2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Anyone have issues with the doors sticking?
      01-03-2013, 01:29 AM   #1
dchartier
Drives: 2013 BMW 550i
I just got a 2013 550i and noticed an annoying little problem: After it rains, the passenger-side front door sticks when you try to open it. Basically, when I pull on the handle and apply a normal amount of force to open the door, it stays stuck closed. When I pull much harder (quite a bit more than I would normally pull), it opens. It feels like this is an issue with the rubber seals between the door and the frame sticking together. I haven't had this issue with the other doors, and this only seems to happen after it rains.
Anyone else experienced this, and any advice how to fix it?
Many thanks!
Doug
      01-03-2013, 02:42 AM   #2
OzDriver
OzDriver's Avatar
Australia
Drives: '13 535i & '08 530i
Sounds like the door isn't properly aligned. If the fit isn't tight enough, water gets between the seal and the frame you have to break the suction to open the door. Get the dealer to check it for you.
      01-03-2013, 03:50 AM   #3
MELLOWYELLOW06
MELLOWYELLOW06's Avatar
53
Drives: 2013 535 MSport & 2012 650i
Wow, I just got my 535 last month and the other day, after not driving it for a few days, I came to open my drivers door and it was stuck. Gave it a tug and it sounded like tape peeling. Only happened once so far!
      01-03-2013, 04:20 AM   #4
AP
AP's Avatar
317
Drives: G30 540i X Msport
My passenger sticks a littl, its not bothered me though.
Maybe some gummifledge might help a bit.
Pu it down to not being used much.
      01-03-2013, 02:02 PM   #5
dchartier
Thanks, guys. I read online that applying some Armor All to the seals can prevent sticking. I applied some this morning and will report back whether it fixes the problem. If it doesn't, I'll have to follow OZDriver's advice and have the dealer look at it (hopefully, it doesn't come to that!).
      01-06-2013, 08:06 PM   #6
dchartier
So I Armor-alled my door seals, and then my car sat outside in some rain for a couple days. Tried the door today and there was no sticking at all. So -- fingers crossed -- the problem might be solved.
_____________________________
2013 550i (6-speed, MSport)
      01-08-2013, 02:43 AM   #7
NYF32DRIVER
NYF32DRIVER's Avatar
Drives: 2016 428i X Drive
Both my passenger and drivers side door have stuck after hot or wet weather since day 1.
2016 428i X Drive. Mineral Gray Metallic. Born 2/2016, Munich Factory.
Member BMW CCA Since 2008
      08-31-2013, 03:34 PM   #8
Luigi524TD
Drives: 2013 535 xDrive
Mine have not stuck closed - but they seem to bounce off the door seals unless you really slam the doors hard. IF I decide to buy a 2014 in the months ahead I will DEFINITELY add the soft close door option - NOW I know why!
Until then, I just tell my passengers to slam the doors and pretend that they are getting into a $70,000 Kia.
My opinions are free - you'll get exactly what you pay for!
Current:
2013 535xDrive
1998 Z3 2.8
2007 Rav4 V-6 AWD
      08-31-2013, 04:36 PM   #9
Alan l.
Alan l.'s Avatar
1655
Drives: 2016 F85M
Mine does it because of the rubber gaskets around the doors. Doesn't matter if you have soft close doors or not (i have them). I'm sure you can get some rubber product like gummi phlege to fix it.
Alan
      08-31-2013, 05:12 PM   #10
Martin528
Martin528's Avatar
Drives: 2012 528
Mine did it once. I thought the remote was not working and the door was not unlocked. It was a 90 degree raint day. Car was at work. Only happened once.
Thanks for the reminder I do have gumiflege(sp)
2012 Tasman green metallic with oyster/ black interior. premium pkg, power tailgate, homelink, and park distance control. Premium sound: premium hi fi system and satellite radio,technology package:
Rear view camera and navigation,Comfort Access,heated front seats, BMW apps
      10-28-2013, 06:41 PM   #11
GDP
Drives: 2013 535i xdrive
Thanks for sharing. I had the exact same problem with the passenger door
      11-02-2013, 10:14 AM   #12
dbs600
Drives: 2011 750LXi Individual
Aside from sticking, how about doors making a creaking / whining / gurgling noise upon open and/or close, when damp outside / after a car wash?
      11-05-2013, 01:30 PM   #13
lindros2
Drives: 535i M-S
I missed this whole thread until now. I have a 2013 535i.
Both of my front doors stick. Actually the passenger side door also popped open at ~30 MPH because the sticking was bidirectional - it was difficult to open the door, but ALSO difficult to fully close the door (required a hard slam).
I think the dealer realigned the doors and it's been... better.
      11-05-2013, 01:31 PM   #14
lindros2
Drives: 535i M-S
Same with me - and as I just posted above, my passenger door popped open while driving (thankfully was caught by the secondary latch) because it was not fully closed/latched... thanks to the flawed seals.
2013 F10 535i Carbon Black M-Sport
2011 F10 535i Dark Graphite (Sophisto) Metallic (traded)
2009 Nissan GT-R (sold)
BMW CCA # 493835
      11-06-2013, 01:38 AM   #15
slownfast
Drives: 2013 528i Xdrive
same with me, I think it is normal tough.
      11-06-2013, 05:15 AM   #16
Sjoerd
Sjoerd's Avatar
Drives: MY14 F10 535d, MY13 Boxster S
Mine as well! I have soft close. It is only when weather is humid/rainy. It doesn't get hot here so often ;-)
Both my F10 535i and F11 530d (non-soft close) did not have this issue.
Current: MY2014 F10 535d (daily), MY2013 Porsche 981 Boxster S manual (fun)
Retired: MY 2011 F11 530d (temp), MY2010 F10 535i, MY1987 BMW E30 325i (fun), MY1974 BMW E3 2500 (fun) (and more..)
      03-31-2015, 06:31 PM   #17
gspannu
Drives: F10 535, F82 M4
What is gummifledge? Available from? Or any alternatives?
My 535 is exhibiting this problem.
      03-31-2015, 09:13 PM   #18
SonicEndeavor
Drives: 2014 535i MSport
You can find it on Amazon.com. Search for Gummi Pflege
2014 LCI 535i /// M-Sport - SAT, Premium package, HK Audio, Drivers Assistance, Top/Side/Rear cameras, multi-contour seats.
Mods: V2 coilovers, Michelin PSS, Opticoat Pro, Quad black chrome exhaust tips. Coded several features myself.
      04-01-2015, 01:19 AM   #19
AP
AP's Avatar
317
It also stops any "creaking" noise you may hear as the body flexes over any bumps and the doors move ever so slightly.
      04-01-2015, 02:21 AM   #20
martin mustang
Ireland
74
Drives: 520 F10,X5 40e, 911c4s, 635csi
my one too, from day one and still does it not bothered I guess it explain why the F10 it is by far the best sound proof car in it class!
      04-01-2015, 05:38 AM   #21
gspannu
Just ordered this from Amazon UK; will post results once I apply.
      04-01-2015, 05:57 AM   #22
E90Fleet
South Africa
1068
Gummi = Rubber in German
Pflege = Care in German
So "Rubber Care"
Works wonders.
You used to be able to get it from BMW Dealers, but I havent tried them for years since its cheaper at Amazon.
You can also wax the paint side of the door with normal car wax to help prevent sticking even more.
Also dont forget to clean there when washing the car. Its often overlooked.
BMW if you are reading, I need a job, Please.
