2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions DIY F10 535i OEM M5 diffuser retrofit with Foot Trunk Release Comfort Access
      09-09-2013, 08:13 PM   #1
gre8tw8LL
Drives: 2012 F10 535i
UPDATE as of 10/13/13... See Additional pix after Step 13
This is my first time posting a DIY so please be gentle. i'll try t be as detail as possible and excuse me with the grammar issues if any.
First of all, you must have the M-sport rear bumper from what I gathered after reading numerous post. FYI, also, your F10 must be at least a 2012+ model as I believe the foot trunk release comfort access was not offered in MY2011.
Tools/materials needed:
- Dremel
- 5/16 socket wrench
- Velcro
- zip ties
- Blue painters tape (optional)
Step 1:
Lock your doors with the key fob and keep it away from the car so no electrical devices will be activated which will cause battery drainage. Next remove the diffuser
Step 2:
Take a look at what you have to deal with. The image below is the plastic piece which is already slightly trimmed on the bottom yet I haven't removed any of the comfort access module or TPMS module.
Step 3:
Locate Comfort Access Module
Name:  Comfort access module.jpg
Step 4:
Locate Comfort Access Sensor
Name:  Comfort access sensor.jpg
Step 5:
Locate Comfort Access Antenna
Name:  Comfort Access antenna.jpg
Step 6:
Locate TPMS module
Name:  relocated TPMS module.jpg
Step 7:
Remove the TPMS modules from its holder along with the Comfort Access leave them hanging so you can start cutting the plastic. Also remove the Comfort access sensor by unplugging it and remove comfort access antenna by removing the 7 circular tabs. you'll have to pull very hard but be careful not to damage the antenna. This picture shows all the trimming done as necessary as I forgot to take a picture prior to it.
Name:  Modules hanging.JPG
Step 8:
Start dremelling a long line across all the holes. See 2nd to the last picture
Step 9:
It should look something like this once you cut everything. Sorry for the dark picture as I was working on it at night.
Step 10:
Connect the middle insert diffuser with the big piece of the diffuser. try to insert it in after all the cutting from the plastic. You'll noticed snapping in the middle insert is a little difficult depending how well you cut the plastic. You may need to cut little rectangles for it to fit in properly as seen in my pix
Name:  cuts to fit middle insert.JPG
Step 10:
Tape up the TMPS module on the metal rebar located behind the bumper. Secure it with painters blue tape or velcro and reconnect the wire to the module
Step 11:
Velcro the Comfort Access module on the section where the spare tire would be placed
Step 12:
Tape down the Comfort Access sensor towards the bottom of the middle insert of the diffuser then the comfort access antenna right above it. Connect the Comfort Access sensor and antenna wires back up the Comfort Access Module
Step 13:
snap the entire diffuser together and be sure to screw in the 3 metal screws that goes under the black middle insert and place zip ties in the pair of holes which overlap the big diffuser as the plastic push screw will no long keep both pieces together. If not, your entire diffuser will fly off on the road as I just experienced it today. SMH
Hope this helps and sorry for the next 2 images. I dunno how to delete them but you'll noticed one of the images shows how I was dremelling across the comfort access sensor area.
Good Luck and let me know if you need any help
UPDATE as of 10/13/13......................................
Final product w/Litespeed exhaust. Sorry if its hard to see the angles of the diffuser but all I have to see is, Titanium tips on black diffuser is awesome!
2012 535i Alpine White | Oyster Black Dakota Interior | Hamann Front Lip | LiteSpeed Catback Exhaust | M5 Diffuser| Painted Calipers & Reflectors | Black Gloss Grill | LED interior lights | Piaa Plasma Yellow Foglights | Born on 1/30/12
      09-09-2013, 10:47 PM   #2
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Nice write up.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
      09-16-2013, 04:53 PM   #3
Don Juan
Don Juan's Avatar
Drives: 2016 X5 M Sport
pls put mre pictures with the installation of the diffuser and the final outcome :-)
Don Juan 2016 X5 35i M Sport Premium Package,Napa Terracota Leather, Multi Comfort Seats, shades, Aluminum Interior, Rear view camera, HK Premium sound,IND Painted reflectors (front & Back), M Performance Gloss Black Grills , JB4 Stg2 Map 6,BMW Intake)
Retired 2013 535i M Sport Retired 2011 X5 35d Sport Retired 2007 335i M-Sport Retired 2005 550I M-Sport
      09-16-2013, 05:13 PM   #4
MELLOWYELLOW06
MELLOWYELLOW06's Avatar
53
Drives: 2013 535 MSport & 2012 650i
great suggestion and great write up
Thanks for this
Will give alot more confidence
      10-14-2013, 02:06 AM   #5
gre8tw8LL
New Pix added
      10-14-2013, 11:18 AM   #6
Don Juan
Don Juan's Avatar
THanks for sharing..I'm so incline on doing this and love those tips...can you share where did you get thema dn the size ?
Also did you put them on the stock exahust or bought new ones ? I would like to keep my stock exhaust with the M5 rear diffuser..it seems there is space there to move them a bit inwards...any more pics of the layout from the bottom?
Great job there!!
      10-14-2013, 12:06 PM   #7
gre8tw8LL
Great job there!!
I purchaed a full catback exhuast system from Litespeed as seen on the exhaust tips. I wasn't a big fan of the tips and my only options were black or titanium tips. I figured i already had stock black tips which came with the M-sport pkg, why not just try out the Titanium. If the titanium tips didn't flow, i could always go to a muffler shop and replace the tips with polish ones. But honestly, with a black diffuser and titamium tips, i'm so glad i went this route.
FYI, from my understanding on reading other post, you will not be able to use the stock muffler and add dual exhuast tips as theres no room. Everyone one been either getting M5 OEM mufflers or purchasing Megan Racing axel back mufflers.
Alignment of the muffers was very tough because of the existing hangers to hold the muffer and working with twisting the pipping as its bent. The tips are staggered and tried to align the outter tips flush with the diffuser.
      10-14-2013, 12:26 PM   #8
shawnsheridan
I thought the same thing, and I bought E63 M6 Muffles for my F10 535i, but I wanted to use Cyba Double Layer Black Chrome Quad Tips on them. The problem is the M6 Mufflers have two individual outlets and the Cyba Tips have one inlet and dual outlets, so they cant be used. (I still have the M6 Mufflers is my garage if anyone is interested in them.)
I ended having a muffler shop cut the OEM mufflers near flush at the muffler, and the Cyba tips near flush at the inlet, and it fits perfect. I am using an OEM 550i Diffuser, and the tips do not stick out too far from the rear bumper as I have seen on some.
Here are some pics:
      03-30-2014, 10:57 AM   #9
Cquilichini
Drives: 2012 F10 535i M Sport
Is your foot trunk release feature still working? Mine stopped working after installing the m5 diffuser.
      03-30-2014, 01:53 PM   #10
gre8tw8LL
Suggestion: Double check to see if the sensor and antenna are connected to the module. Also make sure the placement of the 2 above items are placed how I have it posted in my pix.
Worst comes to worst sceniro, hopefully the sensor and antenna wernt damage during removing and reinstalling.
Good luck
      03-30-2014, 11:13 PM   #11
Cquilichini
Will check for that, thanks!
      08-31-2014, 11:24 AM   #12
SonicEndeavor
Drives: 2014 535i MSport
Nice writeup!
Here's a link to another post where they found the part number for the M5 adapter/absorber, which eliminates the need for any cutting in order for the Comfort Access to continue working with the M5 rear diffuser.
http://f10.5post.com/forums/showthread.php?t=950378
2014 LCI 535i /// M-Sport - SAT, Premium package, HK Audio, Drivers Assistance, Top/Side/Rear cameras, multi-contour seats.
Mods: V2 coilovers, Michelin PSS, Opticoat Pro, Quad black chrome exhaust tips. Coded several features myself.
      11-12-2017, 04:05 AM   #13
dsolis88
dsolis88's Avatar
Drives: 2011 528i Space Grey
So I can't install an m5 diffuser on my 2011? Why?
      11-12-2017, 01:40 PM   #14
SonicEndeavor
Many have done it to the F10 MSports. Why do you think you can't?
      11-12-2017, 01:57 PM   #15
dsolis88
dsolis88's Avatar
"FYI, also, your F10 must be at least a 2012+ model as I believe the foot trunk release comfort access was not offered in MY2011." - OP
He's right, I have an '11 with no comfort access. I just don't understand why that means I can't put on an m5 diffuser
      11-12-2017, 02:33 PM   #16
SonicEndeavor
All this means is that if you don't have CA, you don't have to worry about diffuser mods or moving the CA sensors when you install the M5 diffuser.
      02-28-2018, 03:58 PM   #17
Dominic_M
Dominic_M's Avatar
Drives: 08 ///M3
do we have a foot trunk release?
i had no idea... I just purchased my 2015 F10...
i will have to do some reading.
2008 E90 M3 SPARKLING GRAPHITE METALLIC
