2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wash, Wax, Detailing and Cosmetic protection/repairs Automatic Car Wash
      10-23-2012, 02:23 PM   #1
Lee
Germany
39
Drives: '17 X5 50i/'12 550ix/'01 Z3
Automatic Car Wash
Realizing it is sub-optimal to utilize an auto wash, I think I may be forced into it as I have to turn my hose off or the pipes will freeze. Thoughts?
      10-23-2012, 03:06 PM   #2
AP
AP's Avatar
164
Drives: G30 540i X Msport
bucket and sponge or better still a wollen mitten.
There's separate threads about detailing and washing cars but I would certianly never put my car through a automated car wash personally.
      10-23-2012, 03:52 PM   #3
bobblehead
bobblehead's Avatar
Drives: warp speed
If you treasure your F10 , wash it with manually. No other way !
      10-23-2012, 04:03 PM   #4
LiveLarger
Norway
Drives: F11 520d M-sport
This is how you do a propper car wash. With a bit of practice you are done in approx 30 minutes for a F11.
1: Spray the whole car with Bilthamber Surfex HD diluted 1:30. This stuff eats dirt and dust like nothing else and wont damage paint or wax when diluted 1:30 Leave on for five minutes. I make a mixture of total 6 liters and soak the car in this.
2: Rins off with a pressure washer. Now you car allready looks clean by most peoples standard (yes, it's that good)
3: Wash the car with a wollen mitten using the two bucket method with grit guards (google it)
4: Spray off all soap with a pressure washer
5: DRY the car. Make sure whatever you do use is not harsh and is 100% CLEAN. I recommend using chemical guys miracle dryer. Have two of them. One will dry your whole car, and have the second one for getting the last bits and parts.
This is the least abrasive way to wash your car and is what is generally considered the "propper" way in the car detailing community. Even when washing it this way you do get swirelmarks, but you will get them much much slower than most other people. Polish you car once or twice a year and wash it this way and it will be a head turner all the time. Better than new.
It has to be said that a bad hand wash is just as bad or worse (depending on the machine) then a automat.
      10-23-2012, 05:10 PM   #5
aman27
Drives: 2016 F15 x35i MSport
or you could just take it to a hand wash place
      10-23-2012, 05:21 PM   #6
The X Men
Drives: 2013 X3 35i
How do you guys wash the under carriage?
      10-23-2012, 11:48 PM   #7
LiveLarger
Norway
That usually leads to swirl marks. They actually tested this on the british show Fifth Gear. A regular cheap hand wash turned out to damage the car more then the automatic car wash. If you want to keep it clean, you need to take it to a detailer (expensive for the good ones) or do it your self.
      10-24-2012, 08:27 PM   #8
T-Man
Drives: 535i M Sport
@ the family mountain house we have some sort of digital valve heater element that recirculates the water through the pipes. This eliminates freezing.
      10-30-2012, 03:17 AM   #9
AMJAM
AMJAM's Avatar
Australia
17
Drives: 2013 Alpine 328I MSport
Never ever use a auto car wash
      10-30-2012, 04:08 PM   #10
CyclePath1
CyclePath1's Avatar
Drives: '14 M5 CP
I've been hand washing my car but with winter weather coming, not sure what I am going to do either. Maybe bundle up and go out to the car wash bays where you can use the pressure washers on low setting. That way, I can shutdown my outside faucets for the winter.
      10-30-2012, 08:45 PM   #11
eclipsisNA
Drives: 2013 Estoril 328i M Sport
2014 BMW 428i  [3.88]
Even if you hate your F10, don't ever put it through an auto wash.
      10-30-2012, 09:14 PM   #12
Ionic
Drives: 2013 535i X-Drive
Also, check with your dealer. Mine does free washing every Saturday..........
      10-31-2012, 12:07 PM   #13
Lee
Germany
39
Thanks for all you help. I finally came to my senses and found a place where I could use the wand and my own bucket.
That being said, anyone have any good lines on cloths/brushes to assist in washing rims?
      11-13-2012, 05:53 PM   #14
73henny
73henny's Avatar
Scotland
257
Drives: a lovely new 335dx
Hi Livelarger.
I read your post with interest. I've just taken delivery of a F10 in Sophisto grey and as yet has never been washed. I'd like to keep swirl marks to an absolute minimum so have been looking for ways to best clean the car. This surfex stuff you mention - how do you apply it? Foam lance?. Also, I read somewhere that the best method of rinsing is just with an open ended hose?, and that its best to let it dry naturally so no contact is made with the paint?
Thanks in advance.
      11-15-2012, 03:17 PM   #15
LiveLarger
Norway
Originally Posted by 73henny View Post
Hi Livelarger.
Thanks in advance.
You may use a foam lance yes. I use something like this http://www.clasohlson.com/medias/sys...3708060702.jpg but I think a foam lance would work even better.
I like to use a high pressure washer for rinsing. Most detailers I know about does. If you want to air dry the car, you would need some extremely clean water to make sure you don't get chalk marks and what not. Regular tap water usually won't cut it, and you need to dry it.
You should also make sure surfex hd or soap doesn't dry on the paint. I like to do it indoors or in the shade with very little wind.
      11-16-2012, 03:48 PM   #16
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT
I run my Jet Black F10 through the local auto wash twice a month. I clay and wax my car with Zymol twice a year, so far the paint still looks new w/o visible swirl marks. However, I don't plan on keeping any of my any of my cars past 3yrs so I can't speak for long term effect.
If you have the time, use the 2 bucket with wollen mitten wash method mentioned above. Never wipe off after rinse, only dap dry. Always soap/rinse from top to bottom. Don't buy any car wash soap that claims that it comes with wax. Wax doesn't stick to your paint that way.
If you can't wash it home, bring the buckets to the pressure car wash bay. Fill buckets with soapy water, rinse, soap the car, rinse, spot free rinse, and then dap dry with micro fibre or shammy.
Clay/Wax your car at least once a year.
      11-19-2012, 01:55 PM   #17
Frag
Frag's Avatar
Drives: 2011 BMW 550i
What about the automated no touch (water jets and soap dispensers only). Technically nothing actually touches the car.
      11-30-2012, 01:40 PM   #18
LiveLarger
Norway
It probably will be just fine, but it's likely to strip off any wax on you car. It doesn't really clean it well either.
      12-03-2012, 12:43 PM   #19
Lee
Germany
39
Thanks for all your input and you've effectively talked me into avoiding the evil auto wash. That being said, does anyone have any tips for washing the undercarriage to remove salt?
      12-19-2012, 10:44 AM   #20
Frag
Frag's Avatar
very true
      01-30-2013, 04:54 AM   #21
CyclePath1
CyclePath1's Avatar
Drives: '14 M5 CP
But aren't we talking about not doing the automated wash thingy? Unless your dealer is providing free hand washes, which I doubt they are, I wouldn't take it there either.
