2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum M5 rear diffuser
      11-17-2012, 10:11 PM   #1
scott in cincy
Drives: 2011 335xi
M5 rear diffuser
I bought the rear diffuser for my M-sport, and I'm wondering if anyone knows what exhausts work with it? I have contemplated Dinan and Eisenmann at this point, or removing the trapezoid tips and putting on stainless quads like others have. Before I paint these pieces, does anyone know what exactly works?
It's clear from holding it up to the existing, the trapezoidals won't fit.
Scott in Cincy | 2011 335i X-drive |Sapphire Black over Oyster Nevada | VMR V810 19" | Eibach springs | Koni Yellow | Cobb Stage 2a | Dyno Tuned by TiC
Pure Stage 1 and inlet pipe sitting in a box in garage!
      11-17-2012, 10:25 PM   #2
mdrobc13
mdrobc13's Avatar
Drives: Made in Bavaria
2015 BMW M3  [0.00]
2010 BMW X5M  [0.00]
Send a message via MSN to mdrobc13 Send a message via Yahoo to mdrobc13
Scott...yes you will need to change out your tips IF you plan on mounting the M5 rear diffuser. All of the available options Dinan, Eissenman, and Meistershaft, and others (Remus has a setup also I think) make great Quad options for the F10...all depends on your taste and sound/hearing tolerances. However from what I've been told/seen all require slight modifications to fit the F10 M5 rear diffuser. This is because the outlets line up slightly off form the OEM setup (both M Sport and otherwise). Those who have done it say it can be done okay and easily enough for experienced shops it just requires a little more planning and re-routing/modification to your exhaust install to make it work.
Also from what I've been told and found out from my body shop/tuner the rear of the M5 and the 550i are the same IF the non M car has the OEM M Sports kit. Otherwise the non M Sports kit cars use a slightly different rear bumper. Any F10 can be refitted with the M5 rear diffuser it just will take more $$ for a non M Sport car.
My car is currently being done now and I pick it up next week so if you want check out my post then to get an idea of the setup and details.
'14 Range Rover Sport SC (Chille/Black) - Mine
'15 BMW M3 (Black/Black) - gone but not forgotten
'16 Cayenne (Black/Black) - Herz
'13 Harley Davidson Dyna Custom - born to ride
      11-17-2012, 10:55 PM   #3
scott in cincy
Drives: 2011 335xi
Thanks for the reply, please keep us posted! What exhaust did you choose to go with? My car is an M-sport, so that should make it a little easier, according to your post. Guess I'll have it painted and get the process started.
      11-18-2012, 01:55 PM   #4
///M ARMY
Drives: F80
2015 Charger 392  [0.00]
2015 M3  [0.00]
Same here. My m5 diffuser fits but the rear section of the exhaust does not. Your going modify the tips. I am having the same issue.
Also now my easy open trunk isnt working.
      11-18-2012, 02:53 PM   #5
scott in cincy
Drives: 2011 335xi
I wonder if the two aren't mutually exclusive or if the welder wasn't properly grounded at the time and shorted something out?
      11-18-2012, 03:06 PM   #6
///M ARMY
Drives: F80
2015 M3  [0.00]
well when you think about it, the m5 diffuser is made for the m5 and the m5 exhaust. It does fit the m sport bumpers of the 535 and 550 but the exhaust setup has to be modified to fit the m5 diffuser.
      11-18-2012, 05:23 PM   #7
scott in cincy
Drives: 2011 335xi
I was more asking about your trunk opening problem as a result of the new diffuser...doesn't seem like the diffuser itself could cause that issue per se.
      11-18-2012, 06:52 PM   #8
///M ARMY
Drives: F80
2015 M3  [0.00]
Oh that problem? The trunk issue, I'm going to have Ltbmw work on it since they installed it.
2015 BMW /// M3 BSM
Just stock!
      11-18-2012, 08:55 PM   #9
mdrobc13
mdrobc13's Avatar
2015 BMW M3  [0.00]
2010 BMW X5M  [0.00]
Also now my easy open trunk isn't working.
That is because the sensor for the comfort access is somewhere mounted behind the rear bumper and when the retrofit of the M5 rear diffuser is done it may interfere with the mounting points on the sensor. Search the forums as I have come across another member who had that problem. Sensor just needs to be moved as it obviously is mounted in a different place or manner in the M5 vs the non-M cars (even the ones with the M sport package I think). As my easy comfort trunk opener doesn't really open all that easy and reliably I am okay if my car comes out without that fxn when I get it back honestly. I think I've used it properly maybe 2 times in 2.5 mos of ownership! LOL But my installers are aware of the issue and will try to keep it intact during my retrofit. Will keep you guys posted.
      11-19-2012, 01:23 AM   #10
///M ARMY
Drives: F80
2015 M3  [0.00]
Oh ic. Thanks. Well it will be handy because it will be easier for pregnant wife to use it. Ltbmw said he will fix it this week.
2015 BMW /// M3 BSM
Just stock!
      11-21-2012, 02:35 AM   #11
mdrobc13
mdrobc13's Avatar
2015 BMW M3  [0.00]
2010 BMW X5M  [0.00]
So looks like the Eissenman exhaust fits fine in my 550i. Just not with the M5 F10 rear diffuser. F10 M5 Diffuser tips outlets sit inboard by about 2" and my installer/shop are having major problems because the Eissenman Race exhaust is large and the passenger side just won't align to the outlets. No cutting or adjusting seems to work other than major modifications to the rear body/frame/wheel well. So its back to my OEM M sport diffuser unless I want to now swap out exhaust to something smaller or that definitely fits (OEM M5 cans - that probably would have been less expensive than my Eissenmans!) LOL
More to come later when I get an update in the AM.
      11-21-2012, 03:30 AM   #12
wdimagineer
wdimagineer's Avatar
Drives: 2015 X5 M
There's a reason the M5 diffuser only fits the M5...
Without modification you're not going to fit it. Now that I have my Akrapovic exhaust I might sell my OEM M5 exhaust.
Current: 2015 X5 M - Donington Grey/Mugello Red - DINANTRONICS Stage 2 + Free Flow Exhaust - Bimmerpost Featured!
Past: Bimmerpost Featured 2014 X5 xDrive50i 2014 Jeep SRT 2013 Tesla Model S P85+ Bimmerpost Featured 2013 F10 M5 2012 550 xDrive 2011 M3 ZCP
      11-21-2012, 02:30 PM   #13
scott in cincy
Drives: 2011 335xi
Why couldn't a decent exhaust shop add a bend or so to make it work?
      11-21-2012, 04:35 PM   #14
///M ARMY
Drives: F80
2015 M3  [0.00]
Same thing I did. Fits perfect now. Will get pics after I get back in town
2015 BMW /// M3 BSM
Just stock!
      11-21-2012, 05:02 PM   #15
mdrobc13
mdrobc13's Avatar
2015 BMW M3  [0.00]
2010 BMW X5M  [0.00]
Yes the modification however would be extensive and require body work to the frame...likely cutting/shaving off about 1-2 inches of the rear tire well. I've seen it work for a few but looks like extensive mods were required and none used Eissenman cans for the non-m car. One guy got it to work but used a set of F10 M5 cans he got from an owner and I think Akrapovic tips.
Nice set up but $$$ $1700 for the tips alone!
Problem is NOT the pipes but the size of the Eissenman cans. As you can see they're pretty big and there is just not enough space on the passenger side to shift the cans so that they alight outward to meet the M5 valance openings. These are 550i Eissenman exhausts cans mind you...I'd expect the passenger side tips are probably more properly aligned on the M5 Eissienman exhaust. On the Eissenman exhaust for the 550i I am assuming they are set up to fit the outlet of the M sport valence which is outboard by about 1-2" on the car. (See pics)
Would have to see what exhausts you used (some others have much smaller cans and thus more space for the alignment (Meisterschaft and Supersprint) cause looking at it now...I can see there's no way to make it fit AND get the tips aligned properly in the M5 valance. Even if you cut off the tips...there's not enough room between the muffler and the valance to jig and weld an S pipe to get them properly aligned. And once I cut them then IF it doesn't work then there's no going back/returning them.
So will look for an alternative rear diffuser/valence likely and go with my OEM M Sport install.
      06-24-2014, 03:28 PM   #16
Reboot
Reboot's Avatar
Drives: F10 550ix | BMW 2002 | Benz GL
Same issue here w/ my Eisenmann Race + M5 Diffuser. Going back to the OEM M-Sport diffuser.
      06-24-2014, 11:31 PM   #17
Chili Palmer
Master Of My Domain
Drives: 2011 550i M Sport
Is there that much of a difference between the Eisenmann 550 exhaust and the M5 model? If there isn't then just see if you can order the M5 mufflers or the M5 system if you're going to use the M5 diffuser.
Jet Black 2011 550i - Lowered on ACS springs, BMW 343 M5 wheels, Michelin Pilot Super Sports 255 F/285 R, M5 Grilles, M5 rear spoiler, M5 diffuser, M5 exhaust
      06-25-2014, 02:14 AM   #18
mdrobc13
mdrobc13's Avatar
2015 BMW M3  [0.00]
2010 BMW X5M  [0.00]
That is possible however you then will need to move/make some adjustments to your downpipes as well and possible resonators. Also not sure if both have the same pipe diameter. A good shop can do it but at added cost/modifications. I ended up going with a CF Haman rear diffuser instead.
      06-25-2014, 11:45 AM   #19
Chili Palmer
Master Of My Domain
After rereading my post it didn't seem clear that I was talking about when ordering an Eisenmann exhaust; what I was wondering if the M5 spec mufflers could be ordered to fit with an M5 diffuser. Or if an Eisenmann M5 system would fit on an 550 with little or no modifications.
      11-09-2015, 02:46 PM   #20
Justtinchan
Drives: 2013 F10 550i M-sport
I tried to put a m5 meisterschaft gt system on my 550i to fit with an M5 diffuser. Alignment fit perfect with no modification needed. The only thing that need to work with is that the pipe diameter of the m5 spec muffler is slightly larger. That could be fixed easily. Once I stated the car, it sound very deep and loud. Nice sound, ....until I drove it around.
Probably due to the difference in pipes diameter, the exhaust drone A LOT! Around 1800-2000 RPM, it drone like crazy. TOTALLY UNBEARABLE. It felt like sitting in the back of a airplane while the just started to take off. It will hurt your ears IMO. So I just took it back to the muffler shop and see if anything could be done to fix it.
So, to answer your question. Yes, any M5 system could fit a 550i (They are basically using the same floor). And M5 system would fit m5 rear diffuser. But, there are just that much things you need to work with to deal with the Unexpected.
      11-09-2015, 03:14 PM   #21
Chili Palmer
Master Of My Domain
Bummer, I just went with the stock M5 mufflers, I tried to use the whole system, but the bends at the rear suspension hit and weren't clearing as they should so I said screw it - just use the mufflers. I can say I am pleased with the low rumble at start-up and and the subdued tone while driving. While I'd like more sound while getting on it, that's only a very small percentage of the time I'm in the car. I've left the loud open headers and Flowmasters back in my youth where you can't carry on a conversation without turning the radio down - that gets old real fast. Besides the 5 Series is a high end car, no reason to cheapen it by installing an obnoxious exhaust system.
      11-09-2015, 04:25 PM   #22
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
That's gotta suck ball$! Are you able to incorporate some resonators to quiet it down? FenixMike might chime in as he's somewhat our exhaust junkie here
~CinnamonLeatherInterior~21"3Piece AlphaForgedWheels~BMSgoldTitaniumLugz~ 3dCarbonRearSpoiler~3dCarbonFrontLip~3dCarbonSideS kirtExtensions~DTMCarbonDiffuser~CarbonWrapPUFront Splitter~CarbonRearSplitters~PUrearDiffuserTray~
~CarbonEmblems~LedermanzWheel~ShadowlineKit~Double SlatGrills~WstyleCarbonRoofSpoiler~CarbonMirrorCov ers~MeisterschaftEVC90mmQuadExhaust~CarbonTipCover s~KWV1Coilovers~MStylePedals~G2GoldCalipers~35%Tin T~
