2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes M3 competition wheels on f10
      08-13-2012, 01:32 PM   #1
shinsengjun
Drives: 528i carbon black m sport
will oem m3 competition wheels fit on my m sort f10??
shinsengjun is offline
      08-13-2012, 02:38 PM   #2
snj1013
Drives: 2011 528i
Do you know the specs of the wheels or BMW's Style number?
snj1013 is offline   Reply With Quote
      08-13-2012, 03:26 PM   #3
bobblehead
bobblehead's Avatar
Drives: warp speed
359M
Front alloy wheels: 19x9" ET31
Rear alloy wheels: 19x10" ET25
bobblehead is offline   Canada
      08-13-2012, 06:44 PM   #4
shinsengjun
will they? cause i dont want some cheap replica
i wonder what they would look like
shinsengjun is offline   Reply With Quote
      08-13-2012, 07:58 PM   #5
bobblehead
bobblehead's Avatar
Drives: warp speed
Not sure exactly what' your stock config right now.
Assuming you currently have square setup which is:
F: 18 * 8 et 30
R: 18 * 8 et 30
Then those 359M wheel will give you the following:
F: -14mm clearance from strut / +12mm extension outward
R: -20mm clearance from strut / +30 mm extension outward
Opinion: Not recommended and should not be done
If you have staggered setup on your stock ride right now which is:
F: 18 * 8 et 30
R: 18 * 9 et 44
R: +6mm clearance from strut / +32 mm extension outward
Opinion: Same as above. Look for something else. The rear wheel has aggressive offset and designed for M3 car more so. It's either too close to the strut or way too far outward that is going to rub the fender.
      08-13-2012, 08:11 PM   #6
bobblehead
bobblehead's Avatar
Drives: warp speed
http://www.m3post.com/forums/showthread.php?t=380043
Here is a sample of pics.
      08-14-2012, 12:59 PM   #7
shinsengjun
thank you sir may i ask you one more question
this person is selling quad set that was custom made muffler and the carbon fiber diffuser for 500
i was thinking about buying it but, he has 2011 528 model and i have 528 2012 model which has a different inline 4 turbo engine.
if i do but this will it fit ? let me give you the link to the post
      08-14-2012, 01:02 PM   #8
shinsengjun
http://f10.5post.com/forums/showthread.php?t=728953
      08-14-2012, 04:53 PM   #9
bobblehead
bobblehead's Avatar
Drives: warp speed
$500 for the quad exhaust + cf rear diffuser ?
Sounds cheap.
One advise is aftermarket exhaust (95%) out there will have some sort of drone noises, if you are the type of guy that like loud noises, then they may fit your liking. My suggestion is for you to sit in his car and drive both local & highway to listen if that's the sound you like. I am aware of the different engine involved but it does give you a general idea how loud the exhaust is.
      08-15-2012, 12:05 AM   #10
shinsengjun
i think he has its taken out already ):
he told me to come pick it up cause i live locally
i dont know what to do
      08-15-2012, 01:11 AM   #11
shinsengjun
oh and what is drone noise
      08-15-2012, 05:59 AM   #12
bobblehead
bobblehead's Avatar
Drives: warp speed
low frequency 'rumble' noise happening around 1500 - 2500 rpm range that you can hear inside the car cabin.
To some, it can be annoying or head pounding. To a few, they love the drone noise.
Forum Jump
