2010 2011 BMW 5 Series Forum F10 21'' Staggered wheels on X-Drive GT? |
03-30-2014, 09:59 PM | #1 |
Rep 5
Hi All,
I was wondering if I could run a staggered set up on my 2011 GT X Drive. The factory set up is squared in all four corners with 245 45 19. I'm considering a new oem bmw staggered set up with: 275 30 21 245 35 21 Would I have any issues with the x drive system? I ran the calculations and the rolling diameter is nearly equal. Anyone run this set up on the GT xdrive? |
03-31-2014, 05:36 PM | #2 |
Like No Other.
561
Rep 1,833
That setup should be okay. Just make sure you get low offsets, since the GT is quite wide.
Here are my offsets (rears are perfect, fronts could use spacers): Front: 20" x 8.5" ET20 (could use 10mm spacers) Rear: 20" x 10" ET25 (perfect offsets with no rubbing)
BMW 550i GT LCI (w/ a VW MK7 daily)
personal IG: http://www.instagram.com/TheBlackGT my work: http://www.instagram.com/CorsaAutoDesign |
Roxy210.00 |
03-31-2014, 09:08 PM | #4 |
Rep 5
I'm going with the OEM BMW style 312. Apparently these came with differing offsets, so I will have to check which offsets are on the ones that I am buying. I will find out and post to see if it would be acceptable.
I have seen these wheels on a 7 series and they look fantastic! Last edited by 535ixgt; 03-31-2014 at 09:17 PM.. |
04-01-2014, 11:25 PM | #5 |
Rep 34
Has anyone seen the V-Spoke 356 Liquid Black Wheels on the M6? These would look wicked on the GT.
http://www.bmw-post.com/2012/09/28/l...at-paris-2012/
550i GT Black Sapphire Metallic w/ Ivory White and Black Nappa Leather, Cold Weather Package, Sport Package, Black Foose Legend Staggered 20s, DVDinMotion software, H&R Lowering Springs, Black Kidney Grill swap, and the Dinan Stage 2 Performance Software: 501 HP @ 5000 RPM / 580 FT-LBS @ 3500 RPM (w/ Cobra iRadar)
