2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes 10.5 width Wheels with 285 michelin tires.
      04-25-2012, 02:35 PM   #1
Hunter5179
Hunter5179's Avatar
Drives: 2013 M6 Coupe
Does anyone have any pics of 10.5 width wheels and 285 michelin tires or any other tire? I want to know if a 285 tire will look flush with a 10.5 wide wheel.
2013 M6 Coupe SG, VSE 003's 21, Akropovic Evo Carbon, KW V3, AMS DP's, Vorsteiner Full Aero, Gruppe M Intake, Bel Stir Plus & V1 with HP Laser Interceptors, P3Cars Gauges, JL 2X12W6Subs, 35%tints.
My Thread:
http://www.6post.com/forums/showthread.php?t=794659
      04-25-2012, 02:39 PM   #2
LACSTER
Drives: Hybrid
285 on a 10 is flush. If you plan on getting that it will have a little stretch.
Here's forum member mgcyr's VS8.2 with that setup.
      04-25-2012, 02:56 PM   #3
Hunter5179
Hunter5179's Avatar
So if I go 295 rears on an xdrive dropped on ACS with a 40 offset what size profile should I get in the back with what size tires in front on a 9 inch wide wheel?
My Thread:
      04-25-2012, 03:59 PM   #4
Alan l.
Alan l.'s Avatar
1669
Drives: 2016 F85M
I wasn't able to find a right tires size up front to go with 295 rears. This is the issue with having a xdrive car.
for RWD cars the overall diameter doesn't matter as much as i've seen people run 255 up front with 285 rears etc.... but that might freak out the xdrive system since the overall diameter of both sizes are different.
If you plan on running 285 michelin, i would stick with a 10" wide wheel if you don't want stretch.
      04-25-2012, 07:19 PM   #5
Hunter5179
Hunter5179's Avatar
Thanks guys..Problem solved staying with 10inch wheel.
My Thread:
      04-25-2012, 10:26 PM   #6
1badbimmer
Drives: 2011 alpine 535i
2011 BMW 535i  [0.00]
Go to 1010 tires they have a tire calculator it really helps tells you all you need 285/35/20 and 255/40/20 is almost perfect that's what aim going with
      04-25-2012, 11:25 PM   #7
BigMikeTwn
Drives: BMW 523i F10
But if you go with 285/35/20 and 255/40/20, wouldn't that rub if you're lowered on Eibach/ACS springs?
      04-26-2012, 12:18 AM   #8
Hunter5179
Hunter5179's Avatar
Yeah, I wouldn't do that setup. Best is 245/35/20 front and 285/30/20 rear. Offsets are also a factor in rubbing.
My Thread:
      04-29-2012, 09:51 PM   #9
Flex33
Drives: 2011 BMW 535I
You guys are wrong I have a 2011 BMW gt535 xi I am running 22 by 9 in the front with 245/30/22 tires and 22 by 10.5 rear with 295/25/22 no issues at all with the x drive wheels fit flush no rubbing in rear or front
      04-29-2012, 10:08 PM   #10
e46revspeed
e46revspeed's Avatar
73
Drives: F06 & E89
here's a 10.5 et45 with 285/30/20
Squattin on Megan Racing and Vertini Monaco
      05-01-2012, 12:35 AM   #11
Hunter5179
Hunter5179's Avatar
post some pics!
My Thread:
      05-03-2012, 04:31 PM   #12
Flex33
Originally Posted by Hunter5179 View Post
post some pics!
i did go to the forum page and click on 2011 gt535i on 22's ,still searching for a suspension to drop the shit out of it
