2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Windshield Washer Fluid Tank Capacity?
      02-05-2013, 01:25 AM   #1
dbs600
Drives: 2011 750LXi Individual
Heated Windshield Washer Fluid Tanks?
How many gallons do our windshield washer fluid tanks hold? Should I put in more than one gallon at a time? I donít use the fluid any more than in my other cars, but my car guzzles it! Wish there was a way to control whether or not itís wasted on the headlamps...
      02-05-2013, 02:05 AM   #2
LastFrontierBimmer
Drives: '14 F32 435i xDrive MSport
When the warning light comes on, I dump in a gallon and she takes it. Not sure how much it'll take beyond that. In looking at the manual (hard copy), it sure isn't very technical - no fluid capacities, etc.
2014 435i xDrive MSport / Black Sapphire Metallic / Black Dakota Leather / MPPK / 6MT / 19" / M Sport Brakes / DINAN Springs / Bilstein B8 / Technology Package / Premium Package / Cold Weather Package / Driver Assist / HK Sound
      02-05-2013, 02:10 AM   #3
dbs600
Same (when light comes on it takes an entire gallon), which is why I wanted to know capacity.
Checked manual and found it takes 1.325 gallons.
Thanks!
      02-05-2013, 02:15 AM   #4
LastFrontierBimmer
Ack! Guess I didn't look hard enough. Cheers
      02-05-2013, 10:57 AM   #5
vdubturbo
Drives: 2011 535i
I always wondered what the "OEM" washer fluid was. It seems to have a higher alcohol content than what you buy in the stores... which seems to make it evaporate faster and leave less spots/streaks.
What is everyone using in their cars and how do you like it?
      02-05-2013, 01:18 PM   #6
dbs600
Don't use anything in particular; whatever's at the gas station; an absurd $4.00 for 1 gallon now (of what is essentially water)!
You've noticed a difference after the dealer tops you off(?); I never realized they used anything different... Good to know!
      02-05-2013, 02:16 PM   #7
BigKutta
BigKutta's Avatar
63
Drives: 2012 528i
2012 528i  [0.00]
2012 BMW 528i  [0.00]
Yes, I have always loved the factory fill in the BMWs. Its clear and smells very nice as you can smell it through the cabin. The usual stuff is blue and stains the car until you wash it. I think that at least here in the US, you can only buy the blue fluid, because some people may mistake the clear fluid to be water and drink it. Hence only the factory fill is clear.
I try to make my factory fill last as long as possible...I just hit over a year on the car and the low light came on for the first time. Time to get the blue crap
      02-05-2013, 02:54 PM   #8
Gilgorm
Drives: 2012 535i Xdrive
Last July, as I was picking up my car, my salesman gave me two jugs of "BMW All Season Windshield Wash" good to -45C. It is purple. It contains methyl alcohol. It seems to work very well.
My favourite is Rain-X Windshield Washer fluid De-Icer good to -40C. It also contains methyl alcohol, is yellow in colour and contains a 'bittering' agent so no one will drink it. It adds a water repellent that greatly improves the wiper's ability to remove water. It will not ice-up on your windshield down to -40C.
It costs more than the blue stuff and less than BMW brand above but I use less and can genuinely see better. I get mine on sale or at Costco.
2012 BMW 535i X-drive; Space Grey/Black Dakota, Fineline; Executive (Auto trunk, NAV, HiFi Prof, Lumbar, Rear Cam, SIRIUS, Voice), Technology (Blind Spot, Hi-Beam Assist, Lane Departure, Surround View), APPS, Rear heated seats, Tint.
Retired: 78 300D, 81 300SD, 87 190E, 88 Porsche 924, 89 260E, 93 300E, 97 Volvo 850, 98 E320, 03 BMW 325iT, 02 C230 Sport Coupe, 08 BMW 535i
      02-07-2013, 02:00 AM   #9
Alpine300zhp
Drives: M4/M3
I buy the washer fluid concentrate from the dealer and mix with distilled water. Cost is 2.50 a jug. Does not stain paint or windshield.
      02-09-2013, 02:30 PM   #10
dbs600
Do our windshield washer fluid tanks heat the fluid, and if not, why?
GM vehicles are advertised as having same!
      02-09-2013, 03:45 PM   #11
mryakanisachoad
mryakanisachoad's Avatar
-103
Drives: '13 550xi + '09 M5 + '10 135i
You can always make your own washer fluid. Save money too!
It is funny that washer fluid went from a buck to 4 bucks almost overnight.
But, the government keeps telling me there's no inflation so I believe them. Why would they lie?
      02-09-2013, 03:47 PM   #12
mryakanisachoad
-103
The fluid in my 1 series freezes all the time. Same for an old 3 series :-)
      02-10-2013, 03:48 AM   #13
LastFrontierBimmer
No need.
Decent washer fluid comes good to -25 and -40 degrees Fahrenheit. You wouldn't want to heat it all night if you live in a cold climate. Battery would die and car wouldn't start.
      02-10-2013, 01:09 PM   #14
Gilgorm
Proper windshield washer antifreeze should never freeze in the tank. If it does you must be mixing it with water. It should be used full strength unless it states otherwise.
Some poor quality antifreeze may feeze on a cold windshield but never in the tank.
      02-10-2013, 01:12 PM   #15
dbs600
The reason why I'd like the tank, not only the nozzles, to be heated is not because of potential for the fluid to freeze in the tank (if anyone's putting water in their tank, it be bad all around, as the tanks would then crack!), but so the fluid cuts through to snow / ice on the windshield better! Simply having heated nozzles can only do so much, and really just ensure the nozzles are clear...
      02-10-2013, 08:14 PM   #16
Luigi524TD
Drives: 2013 535 xDrive
A good quality windshield washer fluid is necessary not only to help clean a dirty windshield and prevent icing in freezing temperatures but to reduce the possibility that mold or fungus will grow in the tank and slime up the pump filters. If you decide to mix your own, I recommend using distilled water to reduce the possibility that chemicals in municipal water supplies will also add their own gunk to the system. A few $$'s of fluid should last the average driver several months. I too like the smell of the BMW fluid and my dealer tops off my car at any service. It also cleans great and handles temps below "0".
That's my story and I'm stickin to it!
