2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums ASIA M5 343 Rims for F10 520i...
      02-04-2013, 02:32 PM   #1
Pixie
Hong Kong
Drives: 2011 Space Grey F10
I want to buy a set of used (Less than 1000 miles) M5 343 rims with 255/35/20 and 285/30/20 PSS tires from U.S.A., If I fit those rims to my F10, will it be any rubbing issues with stock suspension? The seller is one of the members here, he is asking $3300 USD for it. I just PMed him about the cost of shipping to Hong Kong.
Is my F10 520i power enough running with the 20" rims?
P.S. By the way, what is the " OEM " means? It means " REAL " M5 rims or " Replica "? Thanks.
Thanks in advance. ^_^
      02-04-2013, 04:31 PM   #2
remmib
remmib's Avatar
Norway
823
Drives: 2013 F10 520d M-Sport
OEM means original BMW part, so yes, real M5 wheels.
      02-04-2013, 04:50 PM   #3
remmib
remmib's Avatar
Norway
823
Here's a thread with pics of F107F11 with the 343M wheels.
http://f10.5post.com/forums/showthread.php?t=693143
      02-05-2013, 08:53 AM   #4
eddysuen
Drives: 2014 F15 30d
I think the key issue is the width of rim which required wide tyres....
2014 F15 X5 30d
2012 F10 528i, Toyota Estima
2010 E92 325i, Toyota Estima
2009 Honda Odyssey
2007 Honda Stream
      02-05-2013, 09:09 AM   #5
mlai
mlai's Avatar
Hong Kong
117
Drives: 650GC/E93M3/Lexus LS600HL
Easily drinks +15-20% more fuel vs the stock RFT and low rolling resistance tires.......
F06 650i Gran Coupe Ruby Black/Dakota Cinamon- 2012-10-12 Adaptive Drive/IAS/Surround View/Adaptive LED/Comfort Seats/BMW 356 Liquid Black/Michelin PSS 245/35R20-285/30R20
E93 M3 Cabriolet Satin Pearl White/CR - 2012/03/12 Bilstein PSS10/ Michelin PSS 245/35R19-265/35R19 Brembo GT
2011 F10 550i M Sport - Retired
      02-05-2013, 04:14 PM   #6
Pixie
Hong Kong
Thanks remmib c hing. ^_^
      02-05-2013, 04:15 PM   #7
Pixie
Hong Kong
Thanks for the link. I have read that post before posting my question. It's very nice set up with the M5 343 rims. ^_^
      02-05-2013, 04:16 PM   #8
Pixie
Hong Kong
Yes I know that eddysuen c hing. It requires 255 in front and 285 in rear.
      02-05-2013, 04:18 PM   #9
Pixie
Hong Kong
drink more 15 to 20% fuel? @_@
Thanks for the info. mlai c hing. ^_^
      02-08-2013, 12:32 AM   #10
RR80
RR80's Avatar
12
Drives: F10 535i
First, the tires come with the M5 wheels is too tall for normal f10. Second, the offset are too low because of the M5 is much wider.
2003 E60 530i - PSS9 Coilover/M Kit/BBS GT-RS 19" wheels - retired
2006 E91 335i - Procede V5/Forge DV & FMIC/Bastuck quad exhaust/P1 Steering Wheel/Sachs Coilover/M kit/19" RS wheels - retired
2011 F10 535i - Stock
      02-08-2013, 12:10 PM   #11
remmib
remmib's Avatar
Norway
823
No, OP wants to run 255 + 285 and that works fine.
The M5 offset is ET34 and that's 1mm off the front offset of the non-M F10, and just 10mm more aggressive than in the rear.
      02-08-2013, 01:30 PM   #12
Pixie
Hong Kong
remmib c hing,
Is it ok to fit M5 rims with 255 and 285 tires on a normal F10? Will it be any rubbing issues? Thanks in advance. ^_^
      02-08-2013, 01:31 PM   #13
Pixie
Hong Kong
RR80 c hing,
Yoy meant it won't fit on a normal F10?
      02-13-2013, 09:47 AM   #14
RR80
RR80's Avatar
12
Drives: F10 535i
It will fit and will not rub if not going stupid low, what I said here is the wheel will not fit perfectly or as nice as those after market and OEM rims which's made for normal F10 due to the aggressive offset of the M5. For $3300 USD, I sure will get something else. That's only my 2 cents.
      03-17-2013, 10:19 PM   #15
tofuflower
Drives: 528i
Hey Pixie,
My ride is 528i with M sport package.
I just got a set of 343M installed.
OEM M5 343M wheels(second hand, took off from a BMW M5)
size of the wheels are
front 20x9, ET 34
rear 20x10, ET 34
tire size i went conservative(heard 255 and 285 are also fine but if you wanna lower the car it might rub when you have ppl sitting at the back.)
front Michelin PSS 245/35/20
rear Michelin PSS 275/30/20
      04-06-2013, 08:05 AM   #16
guelphman73
Drives: 2013 528 xDrive
Originally Posted by tofuflower View Post
Hey Pixie,
front 20x9, ET 34
rear 20x10, ET 34
Hi! How are you liking the 343M rims? I have the 528i with M package as well and am planning to put a set of 343's on Monday as well. Is the handling good? Any big hit in mpg because there's so much tire on the road? Thx!
      04-07-2013, 06:16 AM   #17
Pixie
Hong Kong
Thanks for the advice RR80 c hing. ^_^
      04-08-2013, 04:47 AM   #18
tofuflower
Drives: 528i
I personally like an OEM look, so I like it a lot.
I actually can't really feel a different comparing to the old set of wheels in regards to mpg and handling. Probably because I only drive the car in weekends.
The only big change I notice is the ride is much more quite.
Sorry didn't really answer for you questions.
      04-29-2013, 06:16 AM   #19
Pixie
Hong Kong
Hey Pixie,
front 20x9, ET 34
rear 20x10, ET 34
tofuflower c hing,
May I have a look of your car with 343 rims on? Did you lower your car? I bought a used rims before but I don't like them much now and want to get a set of 343 rims if the price is not expensive.
Thanks in advance.
