2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Wheel guru's need your help Forgestar CF10
      07-11-2013, 02:57 PM   #1
XDEEDUBBX
XDEEDUBBX's Avatar
69
Drives: 535I
Whats up guys, im planning on getting some new wheels to replace my old ones. Im currently running Forgestar F10's in 20x9 + 20 something 245/35 and 20x10.5 +40 something 285/30. Im looking into getting a set of CF10's but I need help with fitment. I want to go as aggressive as I can with out rubbing. Is 20X11 with a higher offset? Yes I will be utilizing my current tires as well. Any and all help will be appreciated.
Bryan
      07-11-2013, 03:29 PM   #2
LACSTER
Drives: Hybrid
20x11 et40 will be flush. You can go 20x11 et34 and that will poke about 6mm but with the
285's it will have some stretch which will be perfectly fine!
      07-11-2013, 03:46 PM   #3
XDEEDUBBX
XDEEDUBBX's Avatar
69
Drives: 535I
thanks Lac, great help as always. Will the rears rub? How about the fronts, what size?
      07-11-2013, 03:51 PM   #4
LACSTER
Drives: Hybrid
20x9 et13 is super flush almost poking a bit. I don't recommend you going that low.
Be safe and go with a et18 or so.
      07-11-2013, 04:22 PM   #5
XDEEDUBBX
XDEEDUBBX's Avatar
69
Drives: 535I
OK, so your recommending these sizes:
fronts: 20x9 +18
rears: 20x11 +34
No rubbing on my H&R drop?
      07-12-2013, 01:10 PM   #6
Felgen-Garage
Drives: BMW F11 530d Touring
This is 10x20 ET27 and 11x20 ET35 with 255/35-20 and 285/30-20 Michelin PSS
      07-12-2013, 02:59 PM   #7
XDEEDUBBX
XDEEDUBBX's Avatar
69
Drives: 535I
any rubbing? what suspension?
      07-12-2013, 03:13 PM   #8
LACSTER
Drives: Hybrid
      07-12-2013, 04:55 PM   #9
Felgen-Garage
KW Var.3 coilover and no rubbing at all
      07-12-2013, 06:20 PM   #10
remmib
remmib's Avatar
Norway
1643
Drives: 2013 F10 520d M-Sport
I've got 20x9 ET26 and 20X11 ET46, tires are Michelin PSS 255/35 + 295/30 and KWv3 drop. No rubbing
      08-14-2013, 10:41 PM   #11
Grumpy514
Grumpy514's Avatar
Drives: 2022 M3X
Perfection!
Car should of came like this from factory.
      08-14-2013, 10:59 PM   #12
Grumpy514
Grumpy514's Avatar
Drives: 2022 M3X
Perfection!
      08-15-2013, 02:56 AM   #13
decoy1116
Drives: 2011 BMW 535i
2011 BMW 535i  [0.00]
xdeedubx... I think the CF10's come in 21's... ever consider that?.. =)
Click here to join the >>>> BMW F10 5 Series Crew
      01-27-2014, 01:35 PM   #14
Black Ghost
Drives: F10 LCI
hey Bryan,
Did you ever decide on an offset for your wheels? I just got a 535i and wanted to run a 20x9 , 20x11 set up with a H&R drop. Wanted to see what you ended up doing.
Any help is appreciated. Thank you!
      01-27-2014, 01:46 PM   #15
LACSTER
Drives: Hybrid
Originally Posted by nicholasyou View Post
hey Bryan,
If you look up on this thread a bit forum member @remmib is running the exact wheel width you're inquiring about.
      06-13-2018, 01:34 AM   #16
trbo_bmw
Drives: 2011 535i
I know you don’t have these wheels anymore but do you remember what face these were? Semi, deep etc
      06-13-2018, 06:36 AM   #17
remmib
remmib's Avatar
Norway
1643
I do have the same wheels, and I believe the face profile is the medium one.
