2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications 535d VNT boost problem?someone knows the problem?
      05-10-2024, 05:18 AM   #1
mariodix98
Drives: BMW 640d 2012
Hello i have an 535d and i have some fault codes that says Boost pressure actuator VNT. The car has bad boost up to ca 2500rpm and after that it goes like crazy.
I think it’s the electronic wastegate on the small turbo. Do someone know what it can be?
The codes:
292200: boost pressure actuator (VNT): position sensor in the boost pressure actuator defective or undervoltage.
27B900: exhaust pressure upstream of the turbine, plausibility: difference between measured and calculated exhaust pressure to low.
