2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Watch the 2012 528i Turbo 4 (N20) Take on Its Older 6 Cylinder on the Road and Dyno
      04-27-2012, 10:37 AM   #45
speedfan
speedfan's Avatar
Vietnam
86
Originally Posted by 宝马.e90 View Post
I understand fuel efficiency but can a 4-cyl really be that much quicker than an I6 given that everything else remains about the same? That's pretty cool/interesting.
Kudos to BMW for building such a fantastic 4-cyl engine.
great point.
The power of N20 turbo is underrated by A LOT.
It pumps out much higher hp & torque comparing to the I6.
I'm very curious to know what's gonna happen if 2 engines put out the same hp at the crank. will there be any significant difference other than fuel efficiency?
My e90
Frozen Grey. Dry CF Roof. Vorsteiner Double Sided CF Boot Lid. OSS. BMW Performance Aero Kit. BMW Performance CF Diffuser Cover. BMW Performance CF Trim. Robson Design Steering Wheel. Advan RS. Michelin PSS. H&R Touring Cup Kit. BMW Performance Brakes. Eisenmann Race Rear Muffler. ESS Directflash
      04-27-2012, 11:14 AM   #46
benzo23
benzo23's Avatar
47
Drives: 14 F30 AW MSport
Originally Posted by The X Men View Post
I agree, a 4 cyl. $50000 car is not for everyone, me included. Unfortunately, cars in the future have to be more efficient and we all know Americans like super sized cars like their super sized fast food My opinion is that, if I were to buy a 4 cyl. car, its would not be a $50000 BMW. I would just settle for a Honda or something like that. If I were to buy a BMW, I want it to be fast and smooth.
I agree 100%, decent options puts me at 55k for a 12' 528. You mean to tell me im going to spend that much for a car with leather and a 2.0L 4cyl? No thanks. I dont care if it has more "power" than the old I6. It sounds like a diesel at idle. Like I said for that money or less i would rather find a left over 535, or a 2012 335is thats loaded. But hey to each there own.
      04-27-2012, 11:31 AM   #47
LiveLarger
Norway
Drives: F11 520d M-sport
Originally Posted by benzo23 View Post
You're absolutely right, weight has nothing to do with a cars performance. My mistake. A 4000 lb car should have a 4cyl in it.
It's irrelevant when comparing power output of a engine. The performance is related to what power the engine can deliver. Not the amount of cylinders. 245 horse power is well, just more then 208. It would not matter if you had 6, 8 or 12 cylinders if the engine delivers less HP and torque.
Why is this hard to understand?
      04-27-2012, 11:50 AM   #48
benzo23
benzo23's Avatar
47
Thank you so much for clearing all of that up for me, I dont know what I was possibly thinking. My horrible mistake, I understand now that I wont be buying one either way.
      04-27-2012, 12:24 PM   #49
The X Men
Drives: 2013 X3 35i
Hmmm, what ever happened to the horsepower vs weight ratio?
      04-27-2012, 01:02 PM   #50
LiveLarger
Norway
exactly
      04-27-2012, 01:09 PM   #51
MSPORTWORLD
MSPORTWORLD's Avatar
Drives: '11 M3 MW/FR - '12 M3 FO/SC
Good video...informative, short, sweet and to the point.
      04-27-2012, 02:53 PM   #52
Frosty
Frosty's Avatar
46
Drives: Ordered my E92 (7/10/06)
Originally Posted by e92_m3 View Post
In a drag race stock vs stock the turbo 4-cyl will win every single time over the NA 6-cyl.
In a proper race stock vs stock on a track, I'm pretty sure it will be a very close race considering the only difference between the two cars is the torque. However with a torque of 260 vs 230, the 2012 528i may be coming out of a corner a little faster than the 6 cyl.
Although the 2012 528i has more torque, it may all come down to the driver when it comes to a stock vs stock race on a track.
.....for what its worth I have nearly 130,000 miles on my N54 ~Frost
335i Coupe (6MT) (2007: 9/06 build, pre ordered, only owner): Space Grey / Black Leatherette / Grey Poplar trim / ZCW / ZSP / BMW assist w/ bluetooth / power rear shade / navi with iDrive / comfort access keyless entry /+homelink mirror/ 206,000+miles SOLD (AUG 2016)
      04-27-2012, 04:10 PM   #53
kavehm
Drives: e90
2006 E90 330xi  [0.00]
"In a proper race stock vs stock on a track, I'm pretty sure it will be a very close race considering the only difference between the two cars is the torque. However with a torque of 260 vs 230, the 2012 528i may be coming out of a corner a little faster than the 6 cyl."
Keep in mind the number of times you'll be able to go around the track without high-temperature related issues, for a short spurt surely the turbo-4, but for a longer race i'd put my money on I6 (or any NA engine) any day.
      04-27-2012, 04:39 PM   #54
bradleyland
TIM YOYO
Drives: 2013 M3
I didn't see the distance of the sprint, any one know what it was? If it was short, the N20 is going to have the advantage like you said but how would the N52 compare in a proper race? That's what I would like to see but still, the 4-cyl N20 is a great engine.
The N20 generates more power across the range, and is 22 lbs lighter than the N52. If you took the same exact car and swapped between the N52 and N20, the N20 is going to win every performance category, with maybe the exception of endurance.
Originally Posted by Yallmb View Post
So, I4 was quicker than the I6, I'm cool with that because the factory says that the I4 has 30lb-ft more torque than the I6. However, what's up with the HP ratings? The factory rated them both at 240 HP but the I6 only put out 208 HP at the crank on this particular dyno. Not really liking that. They should both be putting out at least 240 HP at the crank.
Nope, the previous F10 528i used the N52B30 I6 that put out 240 hp and 230 lb·ft in US trim. Now, if they had said the hp output at the wheels was 208 I would have said "OK, driveline loss" but they actually said that it was 208 hp at the crank which should be 240. So, yeah, I think that they either screwed up the numbers as you said or there is something going on with that dyno or something wrong with the car.
A wheel dyno can't tell you crank HP. You can estimate crank HP, but unless you pull the engine and hook it up to a dyno, you won't know. A wheel dyno is only good for relative comparison. I wish they would have just published the numbers output by the dyno, rather than try to do the math.
His: 2013 ///M3 - Interlagos Blue Black M-DCT
Hers: 2013 X3 28i - N20 Mineral Silver / Sand Beige / Premium, Tech
Past: 2010 135i - TiAg Coral Red 6MT ///M-Sport
      04-27-2012, 04:40 PM   #55
absolutezero
Drives: BMW 328i
Originally Posted by ron_jeremy View Post
Well, regarding reliability,the turbo's is a part which breaks down within 130-180.000 km.
Which means within 6 years or so it/they need to be replaced.
It's not cheap, especially the modern turbo's.
What might be worse is when these breaks down, and you drive with it, the Hole engine can be destroyed!
So surely the NA 6 is more durable in the long run, but with these bullshit clima regulations, turbo's and downsizing is a must, sadly!
Can you show data that supports that a significant number of today's turbos will need replaced within that time/distance?
      04-27-2012, 04:42 PM   #56
absolutezero
Drives: BMW 328i
Exactly.
I can understand if someone likes the "smooth" I6 (I love mine), but from a strictly perf perspective, the 4 is the winner. Less weight, more power, oh and on top of that better gas mileage...
      04-27-2012, 04:50 PM   #57
bradleyland
TIM YOYO
Drives: 2013 M3
Regarding torque vs horsepower, keep a couple of things in mind.
Torque is a measure of force. I can generate 240 lb ft of torque with a torque wrench. Imagine you attach a wrench to the drive line of a 5-series. I can generate 240 lb ft of torque, but what do you think my 0-60 time would be? I can answer that for you: I'll be dead before I get that car to 60 MPH!
So if you want to know how well an engine will perform in your car, you don't just care about torque. The correct question to ask is, how many revolutions per second can I produce at 240 lb ft of force?
Horsepower is the answer to that question. The formula for HP is
t(r)/5252
Where t is torque and r is RPM. So torque times RPM, divided by 5252.
So back to the original quandary. You're all staring at me asking, "Ok smart guy, if it's not the torque that explains why the N20 is faster, wtf is it?"
To say the N52 or N20 generates 240 HP at the crank is a pretty shallow insight, because that's peak HP. Care to venture a guess how long the engine spends at peak HP during an acceleration run? It's a really small fraction of the time.
More relevant is the question of HP curve over the RPM range. Turbo engines have a huge torque swell early in their RPM range. Compare the HP generated by the N20 at 2500 RPM vs the N52 at 2500 RPM and you'll begin to see why the N20 performs so well. The N20 accelerates the car faster, earlier because it's generating more force (torque!) earlier in the RPM range (horsepower!).
      04-27-2012, 04:55 PM   #58
bradleyland
TIM YOYO
Drives: 2013 M3
No one has any long term reliability data on modern turbos because, well, they're modern! They haven't been around long enough to know.
I think it's a pretty safe assumption to say that a naturally aspirated engine should (statistically speaking) outlast a comparably engineered turbo engine. Turbochargers live a very hot and abusive life. They push the boundaries of material science. It's not unreasonable to say that they'll suffer failure before a naturally aspirated engine that is inherently simpler.
EDIT: That said, I'll take the surging rush of a turbo car over N/A any day of the week. I'm addicted to FI!
      04-27-2012, 05:19 PM   #59
somonster
Drives: honda, bmw
Originally Posted by Greenkirby21 View Post
a street racing video by a dealership is being featured on bimmerpost?
that is SHAMEFUL.
this dealer should be sanctioned by BMW, they have the nerve to film themselves ABUSING their PRE-DELIVERY cars.
jerks.
and BTW, how do they measure "at the crank" hp? anyone help me out here? (thanks)
      04-27-2012, 08:53 PM   #60
Hill Country Driver
Hill Country Driver's Avatar
Drives: 2016 Shelby GT350
t(r)/5252
Very well said.
2016 GT350
2015 F80 M3
2013 F10 550i MSport
2011 E92 M3
2008 E92 335i
      04-28-2012, 04:37 AM   #61
boostaholic786
boostaholic786's Avatar
24
Drives: E92 N54 with MHD Custom flash
Talking
Originally Posted by somonster View Post
that is SHAMEFUL.
jerks.
haha Thats really funny you just wrote that. This dealer did a favor for you and obviously everybody else on bimmerpost since it was the cover of the front page on bimmerpost. So obviously it holds some weight in the community for them to put it on the very front page. What they are trying to show you is that this 4 cyl turbo motor can outperform the previous one in every way including horsepower, weight, FUEL ECONOMY, performance, ect... BMW has mastered the engineering of there turbo motors to really make them very durable and efficient. The technology that BMW has today is probably 5-10 years ahead of its time. The reason that they perfected the turbo technology is because very soon and I mean very soon, cars will have more restrictions on engine sizes and liter displacement. In the near future all cars are going to be electric or hybrid of some sort. It big time sucks but hey, the government can do what they want to do. and yes I would by a $50000 dollar car with all the amenities that a even base 528 has. I would by it for the way it handles and sounds. I would buy it because its a quality product and is faster than the previous I6 engine that was in it.. Numbers dont lie, neither do motortrend or car and driver. If your wanting a luxurious sedan that get incredible gas mileage and is actually fun to drive, then this would be the car. One of the above post said "if im going to get a 4 cyl i would rather get a honda lol. Have fun with the plastic and fake vinyl or whatever they use for the dash haha. Nothing has changed her except the new 528 just got even better and thats all they were trying to show which is exactly what they did. Go drive one then come comment back if it ANYTHING like a 4 cyl and back and post your results. like I said BMW is on top of turbo game and has damn nearly perfected it. Oh and also, DINAN for instance sell tunes/software for BMW's and with the new 4 cyl motor Steve Dinan stated that there is ALOT of room to make A LOT more power I bet with the DINAN stage 1 tune will give us almost 60-70 whp where as the 2011 I6 DINAN software gives you i think maybe 9 horsepower and the stage 2 software that is like 1500 bucks will give you 13 horsepower .Its going to be one fun engine from what I hear The only thing think they should have done differently is not try and calculate crank horsepower and just give us the real dyno numbers.
      04-28-2012, 07:46 AM   #62
blueridger
Drives: 2011 335i
Exactly.
All true. The 4-cyl is a real performer. The car feels more nimble, but the sound is just not what I'm after. I would have a hard time adjusting to it.
      04-28-2012, 08:57 AM   #63
Audionut
Drives: 335xi
I was in the camp too which believed that a 4 cyl does not belong in a 5. But after I got a 528 loaner when my 335 6mt was in the shop I became a believer. I just ordered a lightly optioned 528 which was sold at invoice; add the $1500 credit, Edmunds $1500 rebate, BMWCCA $1000 rebate, and the car was closer to mid 40ks. Does it sound like an I6? No, but the car is so well insulated that you'd have to drive with the windows opened to appreciate the sounds under the hood from the 535. I just hope they don't start putting M5's and M6's in the loaner pool
      04-28-2012, 03:50 PM   #64
Gator335i
Gator335i's Avatar
10
Drives: E38 E39 E60 E70 E92
I think the answer to the sound issue of the 4-cylinder engine is for BMW to engineer an exhaust system that can mimic the sound of a 6 or even 8-cylinder engine.
I'm wondering what this 4-cylinder would sound like if you put a BMW Performance Exhaust on it.
      04-28-2012, 08:46 PM   #65
996911
Drives: DSB X5 2012
Originally Posted by bavarian19
Originally Posted by jaehshim View Post
it's funny how ppl look at it one dimension about these mechanics and be so amazed about it...
4cylinder turbo vs inline v6 that lasted part 20~30 yrs of BMW history.
Good power
Goof efficiency
They will last a good 4 yrs, what about reliability of those turbos afterwards?
what about the longetivity of those 4 cylinder turbo engines compared to inline 6 bmws?
Especially living in the US where people usually drive more than 12,000 miles a year in all types of terrain, can we really say 4 cylinder turbo is the way to go than a bigger more stable inline 6?
i dunno why but somehow looking at virtually all bimmer lines being turboed now... this looks like a sweet candy "rental car" that will last a good 4 yr and be gone....instead of the good old inline 6 silky smooth reliable engine....they will be missed...
Turbo's staying around for only 4 years? I think not. Based on that logic, the 335 powerplant should have been dead for a few years already.
Change is difficult sometimes. I personally would like the turbo 4 instead of my NA I6. More torque would make it more fun.
Exactly people talk like turbo cars are a new thing. What about all the other turbo smooth power delivering cars out there. I for one low my 2012 35 X5.
      04-29-2012, 11:57 AM   #66
bradleyland
TIM YOYO
Drives: 2013 M3
Exhaust system design can only do so much. Ultimately, the firing order and number of cylinders determines the harmonics that give each cylinder layout its unique tone. If you put BMW Performance Exhaust on the N20, it's still going to sound like a 4-cylinder.
That said, a 4-cylinder doesn't have to sound like a riced out Honda. Have a listen to the E30 M3 for a great example of a kick ass four banger exhaust note.
Tags
5 series f10, 5 series f10 forum, 5-series f10, 5-series f10 forum, 528i f10, 528i n20, bmw 5 series f10, bmw 5-series f10, bmw f10 5 series, bmw f10 5-series, bmw f10 forum, bmw f10 forums, f10 5 series, f10 5 series forum, f10 5 series forums, f10 5-series, f10 5-series forum, f10 5-series forums, f10 528i, f10 forum, f10 forums, f10 n20, n20 528i
