2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes My solution to ditching my run flats
      01-19-2014, 11:12 AM   #1
bake
bake's Avatar
Drives: 2011 F10, 2013 E93
After a bit of research and test fitting, I discovered that the space saver rim/tire from an E60 5 series fits on our F10's with a 10mm spacer. Since I already had spacers I started my search for an E60 space saver wheel/tire. Two weeks later I found a brand new one on EBay for $100. Also picked up this spare tire tote for $15. Now all I need is a BMW emergency jack or a small scissor jack to keep in the trunk for emergency tire changes. If you are interested in doing the same, the part number for the wheel is 36116758778.
Bake
2011 Alpine White on Black 535i M-Sport
2013 Space Gray on Fox Red M3 Vert
      01-19-2014, 11:17 AM   #2
camnhoj
camnhoj's Avatar
Ireland
10
Drives: 2012 f10 520d M sport
Nice piece of research !
      01-20-2014, 03:30 PM   #3
tree
tree's Avatar
41
Drives: 2016 Alpina B6
Well done.
      01-20-2014, 10:37 PM   #4
Lee
Germany
64
Drives: '17 X5 50i/'01 Z3
Funny, our trunks look about the same, although I bought my F10 spare and mini jack from the dealer here in Germany.
      02-25-2014, 06:25 AM   #5
TheGr8Swami
TheGr8Swami's Avatar
Drives: 2012 550i M-Sport w/XDrive
Excellent find! Those scissor jacks will kill you, but a small floor jack from a local auto parts store and you'll be quite pleased...
2012 550xi MSport - everything but TV's in the head rests!
      02-25-2014, 10:36 AM   #6
bake
bake's Avatar
I want to get something that fits in that small cubby hole in the trunk though. I have a small floor jack but it doesn't fit in there. The BMW jack should fit, but it is a POS.
Bake
      04-17-2017, 07:39 PM   #7
Ironman273
Ironman273's Avatar
Drives: 2011 BMW 550i 6MT
I know this is old but I recently ditched my runflats also. Did you find a good solution for a jack?
      04-17-2017, 08:59 PM   #8
big_boss
Frank
Drives: 535i M Sport
Good find. I also jst ditched my runflats.
      04-18-2017, 09:20 AM   #9
bake
bake's Avatar
I just bought a cheap scissor jack from Amazon. Not great, but at least it doesn't have plastic parts like the BMW POS jack. Luckiliy I haven't had to use it yet. I have a couple good floor jacks in my garage that I use for wheel changeovers, so the scissor jack is just for emergencies.
Bake
      04-18-2017, 08:06 PM   #10
sesh1957
Drives: 2012 535i xdrive
Nice, but the rolling diameter of the e60 is 25.5", an inch shorter than stock tires? Tire Rack has a 135/90/17 that will do the trick, $78.
Just put Sumitomo 245/40/19 on mine, went for the value/best rated, $140 a tire, ($122 at tirerack.com) they are much softer than the run flats and handle well, no noticeable performance loss. Probably will stay with these since they are rated high for winter as well, and then replace at 70% of tread wear, at this price why live that last low tread performance in snow or rain.
May try the spare above, currently I have an air pump and plug kit in the truck, don't want to use flatfix or Slime as they might damage the tire sensors, hopefully just pump and run to the nearest Town Fair Tire, where I bought the Sumitomos.
      05-08-2017, 09:39 PM   #11
Merciless58
Merciless58's Avatar
66
Drives: 2012 F10 M sport
Bump.
      05-09-2017, 12:57 AM   #12
S.Hunter
Drives: 4th-Gen F-Body
New here....
Hey, I'm looking into getting an F10 535i.
I was doing some research, and found out about the lack of a Spare Tire in the trunk. It's a shame.... All the 5-Series before the F10's had the whole kit and caboodle. My Brother has a 2002 E46. He has a Full Size Spare, Jack, Lug Wrench, even Wheel Chocks. And a Tool Kit.
I've also found out that the Battery takes the place of where the Spare used to go in the E60.
After looking at Pictures, is it possible to put the Donut Spare in the space where the Battery is? I mean, if someone were to remove the battery/relocate it.
Just for a little background, I'm a 4th-Gen F-Body guy. I'm familiar with all the forums and what people do. It seems people here are doing the same stuff, more or less. (Cat Back Exhausts, parting out cars, Custom Wheels, Etc.)
These are really neat beefy cars, even compared to their predecessors.
I've found out about the Fuel Pump connector recall/issue, and I have a different perspective on why it may be happening. [I work on Computers & Electronics]
I would like to know a lot more about these cars. I am only familiar with the E46, as my Brother has one and I've worked on it. Smoooooth I-6's, love the sound and feel! Nothings like an LS1 V8, that's for sure! [Granted, HP & Torque are higher on the LS1's]
      05-31-2017, 08:59 AM   #13
BMelchner
Drives: 2012 BMW 535i Xdrive MSport
I'm in the same boat. Run the same Sumitomos. I got them from Town Fair. they matched the price and gave me the roadside warranty and 50,000 mile guarantee. Just have to get it to them every ~5,000 miles for free rotation and ~12,000 for an alignment. Which I'm good with since they are right next to my office.
      05-31-2017, 09:02 AM   #14
BMelchner
Trying to get the wheel/tire combo that matches closer to the true size of the OEM wheel/tire.
Looking at this for the wheel $60 : https://www.ecstuning.com/b-genuine-...l/36116758778/
And this for the tire $74 : https://www.tirerack.com/tires/tires...omCompare1=yes
Tire size difference is -0.15". Which is within tolerance.
Thoughts?
      06-01-2017, 07:37 AM   #15
corys530
corys530's Avatar
20
Drives: 2012 535i
thats great if it true but when i run the Does this fit my car
Says Does Not Fit
2012 f10 535 ?
Thoughts?
2001 530i
2004 330i
2006 X5 4.4 the beast
2014 328i
2012 535i
      06-01-2017, 09:59 PM   #16
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
Nice 1
IG: @bmwdoubles
      06-04-2017, 07:18 PM   #17
sesh1957
I have looked for several hours for a steel rim, all the 5 x 120mm bolt diameters have an undersized center hole (we need 72.6mm), offset should not be a problem with the thin wheel, but can't find one.
It is a shame to pay the big bucks for a spare. Saved one of my better run flat tires, maybe I can find a trashed 19" rim for a spare.
      06-05-2017, 06:54 PM   #18
sesh1957
The mid 2000 X3 has the same 5X120 bolt pattern with a 72.6mm bore, so it's steel rim fits (BMW 36-11-6-758-778), with a 135/90/17 spare from tirerack, we get the right rolling diameter, $58 and $78 cost online respectively.
      11-24-2018, 02:48 PM   #19
Rainers100
Drives: 2015 BMW
Bake
When purchasing a 10 mm spacer do I need a certain hub size and will standard lugs work or do I need extended lug nuts?
