03-19-2020, 08:37 AM | #23 |
Rep 10
03-19-2020, 09:02 AM | #24 |
Rep 14,521
95blkmax222.00 |
03-19-2020, 10:49 AM | #25 |
Rep 554
Lol yeah I can't get back into my old account and the admins are not responding. Damn corona virus.
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg |
lsturbointeg9191.00 |
03-19-2020, 10:50 AM | #26 |
Rep 1,458
Drives: F10 S55, E93 M3, E89 N54
How is this ordeal affecting Burger King?
03-19-2020, 04:17 PM | #28 | |
Rep 554
BK: Boomin!
06-11-2020, 09:30 AM | #29 |
Rep 277
sooo i think this has just happened to me!
car went in for rocker cover and oil cooler leakage. workshop performed the fixes and took it for a test drive. car was running for a while and then just died on them. they couldnt jump start or anything. my mechanic is baffled as to why and told me its fkd and needs replacing... fun times ahead! |
06-11-2020, 02:22 PM | #31 | |
Rep 96
I’m about to do my OFHG and I cringe every time I read another one of these.
2014 535i xDrive | MHD Stage 2+ | ER Catless DP | ER Charge Pipe | G-Plus Intercooler | Walbro 450 LPFP | Staggered 20” Avant Garde M359 |
06-11-2020, 03:12 PM | #32 | ||
Rep 1,938
ezaircon4jc5210.50 |
06-11-2020, 09:58 PM | #33 |
Rep 277
thanks gents! it's a shit place to be right now
no idea if they primed it before starting but the workshop is reputable. many decent cars go through there and the owner drives an e91 himself so dont know wtf happened.. hope to find a resolution and/or replacement soon. will keep you posted. S63 would drop straight in ey? hahaha |
06-11-2020, 10:01 PM | #34 |
Rep 1,458
How many miles.on it? Is the shop gonna help you out at all?
06-11-2020, 10:49 PM | #35 |
Rep 5,611
06-12-2020, 01:09 AM | #36 |
Rep 96
This. Though I do all my own major repair/maintenance, I take my car to the dealer for oil changes for a few reasons. The last time I went, they noted my leaking OFHG (quoted at $800 lol) and I know for sure that my estimate had the SIB number for the “priming” listed on it. I’ll go out to my car in the morning and grab that, because afaik that has never been posted yet.
06-12-2020, 01:46 AM | #37 |
Rep 1,939
I just replaced my entire OFH and did an oil change after the job was done and did the SIB priming procedure.
After replacing the engine or making engine repairs that require the replacement or removal of the engine bearings, VANOS gears, camshafts, bed plate resealing, engine oil pump, engine oil filter housing, cylinder head, engine oil cooler or anything that interrupts the engine oil supply circuit of the engine requires a short oil pump and oil supply circuit priming procedure." This procedure is used when the high pressure fuel system pressure is not depleted after minor engine repairs and the fuel injection system needs to be disabled by removing the fuel injector electrical connectors. 1- If the engine has been drained prior to the repair remove the engine oil drain plug again to remove any residual oil that may have settled in the engine oil pan during the repair if the engine oil pan was not removed entirely. 2- Reinstall and torque the engine oil drain plug (with a new seal ring) per the applicable repair instruction. 3- Remove the oil filter housing cover and verify the oil filter is present. Reinstall the oil filter housing cover and torque it to the proper specification noted in the applicable repair instruction. 4- Fill the engine with the proper type and amount of engine oil, as specified in the applicable repair instruction. 5- Connect a battery charger to the vehicle. 6- Remove all fuel injector electrical connectors to disable fuel injection. 7- Crank the engine for 10 seconds. 8- After 10 seconds have elapsed, stop the starter, and allow the starter to cool for 20 seconds. 9- Repeat steps 7 and 8 two additional times. 10- Reinstall the fuel injector electrical connectors, reassemble the vehicle and verify proper engine operation. 11- After the engine has reached operating temperature, check the engine oil electronically or with the dipstick, and top up the engine oil as needed. |
06-12-2020, 03:11 AM | #38 |
Rep 277
Just under 100k km so not sure how many miles (sorry I'm in Aus)
Yeah I believe they will cover it all since it was in their care the whole time. Plus they were working on the motor and the motor is now dead. Looking to secure a replacement soon hopefully. |
06-12-2020, 09:28 AM | #39 | |
Rep 1,907
Working on a theory.... Oh - and is it a 2011? |
06-12-2020, 10:55 AM | #40 |
Rep 96
The bulletin referenced on my estimate is SIB 09 11 15.
Finding the actual updated document (as it updated since 2009 in 2015 and 2016) is a different story. I've found posts where people have typed out what the bulletin says, but I'd like to find the actual document.
06-25-2020, 09:30 PM | #41 | |
Rep 277
It's a 2010 (VIN: C300045) |
06-25-2020, 10:45 PM | #42 | |
Rep 14,521
06-26-2020, 06:50 AM | #43 |
Rep 277
Can someone explain to me (in layman's terms cos I'm not that bright), how/if "OFHG" is connected/related to a leaking oil cooler and a leaking rocker cover?
06-26-2020, 10:07 AM | #44 |
Rep 1,907
