2010 2011 BMW 5 Series Forum F10 BMW 528 XI brake light bulb malfunction warning (request bulb type) |
10-16-2018, 09:35 AM | #1 |
Rep 15
Hi ~
My 528XI has warning message for right brake light bulb not working. warning is 'right two stage brake lamp malfunction' May I know which type is bulbs? Can I purchase from Amazon or ebay? do you guys know how to replace it or guide? many appreciate! Last edited by weiweinick; 10-16-2018 at 11:21 AM.. |
10-16-2018, 10:52 AM | #2 |
Rep 8,113
Which brake light is not working? The rear left, rear right, or rear center?
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 10-16-2018 at 11:06 AM.. |
10-16-2018, 11:22 AM | #3 |
Rep 15
10-16-2018, 11:25 AM | #4 | |
Rep 8,113
For example, when I look in my F06 (650ix GC) owners manual...it lists all of the bulb/lights for the rear tail light assembly. The f06 has TWO types of rear brake light bulbs...only one of them is easily replaceable (the inside bulb) and can probably be purchased just about anywhere automotive bulbs are sold ...and the other (outer brake light) is an LED. The owners manual also lists the (inside) replaceable brake light bulb's wattage and type:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 10-16-2018 at 11:40 AM.. |
10-16-2018, 11:34 AM | #5 |
Rep 15
10-16-2018, 11:42 AM | #6 |
Rep 8,113
See my post above (there may have been more added prior to your last post)...since your F10 and my F06 are generational "cousins"...there may be some very similar set-ups.
If you don't have an owners manual handy...just do a quick google/internet search for a BMW f10 5 series owners manual PDF"...then download or open it. You can then just do a quick search in Acobe Acrobat (probably the app that will open the PDF) and type "bulbs" to quickly find the rear tail light index and other info that may lead you to if your issue is an LED bulb or a simple replacement incandescent or halogen bulb. Are there any F10 owners reading this that can chime in with info? EDIT: I googled for an F10 owners manual...and just like I suspected...these generational "cousins" have a very similar set-up. It appears that you have an inner and outer brake light...and the inner light is replaceable (bulb is listed in owners manual...so should be easy to find at any auto parts store)...but the outer brake light is LED:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 10-16-2018 at 12:15 PM.. |
10-16-2018, 12:09 PM | #7 | |
Rep 15
other one 21-watt bulb, H21W. Last edited by weiweinick; 10-16-2018 at 12:15 PM.. Reason: add |
10-16-2018, 12:19 PM | #8 |
Rep 8,113
If it is the LED brake light that is out (not functioning)...then the fix may be a bit more complicated than the inner brake light bulb.
If it's the inner brake bulb that is out...then as listed in the owners manual...just type 21w h21w bulb into a google/internet search box to find vendors selling that bulb online. Or stop into your local Walmart/Target/AutoZone/Advanced Auto/Pep Boys/O'Reilly's/etc and go to the automotive bulb section to find a 21w H21W light bulb.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
10-16-2018, 12:30 PM | #9 | |
Rep 15
10-16-2018, 01:56 PM | #10 |
Rep 8,113
Good luck...and I do hope its the inner (easier bulb) that is causing your warning light.
10-17-2018, 11:11 AM | #11 | |
Rep 15
but in the morning, the alert is coming again when driving at the road. I am afraid the cops see and pull over.. I had search and find some guys have same problem they assumed lower temperature and wet air.. I have go to BMW store at weekend for checking. |
10-17-2018, 12:25 PM | #12 | |
Rep 8,113
EDIT: just did a google search for the H21w bulb...and it is a halogen bulb...but it does have a filament:
Tags |
528 xi brake light bulb |
