2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding No Audio through iPhone 4S 6FL option only
      01-08-2013, 07:01 PM   #1
MophoMan
2011 535i
Drives: 2011 535i
2013 BMW X5 35i  [0.00]
2011 BMW 535i  [0.00]
Did some extensive searching on the forums and couldn't find a particular instance which would be directly applicable to my problem.
I have option 6FL (USB in console) but not 6NF (Music).
Does this mean I can't control my iPhone from the console USB connection? Also, When connecting my iPhone to the the USB and trying to access it through iDrive it says not supported.
Reason I'm asking is because I'm wanting the cradle for my phone (I don't believe I'm going to upgrade to the iPhone 5 anytime soon), so... the way I'm looking at it, the only options I have is to either get the y-cable to be able to play music through my iPhone and forgo the cradle, or get the cradle and forgo the music.
Am I correct?
      01-09-2013, 04:26 PM   #2
MophoMan
2011 535i
Drives: 2011 535i
Com'on now... I know you guys are using iphones... what's the dilly?
      01-09-2013, 04:28 PM   #3
jykishan
vroom vroom
jykishan's Avatar
Drives: 2011 550i xDrive
on my build sheet it says I have 6FL and I have no issues with using my iphone thru iDrive. Once plugged in you cannot choose your songs from your iphone, you must choose from Idrive. BTW I use the regular ol white apple cable, not bmw's y-cable
      01-09-2013, 04:41 PM   #4
MophoMan
2011 535i
Drives: 2011 535i
yea but do you also have 6FN or 6NR on your sheet?
      01-12-2013, 11:35 PM   #5
MophoMan
2011 535i
Drives: 2011 535i
Figured it out... Needed the Y cable
      01-13-2013, 06:52 PM   #6
jykishan
vroom vroom
jykishan's Avatar
I'm still learning all this 6FL 6NR 6NF crap, not all 2011's are created the same, your car was probably built prior to dec2010 meaning you do not have the combox meaning you need that y-cable, my car was built after dec2010 so I do have the combox, its confusing as fawk
      01-13-2013, 09:51 PM   #7
MophoMan
2011 535i
Drives: 2011 535i
yea all I need to know now is which dock to get... and can I still control and listen to music through that dock, or will it only charge it... uggghhhh....
      01-14-2013, 01:19 PM   #8
MophoMan
2011 535i
Drives: 2011 535i
So does anyone have the "Phone Version" here? Wanting to know if it has the built in Y cable there, or only the USB cable. I still want to be able to play music through my phone and have a cradle.
From Tischer:
Phone version (requires base plate) snap-in adapters provide:
Charging of the device
Secure and stable docking location
Vehicle specific mount
Improved reception by connecting to the vehicles external antenna
Music version (vehicles up to 9/2010, requires option 6NF) adds:
Integrated USB connection which negates the need for a separate audio cable
Access to the music tracks stored on the Smartphone
Media version (vehicles from 9/2010 and on, requires 6NF or 6NR) includes the same as Music version and adds:
Display of "cover art". With "cover art", the applicable song's original album cover will be displayed on the central information display.
For vehicles equipped w/ BMW Apps (SA 6NR), this adapter allows the full functionality of the option, including 'video playback' and the 'plugin' feature.
