FORUMS
- 5
| 09-29-2012, 01:17 PM | #2 |
![]() Drives: 06 E90 330, '11 F10 535 xdrive Join Date: Feb 2006
There's a DIY on here. But I think one of the guys used a butter knife. I wouldn't suggest that. I used a plastic emblem remover. Worked fine.
![]() LIVE FAST..DRIVE FASTER!! |
| 09-29-2012, 06:57 PM | #3 |
![]() Drives: 2011 535i, SG Join Date: Aug 2012
A surplus supermarket club card worked well. Thin plastic and no loss if it's damaged.
| 10-04-2012, 06:53 PM | #5 |
Affirmative. Start from the bottom front edge of the blinker and wiggle the card towards the rear while maintaining slight pulling force to maintain the seperation already gained.
| 10-05-2012, 09:23 AM | #6 |
![]() Drives: 2012 535i (f10) N55 Sport Join Date: Aug 2012
Hold the replacement insert in your hand first. Look at it to understand where and how the tabs, that hold it secure to the body panel, are located and work. As you gently pry the side marker away from the body panel with the credit card you will know where to look for the tabs. Once located, press each tab in towards the middle of the marker while you gently pull it away from the body panel. Piece of cake!
I used a plastic putty knife. It worked great, as it had a handle for me to better manipulate the side marker while pressing the tabs in. Last edited by Andy H.; 10-05-2012 at 09:32 AM. |
| Bookmarks |
| Thread Tools | Search this Thread |
