Bimmerpost for iPhone and Android have just been updated with a host of bug fixes. If you've ever had trouble logging into it in the past, give it a try now!
2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Freshly lowered (Pics)
      09-11-2012, 09:04 AM   #23
jftoha
jftoha's Avatar
18
Drives: 2012 X5 M Sport /2011 535is
Originally Posted by Bulldog CFP View Post
I do not see a reference, on your reply, where you purchased them from.
I apologize, clearly I did not post it :S
Well, here it is.
http://www.cecwheels.com
José Tohá ---------------------------------Chilean Architect, Living in Washington, DC.
PRESENT: F10 535I Sport, Alpina 21" wheels, AC Schnitzer springs, M5 Grill.
PAST: E63, E39 (2), E34 (2), E36, E24, E30 (2)
      09-11-2012, 09:10 AM   #24
jftoha
jftoha's Avatar
18
Originally Posted by dblock2151 View Post
What are the offsets on those Alpina's?
They are the offsets of the & Series Alpina B7. They are in the agressive side of things but do not rub in any way and do not come out of the fender at all, they are pretty flush. I am very happy with the fit.n Here are the offsets.
Front: 25mm
Rear: 41mm
      09-11-2012, 08:51 PM   #25
dblock2151
Drives: '11 550i Msport DG
I have some Alpina 21" classics from the older 7 series sitting here and just wanted to see if it would be possible.
The sizes are 21x9.5 et23F and 21x10.5 et28R
I tried the rears on before lowering and they bolted up and stuck out just a tad (hoping the camber from lowering will push them in a little) and the fronts wouldn't fit on the hub, the caliper was hitting the spokes.
      09-11-2012, 10:48 PM   #26
jftoha
jftoha's Avatar
18
Yep, when I was doing research to see if I could fit the Alpina wheels, I read of a member of the board that tried it too and it did not work with the wheels of the previous B7. Sorry. I am sure you can sell those for good money and get the new Alpina design. I actually like the old design quite a bit too and had them in my old E24 635csi.
      09-12-2012, 05:22 AM   #27
Chu2k
Paraguay
9
Drives: F10 535i, X1 xDrive20d
That looks awesome and soooo classy! Great job! I cant believe it ended up being juuust right with the ACS.
In your case I wouldnt bother to get the M-Sport front. It looks very classy with the OEM.
What tire spec?
      09-13-2012, 03:01 PM   #28
Andy H.
Andy H.'s Avatar
41
Drives: 2012 535i M Sport
Well, here it is.
Thank you!
      02-26-2013, 10:06 PM   #29
NCEC
Drives: F10
This is not the first time I look at your setup, i love how classy it looks with those Alpina! I can't help myself to get a set of those for my F10. I know the recommend tire size is 245/35 and 285/30. Do you know if it can go 255/30 and 295/25? Or any other size? Want to give a bit more meat to protect the rims! It took me almost two months to find the set and ship all the way from US to Hong Kong
      02-27-2013, 12:22 AM   #30
jftoha
jftoha's Avatar
18
Actually, the combination you mention give you less "meat" than the one I suggested. The height of the lip of the tire relates to the numbers you ported. The second number is the percentage of the first number that results in the height of the tire. As an example a 245(mm)/35(%) tire results in a lip height of 85.75mm. The one you propose, a 255(mm)/30(%) results in a lip height of 76.5mm. The taller the height, the more protection you have in the wheel and the better ride you get. Performace is better with a lower lip but there is apoint where the lower ratios give you worse performance. I think at this point we are passed the ideal lip height for performance. I don't think there is many racing cars, if any, that run 25 section tires.
I hope that helps.
      02-27-2013, 04:12 AM   #31
NCEC
Drives: F10
Thanks a lot! Appreciate that
      05-07-2013, 02:09 AM   #32
Dwn2Race
Drives: 2002 330ci
Any updates photos? Also do you think his tire size selection will having any rubbing issues on 255-30 and 295-25? Very clean F10!
      05-07-2013, 02:23 AM   #33
sexy_ninja_goat
sexy_ninja_goat's Avatar
Drives: '07 E90, '10 RR Sport
Those Alpinas really are a classy looking wheel. They look super heavy though. But I like them anyway!!!
"Never use a preposition to end a sentence with."
2007 E90 - Black Sapphire/Terra - SP - Xenon - CA -L7A - 19" CSL Reps - KW V3 - SGLD
      05-07-2013, 02:24 AM   #34
MELLOWYELLOW06
MELLOWYELLOW06's Avatar
19
Drives: 2013 535 MSport & 2012 650i
beautiful
I wanted a set when I got the car
Just impossible to find
      05-07-2013, 07:31 AM   #35
Eki88
BxBadBoyy88
Eki88's Avatar
27
Drives: AW 2015 535 Xdrive
21's look perfect with that drop. great choice!!
2013 AW 535Xi
      05-09-2013, 01:25 AM   #36
Dwn2Race
Drives: 2002 330ci
Very nice! We need more photos please.....
      05-09-2013, 11:38 AM   #37
Zaman
Zaman's Avatar
Drives: 2012 BMW (F10) 528i Xdrive
Thumbs up
Neat, I love the wheels and the way that the drop made them stand out.
BMW F10: A formula to captivate the senses.
2012 528i XDrive Alpine white
