2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK swapping wheels
      01-27-2013, 01:44 PM   #1
Dom
Ireland
33
Drives: 2013 520d SE space grey
swapping wheels
Can anyone tell me if these wheels
http://www.gumtree.com/p/cars-vans-m...res/1007914759
will fit my F10 without the need for spacers etc. The tyres are 245/40/18 instead of the recommended 245/45/18 but I don't think that would matter much, or would it?
Thanks.
      01-27-2013, 02:06 PM   #2
HighlandPete
Drives: BMW F11 535i Touring
Thanks.
I can't identify what style they are, look like replica rims, but not sure, so will pass on opinion. But if they are similar to Styling 135, 8x18" with ET 20, will be pushed out 10mm without need for spacers.
http://felgenkatalog.auto-treff.com/
Tyre size is wrong, too low a profile for the F10. You do need the 45 aspect ratio to get the sidewall dimension correct, particularly as you are after better ride quality.
HighlandPete
      01-27-2013, 02:21 PM   #3
Dom
Ireland
33
HighlandPete
Thank you for that. I looked at the link you very kindly sent and I see they are style 166. I wasn't sure about them.. I could buy them and fit new tyres of the correct size. How do you think they would look on the F10?
      01-27-2013, 02:39 PM   #4
HighlandPete
Styling 166 is a 19" rim, plus it is 8.5" width with ET 12. They would be about 25mm out into the arches, if they do fit.
Still not sure about the 18" wheels in your link.
HighlandPete
      01-27-2013, 03:38 PM   #5
Dom
Ireland
33
HighlandPete
They are Styling 166 but they are 18''. Does that mean they aren't original BMW wheels?
      01-27-2013, 04:12 PM   #6
HighlandPete
As I understand it, BMW don't make an 18" version of the Styling 166, only the 19" size. But there are definitely replicas in 18" variations.
HighlandPete
      01-27-2013, 04:45 PM   #7
Dom
Ireland
33
HighlandPete
I don't want to go bigger than 18'' for ride quality purposes. What do you reckon about these?
      01-28-2013, 05:59 AM   #8
HighlandPete
You would need to know the exact size and offset, plus I'd be concerned of the quality of the rims themselves. There are good and bad in replica rims. I personally would prefer a rim type from the OEM range for the car, but obviously will cost more if you can find a used set.
It is a difficult shout, as to what solution is going to give you what you want. Will an 18" non run-flat improve the ride quality enough over rough roads? Rim weight and tyre specification could be as critical as size and a move to a non run-flat.
Plus the comment in the other thread, "it's smoother, but not 1200 worth smoother".
HighlandPete
      01-28-2013, 06:51 AM   #9
Dom
Ireland
33
HighlandPete
I know, it's a difficult call. Maybe I should keep the current rims and just replace the tyres. But the OEM 17'' rims aren't great looking by any means.
      02-25-2013, 09:09 AM   #10
gedward
Drives: BMW F10
Sorry to barge in on the thread but i just joined the forum and I do not yet have the priviledge to create a new thread.
Does anyone know why BMW does not include the 245/50 R17 tyre size as an option for the F10?
I have a 528 with 18" rims and 245/45 tyres. I wish to change down to 17" due to suffering a lot of tyre damage caused by bad road conditions were i live.
The 17" rims would allow a higher profile tyre and hence better cushioning effect.
BMW lists the 225/55 R17 as the only option.
I do not want to loose the traction quality of the 245s but nobody at the local BMW dealership can inform me why the 245/50 R17 is not listed.
