2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications E-Sys on Usenet?
      04-11-2012, 06:46 PM   #1
ImSW1
Drives: F10
Here's links to E-Sys on usenet and Rapidshare. I can't guarantee how long the link on Rapidshare will last, so get it while you can.
The program works and I've been successful in coding auto fold mirrors, trunk close from inside button and key fob, and auto close of windows and sunroof with key fob. You can also unlock DVD in motion and turn off many of the notifications (i.e seat belt chime etc.)
You'll need to build an interface cable (OBD to ethernet), or buy one on eBay when they become available. Overall better than paying someone to code your vehicle. Read the .nfo for more information. PM me if you need any help getting a cable built. I also have some "how-to program" using E-sys pdf's if anyone needs them.
Rapidshare:
The Rapidshare links have been removed thanks to our fellow enthusiasts in the BMW community. Oh well.
Usenet:
http://nzbmatrix.com/nzb-details.php?id=1242599&hit=1
Sean
      04-12-2012, 10:22 AM   #2
DentalBoy
DentalBoy's Avatar
36
Drives: 2016 M6 Gran Coupe
WTF U TALKIN BOUT
_____________________________________________
2016 M6 GC under construction,2013 F10 M5 Akrapovic(sold)
2012 F10 AW 550i MSPORT,Vossen CV3s,ACS Springs,Meisterschaft GTC,.Totalled!
E60 M5 Dinan stg3,hiflow throttle bodies,coldair,evosport rear diff,Eisenmann Race sold
E39 M5 UUC short shift,UUC Corsa and More Sold
      04-12-2012, 12:07 PM   #3
ImSW1
Drives: F10
E-Sys
Good question. Should have started out with that...I guess.
E-Sys is the program that is used to reprogram the modules in the F-series vehicles. In other words, if you want to program your mirrors to fold when you hold your remote button, or close the trunk with the key fob you do it using e-sys and a specialized cable (ethernet to OBDII).
This is the first sighting of the program and activation tools to get communication with the car.
Sean
      04-21-2012, 05:21 PM   #4
ImSW1
Drives: F10
Just updated the original post.
      04-22-2012, 09:52 AM   #5
RumbleJay
RumbleJay's Avatar
13
Drives: 2011 BMW f10 550i M
Just PM you.
      04-22-2012, 03:04 PM   #6
ImSW1
Drives: F10
Easy Cable Build Instructions
I wanted to post some easier to follow cable instructions for those that don't read schematics. My hope is more people will attempt to code their own cars. The only cable I've seen out on ebay is $50.00 and that's ridiculous. It will cost you about $10 to $15 if you have basic soldering skills and order the parts. You could also just buy a standard ethernet patch cable and cut one end off and solder the open ends to the OBD2 connector.
Sean
      04-22-2012, 04:20 PM   #7
volfman
Drives: F10 550i 6MT
Is E-Sys self explanatory to use, or is there a manual for it?
      04-22-2012, 05:04 PM   #8
ImSW1
Drives: F10
It's actually pretty easy to use once you've used it once or twice. The instructions are out there.
You can find them by searching for "E-Ssys - Getting_Started-Coding.pdf" without quotes in google. This search will take you to a russian website. Use google chrome to translate then signup and download the files.
I can't post the url to the site (Bimmerpost won't allow it) that the "how-to's" came from but credit to Modular93fox and the other users that created the documents so others could learn.
Sean ‎
      04-22-2012, 06:53 PM   #9
mikessc
Drives: 2006 E60
IMSW1,
Thank You Very Very Much.
You are the best.
      04-22-2012, 08:57 PM   #10
commaps188
Drives: 335i
i found this info after this post. I hope it helps
http://bmwcoders.com/forum/bmw-isis-...6/bmw-e-sys-6/
      04-24-2012, 02:20 PM   #11
volfman
Sean ‎
Worked great. Helps that I'm Russian :P
      04-25-2012, 09:49 AM   #12
scoobdawg
Drives: f10
Thanks everyone! I just ordered my car this past weekend - wont be in for 6 weeks but figured I'd start prepping... Screwed up and bought the ODB cable for the older cars so I'm down $100 so far...
Since this is all new to me - I'm really lousy with a Solder is there anywhere to buy the ethernet to odb cable yet?
Also I'm searching for "E-Ssys - Geting_Started-Coding.pdf" on google and nothings coming up... Any help would be appreciated!
      04-25-2012, 10:10 AM   #13
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
If you Google "bmw enet cable" you will find sellers, e.g.:
BMW F-series ENET cable (required for BMW F01, F02, F10 remote coding services)
http://www.codecard.lt/electronics/t.../prod_651.html
Attached is the E-Sys - Getting Started: Coding.pdf. The document password (PW) is at the end of the file name.
File Type: pdf E-Ssys - Getting_Started-Coding - PW is **************.pdf (1.51 MB, 2046 views)
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
      04-25-2012, 10:16 AM   #14
scoobdawg
Drives: f10
Thank you very much!
      04-25-2012, 02:06 PM   #15
scoobdawg
Drives: f10
Having spent all morning reading and getting the appropriate tools installed - How do you know what code to change for the DVD in Motion or the automatic mirrors? Is there a master list somewhere or do you have to get lucky?? I looked on BMWcoders.com as well... maybe I'm just dense?
Thanks again - Not easy being the newbie..
      04-25-2012, 02:12 PM   #16
shawnsheridan
Start here:
http://www.**************/showwiki.p...Coding+Options
The masked website is the same as the document Password above.
      06-13-2012, 04:07 PM   #17
norinred
Drives: 2009 BMW 750LI
Do you still have cables available?
      06-16-2012, 11:24 PM   #18
siahyong
Drives: F10
Hi, can anyone share the location to download all the psdzdata files? Apparently, it seems that the files is no longer in Rapidshare. Thanks in advance for the helps.
Cheers!
      06-16-2012, 11:32 PM   #19
shawnsheridan
Cheers!
The RapidShare Links here are working still:
http://www.bimmerfest.com/forums/sho...08&postcount=1
      06-21-2012, 09:45 PM   #20
siahyong
Drives: F10
Thank you and appreciated.. It seems that my current IP address does not allow me to access to the files. I had tried another network and it is working.
      09-05-2012, 01:58 AM   #21
Roubs
Drives: 3srs
E-Sys
ImSW1 I am trying to get in contact with you. I cannot PM you since I am new here. How would I be able to reach you
Roubs
      09-05-2012, 05:06 AM   #22
shawnsheridan
Roubs
ImSW1 has been out of pocket for a while. What is it you need? A Cable?
