| 05-09-2016, 06:58 PM | #1 |
Rep 751
Drives: '12 BMW AW 550xi
Tires for HRE FF01
Hello everyone, I'm waiting for a set of HRE FF01 but I can't decide which tire sizes to choose. For the front I'm going with 20x9 (245/35/20). What about the rear? Can I run 20x10 (285/30/20) without any rubbing? The car has ACS springs and xdrive btw. Thanks in advance!
'15 Porsche Macan S / Black & Garnet Red / 20" RS Spyder Wheels / CF trim / Red Calipers / Black Rear Badge.
'12 AW 550xi / Dinan S2 / Arkym CF Spoiler / 3D Design Style Splitter / Eisenmann Race Exhaust / 20' HRE FF01 / ACS Springs / CF Grill / CF 3D Design Diffuser / Blue Calipers... |
| 05-09-2016, 08:11 PM | #2 |
Rep 2,419
Yes, 285/30/20 will work fine. Gtmassive, who has since turned in his car off lease, was running those sizes on his XDrive 535 with ACS Springs. I also run the same setup, but my car is not XDrive.
Bake
2013 Space Gray on Fox Red M3 Vert 2023 Individual Dravit Grey on Extended Tartufo X5 M50i |
| 05-10-2016, 05:05 AM | #3 |
Rep 29,227
What's the offset in the rear? If it's 40ish, 285 will work.
![]() F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
| 05-10-2016, 06:16 AM | #4 | |
Rep 751
Thanks
| 05-10-2016, 07:08 AM | #5 |
Rep 751
285 is going to be wider, but is it possible to tell the difference between 285 and 275?
| 05-10-2016, 08:37 AM | #6 |
Rep 2,419
I am running 20x10 ET41 with a 10mm spacer (so effective ET31) and I don't have any rubbing issues with ACS springs.
Bake
| 05-12-2016, 10:12 AM | #7 | |
Rep 751
Thanks
| 05-13-2016, 08:55 AM | #8 |
![]() 173
Rep 1,317
yes, you can run 245/35/20 in the front and 285/30/20 in the rear. That is how i had it setup on my 535i xdrive and no rubbing whatsoever. I have BC forged wheels with the same specs as your and I also lowered.
The 245/35/20 will have a bit of stretched look to it though due to the 9" wide tires in the front but not issue in performance. |
