2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Manual 6 speed transmission issue
      12-15-2012, 08:37 AM   #1
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
Anyone running 6MT have noticed a problem when shifting from 1st to 2nd?
I'm in sport mode in my 535i I bring my rpm's up to 4000 and pop the clutch and boom my car takes off. Rpm's race up to 6000 I shift into second gear, hit the gas and nothing my rpm's didn't drop they stayed at 6500, no power, felt like a safety override kicked in. I let off the throttle and the rpm's dropped down I hit the throttle and she takes off. Other times when shifting from first to second I chirp the tires and she hauls ass.
I've discussed this with my dealer and they tell me everything running to specifications.
Of course this happened when I was running against a 2012 Audi A6
      12-15-2012, 11:19 AM   #2
alextremo
Drives: F10 550i
Are you doing this with dsc on? If so try turning it off.
      12-15-2012, 01:10 PM   #3
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
I have three modes comfort, normal and sport. I'm running it in sport mode when this happens.
      12-15-2012, 03:01 PM   #4
alextremo
Drives: F10 550i
Hold down your dsc button until it turns off completely and see if you still experience this.
      12-15-2012, 03:18 PM   #5
Fantasm
Algeria
20
Drives: SL63
if dsc is kicking in, he must be losing some amount of traction -- if he doesn't realize this, i dont think telling him to turn off traction control is going to be a good outcome.
NOW: 2011 Ferrari 458, 2014 BMW M5 w/ CompPack, 2014 BMW X1, 2005 BMW M3 with Gintani SC&Meth, 2008 Ducati 1098
BEFORE: 24+ Other Awesome Cars - BYE - My Straight Piped Ferrari 458 (plus other mods): http://goo.gl/2qf5fW
      12-15-2012, 03:50 PM   #6
Juiced46
Drives: 03 Turbo Cobra, 2011 335xi
I was thinking the same exact thing!
      12-15-2012, 03:58 PM   #7
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
Yes I hold it down for a few seconds until red picture come on saying dsc is deactivated.
      12-15-2012, 04:11 PM   #8
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
Off the line yes I'm losing some traction, tires chirping that's why take it up to 4000 rpm's. now it may be that I'm so close that the rev limiter is kicking in? I'll try shifting sooner around 6000 rpm's and see what happens.
      12-15-2012, 05:03 PM   #9
alextremo
Drives: F10 550i
Good point. Make sure you try this in a straight line with no one around...
      12-19-2012, 08:24 AM   #10
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
Yesterday with my brother in my car we took off in a straight line, I took first gear up to 6000 shifted into second and again some kind of safety kicks in until I let off the gas then I could punch it and hit third gear. My DSC was off and I was in sport mode. This only happens when I'm shifting into second, no problems shifting into third. Does BMW have some kind of built in safety in there manual transmission? When this condition happens it feels like the power is cut in half my rpm's are at 6000 and my speed is 40 mph. My car should be hooking up and pulling away hard. Like I said when I let off the throttle and then punch it my car takes off, but by the time that happens a few seconds are lost.
      12-19-2012, 05:50 PM   #11
alextremo
Drives: F10 550i
If you are in sport mode I don't think DSC can be completely off. I think DTC stays active when you are in sport mode.
      12-19-2012, 06:15 PM   #12
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
Yes, I think you are right from what I have just researched. In my 535i I don't have a sport plus setting, perhaps that is when DTC is disabled?
      12-19-2012, 09:01 PM   #13
alextremo
Drives: F10 550i
I don't think so. Just hold the dsc button until you get the SECOND warning saying that dtc is off. It takes about 5-10 seconds. Once this happens don't touch any other settings and give it a go.
      12-20-2012, 12:30 AM   #14
bb2405
bb2405's Avatar
Drives: F10 535i M-sport
2011 BMW 535i  [4.38]
I don't think there is any way of turning traction completely off. Sport plus enables DSC and turns off DTC and turning DTC off just turn DSC.
      12-20-2012, 06:43 AM   #15
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
So with that said I'll have to change the way I run a 0-60 from a dead stop. I never have a problem dropping the clutch at 6000 rpm's it intermittently and only happens when shifty into second around 6000 rpm's. well looks like I'll have to save for a M5
      12-20-2012, 07:12 AM   #16
alextremo
Drives: F10 550i
It can definitely be turned all the way off, you just need to continue to hold the button.
      12-20-2012, 08:06 AM   #17
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
I have three modes: 1) Normal, 2) Traction DTC active and 3) DSC Off sport-oriented chassis setting, DSC deactivated
I don't have sport plus so DTC must still be active.
      12-20-2012, 08:17 PM   #18
alextremo
Drives: F10 550i
I don't have sport plus either. The small display next to the tach will say DSC OFF when it's completely off.
This is the setting I've used at the track and you will get uninterrupted wheel spin, if you want it.
      12-20-2012, 10:00 PM   #19
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
Yes I have done the same, I mostly drive around in sport mode, but for some reason I'm having a problem when I'm shifting into second gear. Anyway I'm going to take my car in again because I'm getting some kind of a safety either DTC kicking in or a manual transmission/clutch problem?
