2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Setting HVAC to Recirculate
      07-21-2013, 01:09 PM   #1
dbs600
Drives: 2011 750LXi Individual
Does setting the HVAC system to recirculate air help with making the AC any colder?
dbs600 is offline
      07-21-2013, 01:56 PM   #2
AP
AP's Avatar
Drives: F10 530d Msport
yes, but the car should do that automatically for you if it needs to. If it does that it won't do it for ever though, just to get he temperature down if its very hot inside.
I'd just set the temperature to your desired settings and leave everything on auto and let the car handle it.
You might consider change the air intensity setting up a level or two if you're preferring more of a air flow.
Are you having any issues in particular, not cooling down enough?
AP is offline
      07-21-2013, 02:50 PM   #3
dbs600
Thanks for this insight, AP!
Yes, not sure, but my AC doesn't feel as strong as it used to be...
dbs600 is offline
      07-21-2013, 03:20 PM   #4
AP
AP's Avatar
How old is the car?
It might just need re-gassing as the gas will leak over time. Best to make sure its used at least once a week.(Wasn't off over winter was it?)
On all of the cars I've had , I've generally had the air conditioning regassed every 2 years just before the summer kicks in to make sure its at its best.
If its nice and cold already it might just be the intensity. just up the level a step or two. When I picked up my car it was set at the lowest level I thought it wasn't much good. I've got mine set in the middle setting and this seems fine. Also silly question but I'll ask anyway! You have got the dial for face vents set to the blue for the coldest setting?
AP is offline
      07-21-2013, 04:13 PM   #5
dbs600
How old is the car?
It's a 2011 750Li xDrive and yes, the center vent dials are set to blue.
It's already cold, but but my AC doesn't feel as strong as it used to be...
dbs600 is offline
      07-21-2013, 04:38 PM   #6
Luigi524TD
Drives: 2013 535 xDrive
Have you had the under-hood filters checked and replaced recently? If they are dirty your ventilation (air flow) may be reduced.
My opinions are free - you'll get exactly what you pay for!
Current:
2013 535xDrive
1998 Z3 2.8
2007 Rav4 V-6 AWD
Luigi524TD is offline   United_States
      07-21-2013, 05:52 PM   #7
dbs600
No; haven't checked; thanks for the insight!
dbs600 is offline
Forum Jump
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
