01-25-2016, 11:12 PM | #1 |
Rep 5,409
Steering wheel swap
For those interested in swapping the horrible base steering wheel for the sport steering wheel here is my successful journey...
I did the swap today. I got the wheel w/airbag from Lithuania so knew I was going to have an airbag issue. What I had to do was remove the entire airbag assembly from the old wheel to install into the "new". The cover comes off relatively easily (there is a bracket holding the mounting tabs in place that comes off easily) and the airbag itself is packed so well I had no issues getting it into the new cover. I initially thought all I would need to do is replace the ignitor but that turned out to not be the case. There is an additional connection to the airbag itself; which necessitated replacing the entire airbag. Replacing the entire assembly was pretty straight-forward and if you can get as far as replacing the steering wheel this extra step shouldn't pose a problem. Just pay close attention to what you're doing as you go. One hitch I found is the ignitor has a different orientation after reinstalling the ignitor into the new cover so the blue connector was a tad short. It did stretch enough to fit back into the connection. Here are some pics of the process..... Questions?? Ask away and I'll answer what I can!! Oh..... DISCLAIMER!!!!!! I bear NO responsibility for anyone trying this and having catastrophic results. This is MY EXPERIENCE ONLY!! Now that that's out of the way here are some pics of the process... UGH.... I can't post pics.. yet. I'll keep trying... GOT IT!!!!!! Last edited by ezaircon4jc; 01-26-2016 at 04:01 PM.. |
01-26-2016, 05:33 AM | #2 |
Rep 14,521
Curious to see what ur talking about as I did mine with no issues other than replacing the steering wheel controls with mine again. Get those pictures up cause it'll make more sense visually
01-26-2016, 07:51 AM | #3 |
Rep 492
I would also throw out there DO NOT TURN YOUR CAR ON UNTIL YOU RECONNECT ALL THE AIRBAG plugs! I found out the hard way and had an airbag light that would not go away until I had it reset. Unless you have the tool, you'll need to ask the dealer to reset which probably won't go over well.
01-26-2016, 09:30 AM | #4 | |
Rep 5,409
01-26-2016, 09:34 AM | #5 | |
Rep 5,409
01-26-2016, 09:44 AM | #6 | |
Rep 14,521
01-26-2016, 10:25 AM | #7 |
Rep 5,409
OK... I still can't uplod pics. I get some security token error... Grrrrr..... Anyway (and I hope this doesn't violate any forum rules as I have the pic on another forum) here are pics. Last edited by ezaircon4jc; 01-26-2016 at 10:36 AM.. |
01-26-2016, 11:39 AM | #8 |
Rep 14,521
oh yeah i saw that post on bimmerfest.
01-26-2016, 08:55 PM | #10 |
Rep 687
ok a little help here.I believe lsturbointeg talked about this before with switching M sport steering with non M sport problems and European wheels.
The pic of my wheel i believe is the sport but non M from and i have a 2011 550i, if i Just got the M sport wheel would i be able to put my airbag back in it? or is it a different airbag also. i"m not talking the LCI sport wheel with the Round bag either. The regular non moded M sport to lsturbointeg wheel he got from Ledermanz. Please help before i order the wrong thing! |
01-26-2016, 09:17 PM | #11 | |
Rep 14,521
01-26-2016, 09:19 PM | #12 |
Rep 14,521
01-26-2016, 09:48 PM | #13 |
Rep 5,409
Yup.. I figuered I had nothing to lose. The hardest part was getting all the "ears" opened at the same time I had to use multiple flat-heads to keep the "ears" open as I moved around the cover. I was surprised how easy the swap was.
01-26-2016, 10:05 PM | #14 |
Rep 687
01-27-2016, 06:55 AM | #15 | |
Rep 14,521
01-27-2016, 06:57 AM | #16 |
Rep 14,521
doesn't that void the warranty on the airbag because it was disassembled?
01-27-2016, 07:26 AM | #17 |
Rep 5,409
04-04-2016, 07:50 AM | #18 |
Rep 13
Hello.
I want to replace/rewrap my steering as well. What is the PM Name of the guy from Luthuania here in the forums? Is he the same guy on EBay?
2011 550i GT
2013 1199R 2011 RSV4 SE |
04-04-2016, 07:44 PM | #19 |
Rep 14,521
i believe so
04-12-2016, 09:17 PM | #20 |
Rep 305
Nice write up. I just swapped my steering wheel from non sport to sport with paddles last month. Instead of buying a sport airbag unit, I bought a sport airbag cover and dismantle the non sport airbag and swapped everything over to the sport airbag cover. Everything fit perfectly. I should've took some photo too for a diy to show how easy it was.
04-12-2016, 10:18 PM | #21 | |
Rep 14,521
04-13-2016, 05:57 PM | #22 | |
Rep 5,409
