2010 2011 BMW 5 Series Forum F10 What did you do to your 5 series today? |
08-22-2023, 07:18 PM | #2927 |
Rep 1,510
08-22-2023, 11:10 PM | #2928 |
Rep 3,586
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.25]
2009 BMW 328i Touri ... [8.00] 2013 BMW X5 35i [7.80] 2011 BMW 528i [8.70] 2006 Mazda3 [5.50] |
08-23-2023, 02:44 PM | #2929 |
Rep 513
Drives: 2013 BMW F10 N55 535i XDrive
$ PURE STAGE 2 {} JORDAN CUSTOM TUNE {} DORCH HPFP {} SNOW METH {} DINAN EXHAUST {} EVOLV DARK OLIVE WRAP $
08-25-2023, 10:12 AM | #2930 |
Rep 124
Nice s550 parked undercover. I had a '17 6-SPD GT and loved that car.
2016 BMW 550i M Sport - Mineral Gray Metallic
2015 BMW X5 base - Jet Black 2011 BMW 335i - Alpine White |
08-25-2023, 11:20 AM | #2931 |
Broke
101
Rep 28
Drives: 2014 BMW 550i
Thanks. Yep, that one's a '15 6 Speed. Gets driven on the weekends when the weather is nice. Thinking of selling it for something more collectible now that I've got the BMW as the daily (and is now faster than the Mustang after going BM3 Stage 2).
08-27-2023, 03:18 AM | #2932 | |
Rep 3
Alex |
08-29-2023, 08:30 PM | #2933 |
Rep 41
08-31-2023, 09:04 AM | #2934 | |
Rep 2,637
You can use whatever fluid you normally use for the front diff.
2015 BMW 535xi
09-01-2023, 12:17 AM | #2935 |
Rep 1,510
Any gear oil rated 75W-85 should be ok. I used used:
1 bottle of BMW Hypoid G2 oil - 83222413511 2 diff plugs - 33117525064 Agree, thats what I did but only recommended if you have fresh fluid in it. If its old fluid, might as well change them since you already pulled everything apart. |
09-04-2023, 05:10 PM | #2936 |
Rep 381
Drives: 2021 M550
Tensioner, pulleys and belt replaced, as well as engine air filter and microfilter, cleaned MAF and MAP sensors. Been a busy day today😄
StradaRedlands5966.50 ctcarbonari415.50 |
09-05-2023, 12:33 AM | #2937 | |
Rep 3,586
And brakes, I love doing brakes. Last edited by StradaRedlands; 09-05-2023 at 11:11 PM.. |
zvery777332.00 |
09-07-2023, 09:06 AM | #2938 |
German Car Caregiver
32
Rep 28
Drives: 2014 BMW 535i M-Sport
I replaced the water pump on my 535i yesterday! A much easier job then I was expecting, once the sway bar is out of the way and the fan shroud is out, it's pretty easy to get to.
Unfortunately I misdiagnosed and I don't think replacing the water pump fixed my issue completely. It's having intermittent overheating issues, the coolant will be sitting at operating temperature just fine, but randomly, though moreso if I'm really getting into the boost, it would spike to over 120C for a few seconds then quickly drop back down to 105-110C. After that happened a few times, I did the bleeding procedure. During that, the pump sounded rough and would just completely stop sometimes, hence why I thought the pump was bad. It's still occasionally overheating even after I got the replacement on, but it does take a lot longer before it spikes over 120C. Regardless, the car had 91k miles on the original pump, so it was bound to go bad soon. Now I need to figure out if I've just got an air bubble, or if the thermostat might be bad, or if something else entirely is wrong. Using ISTA, the car isn't throwing any codes, active or shadow, so I'm not sure what my next step should be. I've had this car for nine days and I'm already frustrated with it lol.
2014 BMW F10 535i - Glacier Silver, Black Dakota; M-Sport Line, M-Sport Susp 704, Sport 8AT, Comfort Seats, Prem, HUD, PDC, Adaptive LED's, CA, Alarm, Soft-Close, Ceramic Controls, Style 351M
2011 BMW E90 328i - Space Grey, Saddle Dakota; Prem, Nav, Style 285 - Sold 2012 BMW E92 328i xDrive - Jet Black, Black Dakota; Prem, CA, Alarm, Style 338 - Totalled |
StradaRedlands5966.50 |
09-07-2023, 10:18 AM | #2939 | |
Rep 2,637
2015 BMW 535xi
09-07-2023, 06:45 PM | #2940 |
32
Rep 28
I drove it about 30 miles today with it being 105F outside and it didn't overheat; so I'm hoping that maybe I just had an air bubble in the system this morning, causing a false overheat warning. If the problem persists, I'll definitely look at the thermostat next.
09-11-2023, 09:09 AM | #2941 |
Rep 124
Oil & filter change, engine air filters and cabin filters.
Man, I tell you...My head about popped off my neck trying to get that 4th and last screw on the underside of the dash to ultimately get to the inside cabin filters. I was tempted to leave the back screw out but was able to (somehow) get it back in place. For those of you who have changed out your cabin air filters...you know what I'm talking about...
09-11-2023, 09:10 AM | #2942 |
Rep 94
New bi-color steering wheel
09-11-2023, 09:59 AM | #2943 |
Rep 116
I managed to destroy the driver rear axle on my car while enjoying some tire smoke.... Replaced it with a cheapy that a local parts store had and it made it maybe 10miles under zero stress before it popped and left me stranded... New OEM on the way as I am not ding this a 4th time LOL
09-11-2023, 11:06 PM | #2944 |
Rep 316
Drives: 2015 BMW 535i M Sport
StreetCruiser287.50 |
09-12-2023, 12:47 AM | #2945 |
Rep 3,586
Amazing interior, even before the steering wheel addition!!!
09-16-2023, 01:54 PM | #2946 |
Rep 81
Drives: 2015 BMW 535i xDrive M sport
Just put some V-Bar covers on today.
09-16-2023, 06:04 PM | #2947 |
Rep 81
Now having the mufflers deleted
zvery777332.00 StradaRedlands5966.50 |
09-21-2023, 03:23 PM | #2948 |
Rep 124
Found an excuse to replace the *STOCK* Michellin RFs--just hit 23k miles!
Picked up a nail somewhere last week. Took it to my local Discount Tire Direct and while they said it could be repaired, @ 4/32" it was not advisable. Did some homework on the Continental Extreme Contact DWS06 plus'--was happy with the reviews and the price point. Nothing like a new pair of shoes!
ChiltiCoatl891935.50 StradaRedlands5966.50 |
