FORUMS
- 5
After Detai: How Do You Keep The Scratches Away?
| 01-13-2013, 05:04 PM | #1 |
Master Of My Domain
I'm going to spend about $1000 on a detail to my Jet Black 550. How do I keep the scratches away? My detail guy told me that anytime you touch something across the paint, (microfiber towel, sponge, etc.), you risk scratching the paint. My big problem is the car is black and everything shows up on black.
I thought about maybe having Opti-Guard applied after the detail to add some resistance to scratching, but my detail guy said that really wouldn't help. What are my options? |
| 01-15-2013, 07:59 PM | #2 |
Opti guard would most definitely reduce marring. OG is more scratch resistant. However, the questions is this: is your detailer able to apply the coating without marring the paint.
For people like yourself, jet black should not be an option. I realize why people purchase solid black, but if you worry about imperfections, you'd be better off with something lighter and metallic. I hope my post didn't come across too harsh.
| 01-16-2013, 07:03 PM | #3 | |
Master Of My Domain
| 01-16-2013, 07:18 PM | #4 |
In that case, have it Opti Coated.
| 01-20-2013, 12:27 PM | #6 | |
Master Of My Domain
I was thinking about getting a water deionization set-up for rinsing the car off, drive it around the block to get most of the water off and then dry off the remaining dribbles. The less you touch the paint, the better, right? |
| 01-20-2013, 03:57 PM | #7 |
Problem is that there is still debris on the paint. Driving off will cause the remnant water to slide off. While it is sliding off it will trap debris/dirt and scratch. Swirls will form.
Best way is a proper car wash method. Check out gilmour foam gun for a regular water hose. As I said before invest in two buckets and grit guard and put some elbow grease into your car. You are paying a grand to make it new. Why not put a little effort and some chump change to keep it that way. Weeks worth of rain, yes ONR still does wonders. Do a panel at a time. Caked on dirt/salt, then rinse off thoroughly before ONR or using a foam gun.
2012 BMW 128i 6MT Deep Sea Blue Metallic
| 01-20-2013, 06:14 PM | #8 | |
Master Of My Domain
By no means did I plan to just rinse off the dirty car with deionized water and leave it at that. |
| 01-20-2013, 06:26 PM | #9 |
Bwahaha. Seriously I was reading it and I was like why would be spend a grand on a detail to swirl the paint again!
But invest in a gilmour II foam gun. I think you would really be happy with it. I also like to use a leaf blower to dry the car. Good luck mate.
| 02-08-2013, 12:21 PM | #11 |
I use my electric leaf blower to pre-dry the car after washing. Then finish up with nice clean and fluffy microfiber cloths and a good detail spray (I use Adams). The extra lubricity of the detail spray provides some extra protection in event there's a spec of schmutz lurking on the paint. And it smells nice too :-)
| 02-10-2013, 03:02 PM | #12 | |
Master Of My Domain
My paint was damaged by the dealership when I took in for a paint repair on the front bumper, (my car was a CPO that they said they had repainted the front bumper cap). When got the car home and saw it in the sunlight I was aghast that there were swirl marks and buffer trails all over the car. They said that they would take care of it, but I didn't want them to touch the car again. I should have gotten in contact with BMW corporate, but I waited too long. The car has a haze that I can't seem to remove and now has buffer trails all over it. I want it done right and only one time. Plus this is a complete car detail inside and out, hence the cost. |
| 02-10-2013, 03:04 PM | #13 | |
Master Of My Domain
| 02-10-2013, 07:52 PM | #14 | |
| Bookmarks |
