2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications M5 Exhaust on a 2012 550i M Sport?
      12-11-2012, 12:05 AM   #1
SoCalKid
SoCalKid
SoCalKid's Avatar
Drives: 2018 BMW M4
Need some technical insight. Will the exhaust system (cat back) from a 2012 M5 fit on a 2012 550 M Sport? Thanks in advance.
____________________
2018 BMW M4 Mineral Grey with M Competition Package / Vorsteiner 20" VFF-103 Wheels / H&R Sport Springs / CF rear diffuser /CF side skirts / CF front lip / CF splitter / CF mirror caps / CF rear spoiler / Meisterschaft GTC exhaust.
      12-11-2012, 03:23 AM   #2
EV0LVE
EV0LVE's Avatar
24
Drives: F10 535i SG
It can be done...
http://f10.5post.com/forums/showthread.php?t=752054
      12-11-2012, 03:58 PM   #3
SoCalKid
SoCalKid
SoCalKid's Avatar
Drives: 2018 BMW M4
Originally Posted by EV0LVE
I appreciate the feedback. I saw this post, but from what I can tell he only installed the M5 mufflers, not the complete cat-back system, which is what I'm contemplating. Local BMW dealer says they can't find the dimensions of '13 M5 exhaust system nor my '12 550i, so they can't say whether it will work or not. Frustrating.
      12-30-2012, 02:11 AM   #4
mdrobc13
mdrobc13's Avatar
Drives: Made in Bavaria
2015 BMW M3  [0.00]
2010 BMW X5M  [0.00]
Send a message via MSN to mdrobc13 Send a message via Yahoo to mdrobc13
It should fit. Remember that the engine in the F10 550i is basically the same engine as the F10 M5 but detuned so the diameter of the exhaust should be the same pipe wise as both are V8's. Changes are likely due cat back and muffler back on the M5 vs 550i. However since someone has already easily retrofitted the M5 mufflers into their 550i and used the OEM rear valence it should NOT be too easy to do the full system. Check around some more and I am sure you'll find a willing shop/tuner shop. Dealer will likely balk tho as if anything goes wrong they won't want the blame..however it does depend on your relationship with them tho. Good luck and keep us posted.
'14 Range Rover Sport SC (Chille/Black) - Mine
'15 BMW M3 (Black/Black) - gone but not forgotten
'16 Cayenne (Black/Black) - Herz
'13 Harley Davidson Dyna Custom - born to ride
      06-23-2014, 06:04 PM   #5
eboosted
Peru
17
Drives: x6 5.0i xdrive 2009
Did you guy confirm if the M5 exhaust will fit a 550i F10?
Akrapovic does not offer an option for the 550i F10 only for the M5 F10, I'd like to know what things will I have to modify besides the diffuser in order to fit it in the 550i
      06-23-2014, 08:17 PM   #6
badblack550xi
badblack550xi's Avatar
329
Drives: F10 550xi 2013
should be a direct fit with very minor adjustments most likely between down pipe and exhaust.
      06-23-2014, 08:36 PM   #7
eboosted
Peru
17
I jumped into the pool and ordered the Akrapovic evolution M5 F10 system even thouigh my car is the 550i F10.
As I see on these pictures there will be some modifications but it should work ok if I change the rear diffuser for the M5 one.
BMW M5 F10
BMW 550i
      06-24-2014, 01:51 PM   #8
F150 Duke
Drives: 550i
It works, I have it on my 550i. The competition pkg is what I have and boy is this thing loud now. Thinking about putting on the primary muffler back on to tone it down some as it's giving my GT500 a run for it's money.
You'll need to have a shop adjust the downpipes and move the resonators back some to clear the transmission. Then you'll just need the M5 diffuser, insert and bracket which holds the trunk proximity sensor.
      06-29-2014, 09:15 PM   #9
clerkpalmer
Drives: 2011 550xi M-Sport
Exhaust
Most definitely. I have an m5 exhaust on my 2011 f10 550. I am even using the stock diffuser. Muffler shop can make it fit.
      06-30-2014, 12:56 PM   #10
eboosted
Peru
17
Do you have the complete catback system?, do you know what does the muffler shop had to do in order to make it fit?
      07-05-2014, 01:47 PM   #11
clerkpalmer
Bolts up to the stock downpipes. I am using the M5 xpipe but you don't have to. Muffler shop said it was a bit of a pia but not that big of a deal. They had to move the hangers and adjust the tips. Not sure what else ... I didn't really ask for details.
      05-24-2015, 03:48 AM   #12
texasjohn
texasjohn's Avatar
I just had this same installation on a 550i (RWD) in the UK. The car is completely whisper silent on the stock exhaust, unlike the E60 which had a nice backtrack of V8 noise (although the E60 was still pretty quiet, you had to listen hard for it).
550i is 2010, and the M5 exhaust system came off of a 2015 car.
All in all it was about 8 hours labour. It is not really a direct bolt on, but probably overall cheaper than an aftermarket full exhaust.
The PNs you need are:
18207845461/3 x 1 of each
18207585358 x 4
18207578229/30 x 1 of each
18207832991 x 2
51618048827 x 1
Where the front of the exhaust system meets the downpipes it is not a true bolt-on. The flanges are a little different:
https://drive.google.com/file/d/0B3y...ew?usp=sharing
The workshop I used ran the 550i system back from the downpipes about 24" to the 'bulge' in the pipes (not sure if these contain secondary cats or an absorption muffler) and thereafter it is the M5 system.
Some hangers needed to be relocated and the cross member bracket needs to be replaced to accommodate the x pipe (which replaces the centre resonator you have on the 550i).
I had the 550i tips refitted as I wanted to retain the 550i SE looks. Thus I had custom fabrication of the tailpipes between the backbox (muffler in US) and tips, using some 57mm bosal exhaust tube. First of all I went without the exhaust flaps but it was too loud and droned, particularly under load like uphill on the motorway at 70mph.
See link for the audio of the system without flaps:
Start:
https://drive.google.com/open?id=0B3...REk&authuser=0
I have now had the M5 flaps fitted in the outboard tailpipes and it is loud on a cold start and also when it really 'gets on it' over 2500rpm, you can literally tell when the flaps are opening. The power comes on a little harder as the flaps open (as you might expect).
It isn't whisper quiet below 2500rpm and is probably just about as loud as most 40 year olds would want, certainly near the limit for me. But it has a nice burble and doesn't scare small animals and children. It is louder than a stock E60 550i.
See links for video of low revs with flaps closed:
https://drive.google.com/open?id=0B3...aUk&authuser=0
https://drive.google.com/open?id=0B3...bFE&authuser=0
I am not sure why (probably due to something upstream of the exhaust system, ie manifolds) but the 550i is louder and more 'bassy' with the M5 exhaust than the M5 is. AFAIK, the cc and firing order is the same.
F31 340i, E87 130i, F10 550i, E92 335i, E61 550i, E90 335i, E87 130i, E87 118d, Z4M, Z4 3.0i SMG, E46 330D, Z3M, Z3 3.0i, Z3 3.0i (USDM)
      05-24-2015, 11:50 PM   #13
FenixMike
Drives: 2015 435i M Sport
I dont believe you... post videos with sound
      05-26-2015, 11:25 AM   #14
kthankzbye
kthankzbye's Avatar
33
Drives: 2011 550i DGM
Just like what texasjohn said, I also realized that the M5 muffler is louder and deeper on the 550i than a M5. Thought it was only me cause Ive added vibrant resonators.
      09-09-2016, 06:17 PM   #15
BigVic
Drives: 2010 BMW X5M
It is because of the exhaust manifolds. The N63 motor has the typical layout of the turbos, one dedicated to each bank's exhaust ports. The S63 is a cross bank exhaust manifold designed to reduce the turbo lag. This impacts the exhaust pulses significantly. which would change the tone. That is why the AMG's sound more vicious compared to the M cars. They are setup just like the N63 motor with turbos on each bank's exhaust port.
N63 Turbo manifolds
S63 Turbo manifolds
      09-09-2016, 06:19 PM   #16
BigVic
18207585358 x 4
18207832991 x 2
51618048827 x 1
Start:
Your assumptions are correct. I posted this at the bottom of the post.
N63 Turbo Manifolds
S63 Turbo Manifolds
      10-28-2016, 03:44 AM   #17
Jabreezy
Jabreezy's Avatar
Drives: 2011 BMW 550I
After reading several post I swapped out the stock mufflers for the M5 Comp Mufflers along with the rear diffuser. Getting the diffuser was one of my biggest hold ups.
This post solved the problem:
http://f10.5post.com/forums/showthre...EM+M5+Diffuser
I also added the Exhaustmeister:
http://exhaustmeister.com
      10-29-2016, 12:24 AM   #18
Graffix
Graffix's Avatar
18
Drives: 2013 550 xi M sport
Where did you find the exhaust?
