FORUMS
- 5
PYSpeed.com | Avant Garde BMW Type M510 19"/20" - Bimmerpost Special!
| 02-13-2013, 09:09 PM | #1 |
PYSpeed.com | Avant Garde BMW Type M355 Style 20 inch Wheel Set
![]() These Avant Garde BMW Type M510 20 inch Wheel Set are guaranteed flawless straight from the factory! With perfect fitment and evenly coated finish. They are low pressure cast, increasing the quality and decreasing the weight when compared to gravity cast wheels. The Avant Garde M510Wheels are also stronger with a higher load rating than most other low pressure cast wheels on the market today. Bolt Pattern: 5x120mm Center Bore: 72.56mm PYSpeed Recommended Size: F10 (non M) - 20"x8.5" ET30mm Front - 20"x10" ET38mm Rear F10 (M5) - 20"x8.5" ET30mm Front 12mm spacer - 20"x10" ET38mm Rear 15mm spacer |
| Bookmarks |
