Bimmerpost for iPhone and Android have just been updated with a host of bug fixes. If you've ever had trouble logging into it in the past, give it a try now!
2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Lowering springs 0,4-0,8"
      07-09-2012, 06:59 AM   #1
jande25670
Catalan
jande25670's Avatar
Drives: 520d F10
Anybody knows if there are some springs that lows the car only between 0,4-0,8 in (1-2 cm).
Thanks.
      07-09-2012, 09:04 AM   #2
Alan l.
Alan l.'s Avatar
1179
Drives: 2016 F85M
ACS lowers the car 1". I think Dinan springs lowers the car even less than that. Any less its not even worth doing since even 1" is already very subtle.
Alan
      07-09-2012, 09:24 AM   #3
Vinfast
Drives: '14 550i M-Sport
ACS lowered my 550i much more that 1", so my next lowering springs will be Dinan since I think that will be perfect. I've had H&Rs, RDs, and ACS, and they all underestimate their drop rate -- H&R being the worst.
      07-09-2012, 09:26 AM   #4
dblock2151
Drives: '11 550i Msport DG
I have a H&R sport springs on my 550i, and wish they made a race set. My front is the perfect drop while my rear has .5"-.75" of gap that I wish wasn't there.
I wish they made coilovers for the DHP suspension.
      07-09-2012, 11:44 AM   #5
pyramid
Indonesia
Drives: Serpent S966
Various Various  [0.00]
Thanks.
2 ways,
If just the spring, your only choice is BMW oem mtech springs, lowered by 10mm front and back. Don't know how it feels with original struts as it meant for mtech (msport) struts.
Else, you need to go for kw suspension set. With kw v3, I managed to get my front lowered by 20mm, rear at 10mm. I believe you could go even higher (less drop) with kw comfort suspension set.
      07-09-2012, 04:19 PM   #6
Stealth7
Drives: 2012 BMW 550i M Sport
So far, I think the ACS drop and ride is perfect on my 2012 550i M-Sport. There is still a wheel/fender gap front and rear so the car does not look ghetto/slammed.
Also, note that the improvement in handling by adding springs (flatter cornering, more connected, not floaty, sloppy and loose like stock) is due to: (a) stiffer springs; and (b) lower ride height and lower center of gravity. So you might want to keep your goals in mind when and if you make any changes in the springs.
      07-09-2012, 10:31 PM   #7
saeba1
saeba1's Avatar
Drives: 2015 F82 M4 DCT
On a 528i xdrive, ACS lowers it only by 3/4" at most. It is a bit more on the 550. You can check out my build thread for the 528i (the last few pics).
It does improve ride and handling greatly.
2015 F82 /// M4 DCT - BBS FI-R | Macht Schnell EVC | Eisenmann Performance | RKP GTS Lip | RKP Diffuser | IND Cosmetic Package | CF Seats Cover
2012 F10 528i xDrive - BC Forged HB05S | Meisterschaft GTC | 3D Front Lip | Vorsteiner Diffuser | MP Mirror Covers and Spoiler | ACS Springs
