2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Tires, Run Flat vs No Run Flat
      10-27-2012, 10:13 AM   #1
Helinas
Drives: 2011 550i M Sport Package
I think I have been duped by my dealer. I needed new tires only after 10,000 miles on my 550i M sport, and he said no run flats were not available for the 550i. Then I went to Tire Rack and found Michelin Super Sports, $700 cheaper than the Dunlop OEM run flats!
The no run flats should make the car handle better, I just have to have a can of fix-a-flat in the car, correct?
      10-27-2012, 05:33 PM   #2
snj1013
Drives: 2011 528i
Non run flats are cheaper and ride better than run flats as a general rule. It is up to you whether you feel comfortable without a spare. Most that switch carry a small compressor and a can of Slime fix a flat or similar.
      10-27-2012, 06:58 PM   #3
LiveLarger
Norway
Drives: F11 520d M-sport
Does the fix a flat thing really work?
      10-28-2012, 04:01 AM   #4
JimmyD
Jimmy D. 2011 F-10 550i Sport, Black Sapphire
JimmyD's Avatar
Drives: 2011 F-10 550i
2011 BMW 550i  [0.00]
I was just doing the same thing, bought a jack set from BMW (nicest jack set Ive ever seen, but you can talk them down to $150.00 for it) I am buying my spare tire donut for the F-10 from beamerzone $300.00 you also can get the jack set up there...Ive heard most dealers wont want to clean out fix a flat or slime, it is also bad for the tire sensors. My run flat tires are looking pretty worn after 11,000 miles
      10-29-2012, 04:37 PM   #5
snj1013
Drives: 2011 528i
Some fix a flat sealants are quite messing and can damage TPMS sensors. Slime is TPMS safe and cleans up with warm water per their website.
http://www.slime.com/shop/quick-spair/
      11-01-2012, 02:07 PM   #6
JRubin13
Drives: 2009 E92 335i/2012 F10 535i
run flats are absolute garbage. Get Michelin PSS now.
Tags
run flat oem
