzer springs, price is more expensive and only 25mm drop.
Also a lot of other brands available but you must look for one with GOCA papers, otherwise you will get in troubles with the car control....
Grts
Frederick
      01-07-2016, 06:49 PM   #3
Diesel Flash
The Flasher
Diesel Flash's Avatar
Drives: F11 520d M sport
2008 320d  [0.00]
i run 20" with h&r sport springs, would definately recommend them. they tightened up the handling so much and now the car does not wallow like a boat going around corners.
Due to you having the 3.5L, a slightly heavier engine than mine the drop should be just right, mine to be honest is just a little bit to high for me on the front, but apparently as i said the bigger engines can sit up to 1cm lower!
Go for H&r, Eibach sportline is to much of a drop in my opinion and prokit not enough.
hope this helps
BMW F11 520d M-Sport, Stage2 Remap, Sophisto Grau, Oyster leather, Pro Nav, 20" M5 reps, H&R Sport Springs, Vorsteiner Rep Front&Rear Carbon valance, Quad exhaust Conversion, M5 Grill, Focal Audio
      01-23-2016, 12:51 AM   #4
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
Eibach
