2010 2011 BMW 5 Series Forum F10 Front Strut Torque Specs |
11-25-2023, 09:45 AM | #1 |
Rep 132
I need to replace front struts protective booths and bump stops. I searched the web to figure out torque specs for the struts mounting hardware with no definitive results. looking for torque specs on strut to wishbone (C & D), strut center nut (B) and strut to body (A) as shown in picture below. Thanks in advance. Regards
11-27-2023, 01:46 PM | #2 |
Rep 2,595
C - D: 90nm + 180 degrees. Must be torqued in the normal position, and hardware should ideally be replaced due to the torque-to-yield spec
B: 34nm A: 28nm
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial |
Conserve189.00 ChiltiCoatl891779.50 |
11-27-2023, 06:39 PM | #3 | |
Rep 132
Regards, |
11-27-2023, 09:00 PM | #4 |
Rep 2,595
Use the jack to push the wheel carrier up. That's what I do. Or just put jack stands under the wheel carrier - up to you
2015 BMW 535xi
