FORUMS
- 5
Do most people here pumping premium gasoline on a lease car?
| 01-10-2013, 04:11 AM | #23 | |
![]() ![]() ![]() ![]() Drives: 2012 535i xDrive M-Sport Join Date: Aug 2009
2012 F10 535i M-Sport
| 01-10-2013, 08:53 AM | #24 |
I appreciate you're talking about the US, but in EU (UK more specifically) premium fuel usually means Shell V-Power Or BP Ultimate which is the performance stuff 97/98 Octane).
You can get 87, but most go for Normal = 90 due to the price. Performance is much more expensive, 8p a litre (about $10/tank). The point I am making is whilst I agree to an extent that if you are buying a luxury car, this would be insignificant, however as a company car when you pay fuel and tax on the benefit (UK Tax stings you!), then that's why I don't put performance fuel in. Moreover, I give the car back every 4 years so don't care... and recent studies (Top Gear, What Car, AA etc. show no tangible difference in performance). Each to their own
Alpine White (
) F10 520d M Sport Auto - 8 speed Auto/paddles - 350M 18" Dunlop RFT's - Deleted Sports Suspension - Tom Tom Navigation Pro ![]() Last edited by jedpause; 01-10-2013 at 08:55 AM. Reason: Additional point made |
| 01-10-2013, 01:39 PM | #25 |
Methinks we are missing a point here.
The question here is what is considered “premium”. BMW recommends 89 and 91. Turbo engine will sooner or later choke on 87. Lease or purchase; 89 is perfectly fine. Now, off to catch that expiring holiday special at the local Yugo dealer. Can’t wait to finally be able to afford 91. ![]() Last edited by COBodom; 01-10-2013 at 02:07 PM. |
| 01-10-2013, 02:13 PM | #26 |
| 01-10-2013, 03:08 PM | #28 | |
![]() On a serious note though, I don’t know anything about Hyundai, but I am sure you’re right. However, any AUDI/VW/BMW turbo that I had always got the “check engine” light after a tank or two of 87. |
| 01-10-2013, 10:38 PM | #29 |
![]() Drives: Loving my F10 528 Msport Join Date: Nov 2006
only use Shell V power and nothing else.
2012 528i(N20) M-Sport
Old cars 1999 E46 325i, 2004 E60 525i, 2009 E60 525i ![]() |
| 01-11-2013, 12:16 PM | #30 | |
| 01-11-2013, 12:59 PM | #31 |
I see these threads pop up from time to time on various forums and they annoy the crap out of me for a couple reasons. Believe it or not, there IS science and engineering behind the recommended octane rating. Because most people don't understand what octane really is, the discussions always revolve around the periphery of the topic. So I'll explain and you can chose to listen or not... I taught internal combustion theory and application at a university, so I feel somewhat qualified to open my mouth (though people rarely care)...
Octane is generally defined as a fuel's resistance to preignition and detonation. To the layman, this is it's resistance to pings and knocks. The higher the octane rating, the more resistant a fuel is to being ignited by the temperature and pressure within the cylinder (and not the spark plug). There is a tradeoff however... the higher the octane rating, the slower the fuel will burn (I'll get to that in a little). Engines are designed with a certain compression ratio. The higher the compression, the more the fuel must resist igniting on it's own... thus a higher octane requirement. Turbocharges effectively increase the cylinder pressure by forcing additional air charge into the cylinders (duh). So while a turbo car might advertise a static compression ratio of 9.5:1, with the turbo is working that number may actually be considerably higher. This is why turbo cars generally run higher octane fuels. Modern vehicles have sophisticated sensors to monitor the performance and safety envelope of the engine. Because there's a variety of factors that can induce preignition (other than low octane) like load, temp, ignition and valuve timing, or altitude, the engine's computer will adjust certain variables to keep the engine in a "safe zone"... e.g. no condition where preignition or detonation is present. So here's why I think using lower than specified octane fuel is a bad idea: By using 87 or 89 instead of 91 or 93, you essentially force the engine into a state where it has to constantly correct for preignition or detonation. For the engine to do this, it must first DETECT the ill-advised condition. This means that some preignition must occur before the ECM can account for it. And because computers are logic based, it doesn't know what is causing the condition, so it will constantly check & adjust, check & adjust... It was previously stated that no reliability problems are generally identified with short term exposure to this situation (which may be true), but I have to believe that over the long term, those conditions will take it's toll on the internal engine components. If anyone has ever seen what detonation can do, you'll appreciate how catastrophic it can be. So in my opinion, NO, do not run lower octane fuel unless you're prepared to pay the consequences down the road. It's not a matter of "zippiness" or MPG's, it's a matter of wear. Yes, low octane gas will degrade the performance of your car... but that's a SAFETY mechanism, not a convenience because you are too cheap to purchase the correct fuel or wanted a more expensive car than you really could afford. One other point... if you have a car that requires 87 and you run 91 because you want to "treat" your car, or get some more power... you're a fool. Running higher than the required octane will possibly degrade performance because it burns slower (as stated in my first paragraph). Hope this helps. Flame suit on. |
| 01-11-2013, 01:10 PM | #32 |
Fascinating. Really. You sound as close to a rocket scientist as we are likely to see on this forum.
![]() I have always run premium and will continue to do so. My sense was essentially what you have stated - I wanted to protect the engine from unecessary wear and the marginal cost was insignificant. Going back to the OP, if you have the car for 3 years and then turn it in, perhaps you just don't care. I wouldn't know, since I buy, hold and drive. I suppose those on a lease have their decision to make. But thanks for the thoughtful post.
2013 F10 550i/6 M-Sport
retired: 2002 E39 540i/6 |
| 01-11-2013, 06:27 PM | #34 |
next thing you know..someone will come here asking if people properly clean their leased car or not or if they just clean it from outside..lol
don't be cheap..leased or rented..treat it good! |
| 01-12-2013, 04:57 AM | #35 |
I bought the 4.4 twin turbo 550ix for a reason......I wanted the power. Even though its a lease, I want the car to perform on a optimal level. I put premium
2011 550ix
Retired: 2009 e92 335i msport 2006 acura TL 2004 Mazda 6 GT GFX 1987 325is |
| 01-12-2013, 06:29 AM | #36 |
Octane ratings 'different' US v UK
Further to my first response, and after reading vdubturbo's writeup... I studied a bit more.
Turns out regular and premium in UK have higher octane ratings than US. Seems regular here in UK is aligned with BMW minimum requirements, so our Premium (99 Octane) is much higher than needed, i.e. our regular is just fine and Dandy to keep the engine healthy.... i.e. US regular is below spec I believe, premium aligns it with BMW recommendations That's why I don't have any inclination to buy premium in UK despite it being crazy expensive anyway.
Alpine White (
) F10 520d M Sport Auto - 8 speed Auto/paddles - 350M 18" Dunlop RFT's - Deleted Sports Suspension - Tom Tom Navigation Pro ![]() Last edited by jedpause; 01-13-2013 at 04:56 AM. |
| 01-12-2013, 09:34 PM | #39 |
Are you serious? There is a huge performance drop between 91 and 87. Its very noticeable to me and certainly worth the extra $3 per tank. I don't treat my car any differently because I lease it.
I leased this last time because I found myself buying a new car every 2-3 years anyways. I don't feel there is any real difference between lease and own. The only minor difference I see is that I don't have the hassle of getting rid of the car when I'm ready for a new one. -Time |
| 01-16-2013, 10:04 AM | #41 |
I choose my car expecting it to give me all 300HP that Bmw said it has. I'm not going save a few bucks by putting in cheap gas so i could have less.
Its like someone buying a top of the line Macbook Pro and then go cheap by hooking it up with dial up connection because you saved a few bucks by not getting cable/Fios. Lease or finance I treat my cars as if its nearly a member of the family (my wife hates me for it lol) Alan
![]() Current - 2013 N55 535xi Msport SAT Retired - 2009 N54 335i Msport 6MT Retired - 2000 M52TU 323i ASA Supercharged 5MT More Photos of my car here |
| 01-16-2013, 10:11 AM | #42 | |
| 01-16-2013, 02:28 PM | #44 | ||
Commander
Stay Ahead!
E46(00-03) - E46 Touring (03-06) - E90(06-10) |
| Bookmarks |
