2010 2011 BMW 5 Series Forum F10 What material are original bmw brake pads? |
09-08-2019, 10:08 AM | #1 |
Rep 305
Needing to replace my brake pads. One website says ceramic the other says semi-metallic, which one is right? Any suggestions on which brand or pad material would be good. Thanks
09-08-2019, 03:00 PM | #2 |
Rep 5,409
Ceramic is good for low dust and noise, but I'm told they are harder on the rotors. I had ceramic pads on my last car and didn't notice any excessive rotor wear. Akebono seems to be a favorite amongst DIYers.
FrannieMoral20176.00 |
09-08-2019, 03:12 PM | #3 |
Rep 11
Heard BMW made the switch to ceramic on F10 due to dust and noise complaints. For 528 for sure they are ceramic as I recently replaced with semi metallic and they bite alot harder now compared to OEM ceramic pads but also now theres brake dust.
09-08-2019, 11:31 PM | #4 |
Rep 305
ezaircon4jz- did you go with akebono when you replaced yours? Did you feel any difference in braking performance or pedal feel?
Frick- did you hear a lot of brake noise with semi-metallic pad. What brand did you go with? |
09-09-2019, 02:59 PM | #5 |
Rep 18
I actually had the opposite experience of Frick, although mine is a 2015. My originals were semi-metallic and I switched to the Akebono ceramic pads with Zimmerman coated rotors. I have experienced a very slight decrease in initial bite compared to the stock metallics but nothing major. Braking was quiet before and has remained quiet. Very low dust, almost non-existent.
09-09-2019, 04:31 PM | #6 | |
Rep 5,409
Were I to do the brakes I would most likely use the Akebono pads as they get such good reviews among various manufacturers. |
09-09-2019, 09:13 PM | #7 |
Rep 384
My new 2016 535d came semi metallic brake pads. However, as recommended by the majority of postings, go with ceramic pads. Aside from less dusting, they are far easier on rotors (the expensive component of a brake job). While commonly claimed that semi metallic pads have better initial bite, having changed to ceramics, I would dispute that.
ezaircon4jc4559.00 |
09-09-2019, 10:12 PM | #8 |
Rep 305
Thanks for all the help and suggestions. I went with a brand called textar from fcp euro. They listed it as am OE product so I'm thinking they are ceramic pads. Anyone used that brand yet? I went with fcp euro because if their life warranty.
09-10-2019, 07:16 PM | #9 | |
Rep 11
sorry for the late reply didnt login until now... originally replaced the pads and went with OEM which in my case were ceramic pads. Hated the bite, loved the no dust. Researched and ended up swapping the pads again but with ATE branded "GF"rated pads which are semi-metallic. Still newly installed with under 5k miles but no noise at all but the braking has greatly improved on my vehicle with these pads to where I finally feel confident in these brakes. Last edited by Frick; 09-21-2019 at 10:32 AM.. Reason: GF rated pads not GG* |
09-19-2019, 01:42 PM | #10 |
Rep 373
Yes, Textar is probably not the most famous, but is a pretty popular and respected brand in Europe. If they are "epads" they are ceramic. I'm quite happy with them, brake dist is like 10% of the OEMs.
09-19-2019, 05:47 PM | #11 |
Rep 1,876
I would be interested in some citations for Frick's statements that "for the F10 BMW switched to ceramic".
I've been observing for years that my F10 has way less dust than any previous German car so it makes sense, but no one along the way has ever come up with a document or part numbers confirming it. I'm curious... |
09-19-2019, 07:48 PM | #12 | |
Rep 68
Drives: 2011 535ix M-sport
'11 535ix M-Sport - FMIC, CP, BM3 engine & trans, CQuartz Finest Ceramic, Poly tension bushings, Dynamic, Active Roll, Flappy paddles, HUD, Premium(s), Cold, Convenience, 5-cameras, 4-zones, Driver's Assist, Auto high, Hex trim
'92 850i, '08 XC90 3.2 Past: '93 525i w/ S38B36 M5 engine/trans swap, '99 540i/6sp Sport, etc. |
09-21-2019, 09:34 AM | #13 |
Rep 11
Mine is a 2014 528 xdrive. Non high speed brake option. I researched some time online on various BMW forums and seen multiple posts of members state their pads were ceramic. I dont have anything from BMW stating that but if I find it I will post it.
-brake dust - compared to my oem pads its a big difference. I previously had a n54 335 sport package, b6 S4, and currently drive a B8.5 S4 so the heavy brake dust and aggressive braking is what Im used to and dont mind it too much. Now between my OEM and ATE metallic, the dust is a huge difference but so is the high speed braking at least for me. Because I was testing the metallic pads I never swapped the rear OE pads. I have washed my wheels around 2 weeks ago and the rears still look clean and the fronts look very dirty lol. Again fronts do more braking but there is for sure a considerable difference in dust. Just have to go with what you prefer. Dust is also darker in color compared to oe pads which were lighter and not as visible. |
09-21-2019, 11:29 AM | #14 |
Rep 1,876
On my F10, I have always found the initial cold "bite" OK - i.e. those first couple of stop signs on a commuting drive, cold engine, nothing aggressive.
What I don't like is that brake torque does not increase with pedal pressure as quickly as I'd like, compared to every other German car I've owned/driven. I've found that 5 series in general have "soft" brakes compared to, say, 3s and I'm 95% certain it's just design philosophy. Every control input on a 5 is soft, smooth, long throw, and luxury compared to a 3, and I expect the 7 is even more so. Why would the brakes be any different? E39s had soft brakes compared to E46s and E90s too. (but not compared to Toyota Siennas) So, I'm at a point where I would consider trading dust for more confident stopping. Too bad I already ordered OEM fronts. We'll see if those Pagids are ceramic, semi-metallic or organic I guess. Before going German I had one stint with PBR/Axxis/Repco Metal Masters installed on the fronts of an Acura. No more brake fade, and really great braking when you got to the 4th or 5th hard stop, but the first couple of stops of the day were not very good. |
12-21-2020, 03:19 AM | #15 |
Rep 30
Can't decide on which pads to switch to.
My current factory pads seem to be Textar. I would call it low dust. I am not ready to go with lower cold bite though. I wish I know if the stock is ceramic, so I can decide if I should go with epads vs regular textars... |
12-21-2020, 06:49 AM | #16 | |
Rep 1,876
Take a look at the temperature/friction ratings, they'll look like EE, FF, GG, FG etc...) They give some insight into the temperature and friction properties, although it's quite approximate. https://idpartsblog.com/2019/04/11/w...-ratings-mean/ https://www.hotrod.com/articles/disc...des-explained/ |
12-23-2020, 10:32 PM | #17 |
Rep 1,044
I’ve been a fan of the Textar ePad for some time now. Good initial bite, low dust and rather quiet. I did a thorough write up on them when I had my X5 35d and was towing often. Overall very good pad.
