2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes 22 inch Gianelle Puerto
      06-15-2014, 08:00 AM   #1
westb
Drives: 2014 535i xDrive
2014 535i xDrive Luxury Line
My first mod....more to come
      06-15-2014, 10:00 PM   #2
550toronto
Drives: 2014 F10 550ix
Sweet! I have the same in black, with the ball cut on my 550
      06-19-2014, 01:01 PM   #3
bake
bake's Avatar
Drives: 2023 G05, 2013 E93
You will need coilovers and be willing to dial them way down in order to be able to pull of 22" wheels on an F10. Wheel design isn't bad though.
Bake
2013 Space Gray on Fox Red M3 Vert
2023 Individual Dravit Grey on Extended Tartufo X5 M50i
      06-19-2014, 01:16 PM   #4
MELLOWYELLOW06
MELLOWYELLOW06's Avatar
340
Drives: 2020 M8 & 2022 X& M50i
Nice looking rims
But as previous post mentioned, needs to be a bit lower
      06-19-2014, 02:33 PM   #5
westb
Thanks! I sent you a pm about coilovers
      06-19-2014, 02:34 PM   #6
westb
Originally Posted by MELLOWYELLOW06
Nice looking rims
Going lower scares me.....rubbing!
      06-19-2014, 02:52 PM   #7
MELLOWYELLOW06
340
It shouldn't
What are your offsets and tire sizes?
      06-19-2014, 02:55 PM   #8
MELLOWYELLOW06
340
30 up front is safe
And 38-40 out back should be safe as well
      06-19-2014, 03:02 PM   #9
westb
30 up front is safe
Front 34 offset - 245/30/22
Rear 38 offset - 295/25/22
      06-19-2014, 03:05 PM   #10
westb
30 up front is safe
Rubbed once at high speed on a big dip. My biggest issue is that my wife was in the car. So now my car is off limits to the kids..lol
      06-19-2014, 03:19 PM   #11
MELLOWYELLOW06
340
I'm assuming out back?
40 may be safer on 22
      06-19-2014, 04:01 PM   #12
westb
Yes rubbed on the right rear
      06-19-2014, 09:33 PM   #13
bake
bake's Avatar
We need to know more than just the offset, what is the width of your rear rims?
Bake
      06-19-2014, 09:34 PM   #14
westb
22x10.5
      06-20-2014, 09:17 AM   #15
LACSTER
Drives: Hybrid
Unfortunately there is no coilovers available for the xdrive at this time.
I'd recommend some H&R springs for now. Please lower it asap!
      06-20-2014, 01:37 PM   #16
westb
My rears are slightly beyond flush so I have to do something about that before I would be comfortable with a drop. They occasionally rub now
      06-20-2014, 02:17 PM   #17
Dan1416
Dan1416's Avatar
50
Drives: 2013 528 x-drive
They should camber in slightly once you lower. If it's not enough you could always have a little bit of negative camber added. Or you can have up to 3mm safely shaved off the hub. But I think you'll be fine after lowering
      12-13-2014, 11:49 AM   #18
westb
New lip and painted reflectors
      01-02-2015, 05:21 PM   #19
weezie
weezie's Avatar
Drives: 2015 BMW 535i M-Sport
2015 BMW 535i  [0.00]
What kind of front lip is that?
      01-02-2015, 10:30 PM   #20
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Just my opinion but I think the wheels are too big? If they are rubbing on dips at that height what happens when you lower it?
      01-03-2015, 08:52 AM   #21
westb
Kellener Sport http://www.bavauto.com/shop.asp
