08-13-2012, 08:03 PM | #1 |
Rep 432
Drives: F10 535i M-sport
F10 Stage 2 PROBLEM
installed the n55 stage 2 today. The car ran great. Pulled really hard and loved the result.
The issue came after I turned the car off and went back to it 15 minutes later to turn it on. Once I turned it on the start up was rough and I got a drive train malfunction. Has anyone heard of this issue. And does anyone know what to do. I emailed terry and asked if I can just uninstall the tune but I have a catless downpipe. |
08-13-2012, 08:51 PM | #2 |
Rep 8,805
I would check to make sure all the connections are still tight. Especially the wires you have to splice into for CANBUS access. Also look at the positive/negative connection to be sure they have a solid clean connection.
Did you also make sure you have the F10 specific firmware? I remember Terry said when you order the jb4 upgrade to make sure you email him to let him know its for a F10. Alan
08-13-2012, 09:03 PM | #3 | |
Rep 432
08-13-2012, 11:19 PM | #5 |
Rep 432
Problem solved. CANBUS wires weren't punctured enough. Make sure you cut back some of the wire cover to ensure a good connection. My catless dp CEL is off now too and all the old codes have been automatically cleared. So far I'm very happy
08-13-2012, 11:26 PM | #6 |
Rep 206
so i have a couple of q's for you bb2405... it sounded like the install was not as easy as stage 1? and did you notice a big difference between stage 1 and 2 as in worth the extra money? I'm also not crazy about spicing some of the original wires, I wounder if Terry will come up with an easier retrofit wiring?
08-14-2012, 12:18 AM | #7 | |
Rep 432
08-14-2012, 12:21 PM | #10 | |
Rep 432
