2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Installed BMS Stage 1
      12-12-2012, 08:55 AM   #23
RambleJ
RambleJ's Avatar
Drives: F10 535i M-sport
Originally Posted by bulldog x6 View Post
are you running 91 octane or higher?
I am running 93.
Rbembas, if you are running 91 I would highly suggest running some logs shortly after the tune adapts to make sure that the level of boost is running fine on 91octane.
      12-12-2012, 12:29 PM   #24
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
Originally Posted by RambleJ View Post
I am running 93.
I made a mistake I'm running 93 mostly Shell , but still I'll run some logs this
weekend. I did change the boost to 4.5 this morning, ran great just too much traffic here in Atlanta this monrinig to run it.
      12-20-2012, 06:24 AM   #25
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
Been running stage 1 for a couple of weeks now anyone getting drive train malfunction CEL?
      12-20-2012, 07:43 AM   #26
RambleJ
RambleJ's Avatar
Nope, you might want to check the connections to make sure something isn't loose. To stash the piggy box where the site shows is quite a tight pull to get it overthere. I usually go in and squeeze the plugs every couple weeks to make sure nothing is coming loose.
      12-20-2012, 08:25 AM   #27
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
Thanks I check them out and yes it tight.
      12-20-2012, 08:26 AM   #28
Alan l.
Alan l.'s Avatar
5437
Drives: 2020 F95 X5M Competition
Running 93octane exclusively and the car has been CEL free for over 1200 miles with plenty of full throttle/redline shifts.
Alan
      12-20-2012, 09:59 AM   #29
RambleJ
RambleJ's Avatar
Is the malfunction consistent or did it just happen once?
      12-20-2012, 11:35 AM   #30
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
It's happened a couple of times now the first time was when I had stage two running. Now. I'm running stage one now and have had drive train malfunction pops up a few times now.
      12-20-2012, 12:19 PM   #31
omer
Drives: M8 GC
How do you drive on sport plus? There's only sport on 535 msport
      12-20-2012, 01:16 PM   #32
Alan l.
Alan l.'s Avatar
5437
sounds like theres an issue with the car. Could be your fuel pump going etc..
I'd remove the tune and let the dealer fix it.
Alan
      12-20-2012, 02:03 PM   #33
RambleJ
RambleJ's Avatar
Alan
Exactly, remove the tune and see if you can replicate it tuneless. If not, it could be an issue with the tune.
      12-20-2012, 03:51 PM   #34
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
Thanks guys will do that this weekend. My service tech did tell me that there are issues with the fuel pump and tested it about three weeks ago when I had my car in for 27000 check up. Everything was okay and they didn't know that I've been running a tune. I did take it off before I took it in, they never mention drive train malfunction that stage two caused.
