2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions DIY: Cabin Filter Replacement
      11-09-2012, 06:11 PM   #1
lll F10 lll
Drives: 2012 Space Grey 535i M-Sport
Thumbs up DIY: Cabin Filter Replacement
Here is a DIY to replace or check your cabin filters. These are the filters for your cabin ventilation, not your air intake filter in the engine bay!
You'll need:
1.) Trox bit set
2.) Replacement filters(if needed)
3.) Low profile(short) screw driver
It took me about 30 minutes total, taking the under dash panels took a bit longer as it was my first time doing it, but reinstalling was a breeze. Here goes!
You're going to look under the dash/footwell area of the passenger side. Pretty cool because I actually never new there was another a/c power plug there. Nice!
You'll see a total of 4 screws holding the entire panel, point upwards. There are 2 bigger ones, and 2 smaller ones. Undo those 4, and there is one more screw which is the one on the side of the footwell area, and it screws in towards the driver side.
With a little work and being careful with the panels, you should be able to slide that whole underpanel out safely, but watch out for the 2 wires that are still attached. One of the is the power wire for the A/C port, and one is for the airbag. You A/C power wire slides off easily, but the airbag wire I left connected. It has enough slack for you to rest the entire panel on the floor of the passenger side, and access the cabin filter compartment.
Now, you will see a grey hose going into the cabin filter compartment, simply slide it off.
Holding the lid for the cabin filter compartment is 4 silver screws pointing/screwing upwards. Undo those 4, and you are basically good to go. Here are some shots of the 4 screws and a picture of the compartment cover off:
[url=http://imageshack.us/photo/my-images/525/32622006.png/]
At this point you can check or replace your 2 cabin filters, and put the dash panels back together!
***NOTE: When you reinstall the bottom panel as one whole assembly, make sure that the 2 plastic tabs on the back of the panel line up with the slots under the footwell area, or else the panel wont go back in place properly!
lll F10 lll is offline
      11-09-2012, 06:57 PM   #2
ryyster
ryyster's Avatar
Drives: a BMW
2011 BMW 535i  [3.50]
Great post! Thanks for the info & pictures!
ryyster is offline   United_States
      01-07-2013, 01:41 AM   #3
M535
PinOyBIMER
M535's Avatar
Drives: 535
soo useful.. thanks so much!
M535 is offline   Pitcairn Islands
      02-05-2013, 02:37 PM   #4
beloit
Drives: f10 530d Xdrive
I am not sure that filters was installed correct. Arrows show air direction but it seems strange as both filters installed in one direction. Guys, who will change filters, please pay attention before removing them and make a picture and post here. I think direction of arrows have to be inside. Sorry for English.
beloit is offline   Reply With Quote
      02-07-2013, 08:49 AM   #5
grimlock
Drives: F10 528i
^I noticed this too. But I am not certain which way they were before I took them out, but one was facing in the opposite direction from both facing towards each other.
When I examined the dirt, one had it on the wrong side, but forgot which was it was installed in the car.
I put it in facing toward each other as you suggested - will know next time I replace in 1yr haha..
grimlock is offline   Reply With Quote
      02-11-2013, 01:59 PM   #6
LACSTER
Drives: AW F10 & E93
So I'm assuming this is for the AC system correct? I've notice when I turn my AC on there's a funky smell for the first minute or so. If this will resolve the issue I'll do it now!
LACSTER is offline   Reply With Quote
      02-11-2013, 10:02 PM   #7
L7AS
Drives: '12 F10 535i
I had your problem too Kev! I went to the dealer, and my SA helped me with it.
He said what he did was: turn the AC to the hottest temperature for 10 minutes, turn it off, switch the car off, take out the cabin air filter, clean it (replace if necessary), spray lysol (he used the white bottle one on my car) to the AC system (like the piping or something), and let the AC on for about 20-30 mins in a cool temperature.
I don't have any smell on my AC now.
L7AS is offline   United_States
Forum Jump
