2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Brake fluid flush
      12-13-2020, 11:53 AM   #1
Dio781
Dio781's Avatar
Drives: BMW 535i Xdrive
Brake fluid flush
I own a 2016 535i Xdrive with 35k miles and looking to do a brake flush myself.
But I am wondering if is there a special procedure required to bleed the system once the system is broke open .
Or the normal procedure where someone pumps the pedal and I open the bleeder valve in each wheel is enough?
Thank you
DBM
      12-13-2020, 12:16 PM   #2
Surly73
Drives: '11 535xi 8AT KWv3 MPE MHD xHP
https://f10.5post.com/forums/showthread.php?t=1640750
Dio78110.50
      12-13-2020, 01:02 PM   #3
Unspec
Unspec's Avatar
1496
Drives: 2015 BMW 535xi
Need ISTA. People have reported spongy brakes if you do it without.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets
ISTA VM Setup/Tutorial
Dio78110.50
      12-13-2020, 09:30 PM   #4
Dio781
Dio781's Avatar
Really thank you
Just what I was wondering
Really appreciate all the help
DBM
      12-15-2020, 10:09 PM   #5
550iFreak
Drives: 2011 BMW 550i 6MT
Took mines into the stealership.
Pleasantly surprised that the service costed me $99.99
100 ish after taxes.
Worth a phone call to your local dealer. This is coming from a guy who did the valve seals himself on the 550i along with other major mods on the car lol.
      12-15-2020, 10:35 PM   #6
Sylverlee
Drives: 18 M3, 04 M3, 06 911, 14 RS5,
Is that a special price or daily? I think I paid $220 at my local dealer.
      12-16-2020, 05:26 AM   #7
550iFreak
Here in Daytona beach, they said that the price is ongoing. No special promos or anything. I’m sure the price differs from dealership to dealership but a couple quick phone calls between shops to compare prices may help. Then you can discuss with the shop of your choice to see if they can price match.
I guess I got lucky with mines since I did expect a price north of 200 because “stealership” lol.
Sad part was the service was cheaper than the hood struts that I needed that costed about 120 dollars per side.
On that note, 35 bucks on Amazon took care of that lol.
      12-16-2020, 12:18 PM   #8
Sylverlee
Some of the specialty BMW shops around my area don't even do the full ISTA process. Has anyone not done that that and still have successful results?
      12-16-2020, 01:46 PM   #9
n3985
Drives: a car
I DIY'ed my last 2 brake fluid flush the old fashioned way with a Motive bleeder without ISTA and no issues.
Arguably using ISTA/INPA to cycle the ABS/DSC/etc. systems is the best way but IMO for regular brake bleeds that did not introduce air into the system i.e. changed a brake line, then it is not needed.
      12-17-2020, 10:33 AM   #10
Sylverlee
Thanks for sharing.
      12-17-2020, 10:42 AM   #11
kohsin
Drives: 2013 F10 550ix
I did my brake fluid job with autophix 7910, it has abs and battery registration functions also.
It worked fine without any issues. Used one and half liter to flush/replace the fluid.
I don't think that you will have issues without abs but it sure gives me peace of mind.
      12-17-2020, 05:21 PM   #12
Dio781
Dio781's Avatar
Do you recommend Autophix for a DIY
I am looking for a scanner to perform the basic maintenance services like battery registration, EPB, code retrieval
DBM
      12-18-2020, 10:41 AM   #13
kohsin
I had the autophix for 6 months and it does have the basic functions like the rest plus the brake abs and battery registration. Especially I bought it for less than $80 with discount.
So yes, I recommend it. Of course, there is the Foxwell that you can research at a higher price.
