2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes BMW Tire Insurance or new set of non run-flat tires?
      01-11-2013, 06:55 PM   #1
hufington
BMW Driver since '89 BMW E30 M3 non-cat (147 kW)
hufington's Avatar
Drives: 2013 535i
I was wondering if anyone changed their tires right at the dealer before delivery from runflats to regular tires to avoid any tire and wheel issues with them.
I am thinking about doing so instead of buying the rather expensive tire protection plan from the dealer. I can buy a set of tires from the Tire rack or Discount Tire and get their relatively inexpensive road hazard plan.
And at the lease end, I can return the car with its original set of tires.
What do you guys think?
2013 BMW F10 535i - 3.0 L 221 kW (300 hp)
2007 BMW E64 630i - 3.0 L 200 kW (272 hp)
2003 BMW E65 745i - 4.4 L V8, 242 kW (325 hp)
1995 BMW E34 540i - 4.0 L V8 210 kW (282 hp)
1989 BMW E30 M3 non-cat version 147 kW (200 hp)
hufington is offline   United_States
      01-18-2013, 03:17 PM   #2
bmw-man-uk
bmw-man-uk's Avatar
Drives: F10 530D MSPORT
If your changing to Non RFT, you can't risk not having a spare, thus it would be wise to buy a single alloy in the same size/design and put a cheap tyre on that too, obviously it would have to be the same dimensions as the front tyres.
or just put up with RFT's, bewary of the tyre insurance, read the t&c's the bmw uk version of the policy usually stipulates a minimum tread depth of 3mm across middle 75% of tyre (when the legal limit is only 1.6mm here) also if your rft's are 19"+ and low profile then you might find you'll be paying the differance per tyre as these policys usually set a max limit for tyre price.
Just my 2p's worth, hope its helpful.
bmw-man-uk is offline   Reply With Quote
      01-21-2013, 05:39 PM   #3
rjm98119
Drives: 2013 535i xDrive
How much is the tire & wheel protection right now? I don't remember what it was when I took deliver of my '13 535 in November.
Since you're leasing, Keep in mind (I think/thought) that insurance also covers damage to the wheels themselves. I'm not sure how forgiving your dealer is (mine is super-forgiving), but some dealers charge $150+ for even the most minor scuff. Bend/break it (unlikely, but...) and you're looking at a big bill. So, if you are planning to use the factory wheels, it might be worth it, regardless of what you do with tires, depending on cost.
Also... you on 18's or 19's? Those damn 19" RFT are sickeningly expensive, so if you don't change 'em out, just get the insurance.
That said: I drove 300 miles on my stock 19's and then ditched 'em for a set of Sportline CS wheels with Conti DWS tires (great wheels, not sold yet on the tires) and I am happier. Stock tire/wheel is terrible set up. Will return to dealer with fresh original tires/wheels, as you say. This is what I did in my 2008 335 and was much happier for that last year without the RFTs.
rjm98119 is offline   Reply With Quote
      01-21-2013, 06:42 PM   #4
crl8474
Drives: 2012 535i M-Sport
Tire Coverage
I drove my car from the dealership directly to Discount Tire where they sold me the warranty and road hazard coverage. I wasn't sure they would do it but they told me it was okay so long as the tires were new. Keep in mind that this doesn't cover the wheels. There have been well documented issues with the OEM wheels bending (I currently have two that are bent) so this is something to consider also.
crl8474 is offline   Reply With Quote
      01-22-2013, 11:32 AM   #5
hufington
hufington's Avatar
Drives: 2013 535i
They did that for the factory tires?
      01-22-2013, 11:33 AM   #6
hufington
hufington's Avatar
Drives: 2013 535i
My dealership is not very trustworthy so I am not sure about their service department. I will have to find a nice authorized service in NJ.
      01-22-2013, 11:35 AM   #7
hufington
hufington's Avatar
Drives: 2013 535i
I will have a bottle of tire fix foam with me at the least in case I change to non-RFT.
      01-22-2013, 04:10 PM   #8
crl8474
Yes. I heard from a buddy that they would do this so I gave it a shot and it worked. They checked the tires and odometer to confirm mileage but it wasn't an issue. The bad news is that the insurance on run flats is much more expensive and you'll want to make sure they can get the same tire should one need replacing.
Forum Jump
