2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes 20 Inch Rim Help
      10-26-2012, 12:31 PM   #1
bmwpgh
Drives: 2011 BMW 535I X-Drive
20 Inch Rim Help
I am going down the road of buying some new Rims for my F10 X-Drive from another forum member, and had a few questions regarding ride quality and where I go from here.
Questions:
1) Will there be any rubbing in the tires?
2) Since I have AWD I will be un-able to rotate the tires I place on these rims, will that cause these tires to cup or wear away quicker then normal?
3) will my speed be correct since I am going up a size? I am coming off the stock rims/tires
Any guidance is very helpful, this is my first round with ever replacing rims with bigger ones/different ones.
LINK: What rims I am buying. Ty Again Wvin---http://f10.5post.com/forums/showthread.php?t=748998
Thank you very much,
PGH
      10-27-2012, 01:52 AM   #2
clarkk41
clarkk41's Avatar
16
Drives: 2014 M6 Gran Coupe
Those are nice wheels man. Putting those 20's on your ride wont be a big deal. Speed will be correct ect. Not sure about tire wear since I don't have AWD but someone else on here will know that. They wont rub but the ride will be a little bumpier going to a bigger rim. Most guys on here are running 20's like myself. Just put the right tires on there. Most run 245/35/20 in front and 285/30/20 on the rear. Enjoy and hook up some pics!
      10-27-2012, 04:34 AM   #3
bimmer man
Norway
75
Drives: 745le xdrive 2020, i3 2020
2020 745le  [0.00]
2012 640i  [10.00]
Hello. because you have Xdrive I do not recommend aftermarket wheels. Bmw has many 20" rims to choose from. Originally and used 275 rear tire on Xdrive.
      11-13-2012, 02:36 AM   #4
Hyeoctane
Hyeoctane's Avatar
Drives: 2011 550xi Dinan stage 3 a/ACS
I agree I put 20 AC Schnitzer on mine and have had an issue with traction control and a tugging sensation on acceleration. Take the wheels off problem goes away. you should be ok if you use 4 identical tires and rims even if up a size and lower in profile. if you stagger on an x drive the small difference in profile height will translate to a different rolling distance for one revolution of the tire comparing the front to the rear. Some cars may pick this up as wheel spin and apply the brake.
      11-13-2012, 09:56 AM   #5
remmib
remmib's Avatar
Norway
1566
Drives: 2013 F10 520d M-Sport
What tire size did you use?
